Looking for info on EDEL 665 - Page 2 - SailNet Community
 2Likes
post #11 of 27 Old 11-24-2009
Not sure myself, I will scan it and see if I can attach it can't see why not.
I will put it up tomorrow.
Dave
WindsorSailer is offline
post #12 of 27 Old 11-24-2009 Thread Starter
This should be my 5th post so I will try to send you a PM.
Reboot11133 is offline
post #13 of 27 Old 12-15-2009
edelsailor's Avatar
Send a message via Yahoo to edelsailor
Hi, I am also an Edel665 owner (1980). I am in hopes to clear a few issues with this thread. First the empty weight is as the brochure states, 2,403 lb. This is all gear it was sold with (cushions,anchor,sails,PFD's,mast and boom,running and standing rigging),no motor. Put the boat in the water and it will displace 2403 pounds of water (physical law.) The displacement of 3,484 lb, is Maurice Edel's Design displacement. Thus 3484-2403=1081 lb, is needed to bring the hull (sink) down to the intended water line, so that the boat will sail with its designed "wetted surface". This is why the Edel665 should not be sailed at no more than 12 degrees heal, because more than that puts more boat in the water. We Yank's distorted the the displacement figures of sailboats for obscure reasons, and thus the ambiguity about how much a sailboat weighs under full crew and gear. If I were an dishonest sailor , I could handicap my boat at 3484, and win the coarse every time.
edelsailor is offline
post #14 of 27 Old 12-15-2009
mitiempo's Avatar
Displacement of a boat on the spec sheet is usually the "designed displacement" and doesn't include the driver, his guests or loose gear unless stated otherwise. The Edel spec sheet is the only one I've ever seen done in that unique way.
Brian
mitiempo is offline
post #15 of 27 Old 12-16-2009
edelsailor's Avatar
I believe the intent was to convey to buyers of the edel665, that this could easily be a "trailer sailor". By knowing the empty weight of the boat, the weight of the trailer, the owner could know if his towing vehicle was capable,as well as not exceeding GVW ratings. I had my edel665 craned off a trailer by the single cable lifting hook in the keel, and the crane scaled it at 2800, its bilges were full of frozen water.
post #16 of 27 Old 03-14-2010
so how is the edel for performance? im looking at buying one and it looks to be a well designed boat
floatingonthewind is offline
post #17 of 27 Old 05-22-2010
Edel Performance
I have a 1981 665. Great boat. I have sailed in 30 knot winds with the second reef in and a small jib to keep her balanced. No problem. When overpowered she rounds up and you can just let the sheet out to keep her going. One nice thing about this boat is that you can still handle the sheets in big wind. Everything is right there by the tiller (mainsheet, jib sheet). I have had this boat surfing at 9mph on the GPS with wind on the stern quarter. She performs best loaded (wl length) and sailed at 10-15 degrees. Just keep the weight out of the ends. I upgraded to standing headroom (pearson 31-2), no twofootitis here. My 665 is for sale in Ontario.
BLUEWATER665 is offline
post #18 of 27 Old 09-03-2010
Bluewater665:
Is your boat still for sale? If so, could you send me more details.
raym0nde is offline
post #19 of 27 Old 04-06-2011
While I do not own an Edel, but i have sailed one several different times, We had it doing 6.1-6.6 knots in heavy winds; with the first reef in the main, and a partially roller reefed 150, so they are considerably fast for a 22 footer.
The owner hauls it out seasonally with his 4x4 and a tongue extension right beside his dock. A very slick procedure!
Its one of the most fun sailboats I have ever sailed on (aside from a soling) It points really well and is very stable going upwind.
The cabin is huge compared to other 22's with a smart and functional layout.
The brochure states it sleeps five; my rule of thumb is that you divide this number by 2 to find out how many it will sleep comfortably, in the case of the edel the answer is 3. While it can sleep 5 in a pinch, you would be crazy to do this.
Adam
Here is a collection of Edel 665 pictures:
Flickr: AdamHowie's Photostream
1977 Laser 1
1980 Edel 665
Dinghy!!! With a 2 horse
AdamHowie is offline
post #20 of 27 Old 04-06-2011
Gary M's Avatar
My memory may be failing me, OK it is failing me, but I seem to recollect that Tania Aebi whose ad apepars on this page may have sailed one from France to the US or Canada. I remember the boat being on display at the Toronto boat show. Might have been a bigger Edel ?
Gary M is offline
Safety of Edel Cat 35 as a blue water cruiser? flyfisher General Discussion (sailing related) 22 01-22-2008 03:15 PM
Edel 35 sport / PHRF ????? mangomike General Discussion (sailing related) 0 12-18-2006 01:35 PM
Monohull vs cat on extended passage? magnusmurphy Cruising & Liveaboard Forum 44 12-16-2005 05:51 AM
