12-13-2009
I haven't. I think that you have to be careful with spray foam though. In a confined space it may expand too fast and could bulge the liner. If the liner doesn't contact the hull there should be no condensation. If a part of the liner does touch the hull there might be condensation, but without a gap you can't do much about it. I only get condense where the warm air inside touches the cold hull. In a locker the air space acts as insulation and stops the warm inner air from touching the hull so no problem usually. In extreme cold it could condense but the water temp is pretty constant and it doesn't seem to be a problem.
Brian
Reason: add
