- Quick Menu
11-30-2009
list of seaworthy performance cruisers-IOR
I'm looking to buy a Cal 39 or similar boat. Can anyone suggest boats similar to the CAL 39? Something like an IOR one ton with robust construction. Solid hull layup, fin keel, six foot or less draft, spade rudder or small skeg. Thanks.
11-30-2009
Our personal experience is that you can do quite well shopping such boats, esp if you're prepared to look at some of the many non-mainstream brands, boats built by various "custom" builders throughout the IOR 'disposable boat' era.
They are likely to be rough and/or spartan interior wise, but will be free of molded liners and other obstacles to modifications to layouts and the addition of amenities.
Caution is warranted, though, as some were built rough and ready. Others, though, were well built with the technology of the times. We owned a Choate 40 for 12 years or so, continued to 'cruisifiy' her throughout the time we owned her and had a lot of boat for a fraction of what you'd pay for similar performance in a production boat. We were even fortunate enough to sell her after 12 years for virtually what we'd paid to begin with.
The biggest bonus with this approach is usually excellent deck gear - winches, blocks, steering systems, tunable rigs, and often a good selection of sails (however using the boat as a cruiser and 22 bags of sails are a bit of a contradictory situation - better have a basement!)
What these boats are not are ideal for shorthanded sailing, and many of them can exhibit some positively scary habits downwind in a breeze if you push them. But careful sail selection and heading choices can get you around all that. (No spinnakers in 20 knots of breeze, for instance!) We sailed ours mostly with a blade jib and full main, had plenty of power once we had 12-14 knots apparent upwind.
That boat will probably remain my personal 'favourite', though after wrestling those big headsails for all that time a big 'must have' for our most recent purchase was a fractional rig!
1984 Fast/Nicholson 345
12-01-2009
Most boats from the production builders in the late 70s and early 80s were heavily influenced by the IOR even if they weren't all out racers. One from that era that is racier than the Cal 39 is the Pearson 37. Might fit your requirements.
12-01-2009
Finally found the needle!
I have sailed on a mid eighties CAL39. I can tell you that from 1986-1991 Pearson also made a 39, called the 39-2. Same displacement, and I believe that the saloon was identical to the CAL39. I know that the Pearson offered a centerboard, fin, and winged keel. The CAL that I sailed on had a winged keel. Here's a line drawing:
I believe that JimsCAL must be referring to the 1982-1986 Pearson 37. This is very similar to the 1983-1986 Pearson 34 (its just bigger). Here is a line drawing;
The 1986-1991 Pearson 37-2, however, is an entirely different boat. The 37-2 was designed by a group of Pearson dealers that provided their ideas to Bill Shaw, who penned the final product. [Have you ever heard that a horse designed by committee is a camel?] It was nicknamed the "condo boat." I thought that it looked like something out of star trek. Here is a pic;
(Yes, the pink stuff is wall to wall carpet.)
ASA 101/103/104/105 Certified - Also certified in Recreational Marine Electrical Systems
Reason: Wrong image - Doh!
12-01-2009
Crown 34, Sceptre 36, San Juan 34, C&C 38,40,41... Islander (Peterson) 40 come to mind as production boats clearly based on the IOR rules of the day.
12-01-2009
Thank you everyone! Good information, I will be checking into those designs as possibilities. I appreciate your help. Anyone else care to chime in?
12-01-2009
Super Moderator
With all due respect to my estemed colleague and co-moderator, I would argue that there is just about no such thing as a truly seaworthy performance cruiser-which is also an IOR rule based design.
Perhaps the apparent difference in the opinion expressed by Faster and myself comes in how we each would define term 'seaworthy performance cruiser'. To me a seaworthy performance cruiser must be able to quickly adapt with a small crew to changeable conditions and be seaworthy, seakindly, and easy to handle at the upper ends of the wind range while offering reasonably good performance at the lighter end of the wind range.
No matter how you look at it, IOR era boats were designed to be handled by big strong crews and to have a lot of weight on the rail. By the very nature of the IOR rule, IOR boats counted on huge overlapping headsails to gain performance in anything below a half gail and counted on a large inventory of incrementally larger, heavier and lighter sails.
You can work around this some with modern sail handling gear and with oversized (perhaps power driven) winches and by using smaller sails that are cut slightly fuller from a lighter weight, lower stretch high modulus sail cloth (kevlar, spectra, or carbon) to increase their wind speed range.
But even with all the optiomizing that is possible using modern science, these boats have a lot of drag, low SA/D's and not much stability without a whole lot of weight on the rail, which means that their sails will still have a comparatively narrow wind range (even with roller furling). And that is where I have a problem seeing these performance cruising boats. If you don't do a lot of sail changes you are stuck with one of three poor choices as a cruising boat; either:
- Sailing with a small headsail and having no light air performance,
- Sailing with a large overlapping headsail and have a bear of a boat to push around, especially as windspeeds increase,
- Or doing more frequent sail changes, which is hard to do with a small crew and which also disquailfies it by my my definition of a seaworthy performance cruisng boat since it can't respond qucikly to changing conditions.
Then there are the hull form issues. Most of the IOR era boats came with the gift of a hullform conceived to beat a rule but almost by design, were inherrently skitish when pressed hard. These boats, with enough weight on the rail, were impressive going up wind in a moderate breeze, pointing high and moving well. But as soon as you began to reach or run these boats began to develop nasty habits, so nasty in fact that you lose a key heavy weather survival technique, namely running off under bare poles.
Then there is the robustness issue. While many of the early IOR era boats were pretty solidly built, (boats like the Tartan 41, or Peterson 34) most were not. Boats like the C&C 41 or the Islander Peterson 40 certainly were not especially robust when they were built, let alone 25 years later and even a reasonably well maintained Tartan 41 or Peterson 34 will need a lot of help making it suitable and relable for cruising.
I should say of all the IOR era designs I am particularly fond of the maverick designs which were not strictly designed as IOR designs such as the Contessa 33 (which I raced on for 6-7 years), J-36, Oyster SJ 34, Taylor 39 and 41, and Lightwave 39, Express 37, Frers 36, Hogfarm 30, Soveral 33 and (less so) 39 or many of Farr's racer-cruisers of this era or full blown racers like the Farr 37, and (Garratt)41, which were often departures from the rule that produced better all around boats.
But more to the point, if you are looking for a good, seaworthy, performance, cruising boat then you should really be looking at boats that were not designed with any thought about the IOR rule. If you are going to buy an older boat to fix up, then my advice is to start with the best designed boat that you can find, and improve from there rather than investing your heart and soul in design that will always be limited in performance and seaworthiness by the rating rule it was compromised to beat.....
Respectfully,
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Curmudgeon at Large- sailing my Farr 11.6 on the Chesapeake Bay
12-01-2009
Jeff- Please let me know where you sail so I can stay as far away from there as possible.
12-01-2009
What about an early 1980s Morgan 38?
12-01-2009
As I was reading Jeff`s post I couldn`t help but think that a lot of people might be under the impression that if a boat was designed as a `racing boat`that it was particularly fast. Jeff has already explained the handling issues. To my mind what it really means if designed as a racer under the IOR rule is that it was distorted in various ways to rate well, hopefully better than the competition. Features like low ballastédisp ratios were I believe treated well under the IOR so you had a good rating and could make up for it with crew on the rail, as they were not measured. What you really want is a boat that was designed to be fast based on the water conditions, not based on the rule. I will leave it to others to come up with some good examples, except to suggest the CS36T as one good example.
Brian
| Thread Tools |
Search this Thread |
