Teak and Ipe are pretty dissimilar:
From the Forest Products laboratory:
Teak:
Weight: Basic specific gravity (ovendry weight/green volume) 0.55; air-dry density 40 pcf.
Mechanical Properties: (First set of data based on the 2-cm standard; second and third sets on the 2-in. standard; third set plantation-grown in Honduras.)
Moisture content Bending strength Modulus of elasticity Maximum crushing strength
(%) (Psi) (1,000 psi) (Psi)
Green (17) 12,200 1,280 6,210
11% 15,400 1,450 8,760
Green (38) 10,770 1,570 5,470
14% 12,300 1,710 6,830
Green (81) 9,940 1,350 4,780
13% 13,310 1,390 6,770
Janka side hardness 1,000 to 1,155 lb for dry material. Forest Products Laboratory toughness 116 in.-lb average for green and dry wood (5/8-in. specimen
Ipe:
Weight: Basic specific gravity (ovendry weight/green volume) 0.85 to 0.97; air- dry density 66 to 75 pcf.
Mechanical Properties: (First and third sets of data based on the 2-in. standard, the second on the 1-in. standard.)
(%) (Psi) (1,000 psi) (Psi)>>
Green (73) 22,560 2,920 10,350
12% 25,360 3,140 13,010
12% (24) 25,200 3,010 14,000
12% (44) 28,000 3,350 NA
Janka side hardness 3,060 lb for green material and 3,680 lb at 12% moisture content. Forest Products Laboratory toughness average for green and dry material is 404 in.-lb. (5/8-in. specimen).
Ipe is about twice as heavy (and twice as stong) as Teak (Tectona Grandis). Note that the "green" plantation grown teak is significantly weaker than the (old growth) standard. Ipe is more consistent.
They're both silica rich woods.
Here's Angelique:
Weight: Basic specific gravity (ovendry weight/green volume) 0.65; air-dry density 50 pcf.
Mechanical Properties: (2-in. standard)
Green (74) 11,410 1,840 5,590
12% 17,390 2,190 8,770
Janka side hardness 1,100 lb. for green material and 1,290 lb. at 12% moisture content. Forest Products Laboratory toughness average for green and air-dry material is 151 in.-lb. (5/8-in. specimen). (More similar to T. Grandis mechanically)
