Info on a 70 Oday 23' Pop Top - Page 2 - SailNet Community
post #11 of 14 Old 12-21-2009 Thread Starter
Sunsets and Warm Beer....
LandLocked66c's Avatar
If the boom is lower that definitely won't work!
Thanks guys! This is the kind of info I was looking for... There is no way to verify the retractable keel right now. I could ask him to put it up on stands though.
I did check the cabin latches, they were lined up nicely. I have owned a pop top camper and have seen the effects of a messed up pop top. I'm positive that the 40 year old seal is probably long gone, which would attribute that damge. The one thing that I did notice was there was no sign of a high water mark inside the cabin. The bilge was fairly clean. I'm thinking this boat sat more on land than it did in water.
You can't steer a boat that isn't moving? Just like a life - P. Lutus
LandLocked66c is offline
post #12 of 14 Old 12-21-2009
blt2ski's Avatar
NOt positive, but IIRC USSpars in Florida may have been the supplier of your mast. A lookup on the internet at usspars.com may be worth it, and if they did supply the mast, get a cost to replace it. OR, talk to a local rigger, they may be able to weld an additional 6" back onto the base. Not "MY" personaly first choice of a fix, ie the welding, but a smaller boat like this may work just fine! This of course is assuming the shrouds and stays are still long enough to handle the extra 6" of mast height.
marty
She drives me boat,
I drives me dinghy!
blt2ski is offline
post #13 of 14 Old 12-21-2009 Thread Starter
I called him up to ask more about the mast. It was indeed cut at the bottom. He said there was still more than enough head room. He offered to hoist the boat up to inspect the retractable keel as well.
The stays have been modified already, so they would have to be replaced...
post #14 of 14 Old 12-31-2009 Thread Starter
Going back tomorrow for a second inspection. We'll see what happens...
wanted for mac25 85 pop top cover in up position roland5 MacGregor 0 07-20-2006 11:52 AM
Cal 27 Pop Top Conversion DonaldAdams General Discussion (sailing related) 2 07-10-2006 11:24 PM
O''Day "rOnDAYvous 04" maestro General Discussion (sailing related) 2 07-11-2004 04:50 PM
Top 10 Sailing Venues Dan Dickison Cruising Articles 0 08-11-2002 08:00 PM
C-22 Pop Top Enclosure lil roxie Gear & Maintenance 0 04-22-2002 04:07 PM
