- Quick Menu
03-04-2007
A few other things about Etaps.
They tend to have a bit less interior volume, compared to other boats in the same size range, since the hull is considerably thicker than that of a standard boat.
One reason the Etaps seem to hold their resale value well is due to the extremely rigid hull that their construction gives them.
Essentially, the Etap can be described as either a double hulled boat, with foam between the hulls or a very thick cored hull—depending on how you want to look at it.
The exterior skin on an Etap hull is almost as thick as the hull on a standard solid fiberglass hull from what I've been told. Needless to say, the Etaps tend to be a bit heavier than some comparably sized boats of similar design.
03-05-2007
moderate?
Question:
Are they really a cored hull with adhesion between the foam and 2 hulls or is there really just a hull liner with foam filling? I always thought it was the latter.
How do you get at the exterior hull for leaks, fittings etc. over time?
03-05-2007
Wandering Aimlessly
"ETAP Yachting decided on a unique, technically refined construction method known as the ETAP ship-in-ship construction. In the ETAP ship-in-ship construction, the deck and hull are double-skinned. The hollow space between the two decks and two hulls is filled with closed-cell polyurethane foam. The closed cell structure is almost entirely non-absorbent and gives the boat sufficient buoyancy."
From the ETAP website.
John
Ontario 32 - Aria
Free, is the heart, that lives not, in fear.
Full, is the spirit, that thinks not, of falling.
True, is the soul, that hesitates not, to give.
Alive, is the one, that believes, in love. JCP
Music on the Wind - To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
03-05-2007
Larus Marinus
Here's a couple of pictures taken 1n the ETAP factory.
http://i167.photobucket.com/albums/u...s/PIC00091.jpg
http://i167.photobucket.com/albums/u...s/PIC00096.jpg
The first is an example of the inner hull and the second is of boats going out the door.
ETAP claim that the water take-up of the foam they use between the hulls is only 1.5% in 10 years. They admit that what is not designed into the boat is difficult to add afterwards.
03-05-2007
Cam-
From what my friend's surveyor said, it sounds like the foam is bonded to both hulls... and basically, as ideins said... adding anything that isn't provided for initially is relatively difficult to do.
03-05-2007
My live aboard sailing class was on an Etap 37. Seems to be a very interesting boat. A few details:
The head/galley/nav section of the boat had standing headroom for me (6'4.5") but forward of that has a lower roof. The two sinks are set in a centerline island which I'm still not conviced really makes sense, especially since the island does not cover the area directly behind the stove/range. At anchor or tied up it seemed to work just fine.
For shoal draft, our boat featured twin keels connected by a bulb. Our instructor said that the 32' version with these keels was a joy to run even in reverse. Our boat was very maneuverable but I guess not the the same extreme.
Another thing that didn't come up but might is that like many modern boats the bilge is very shallow. In this case there are no limber holes connecting the various areas and there was a hose you could manauver around to get the bilge pump to clear out any water.
Someone mentioned lack of dealers, as far as I know the charter company I was with also sells the Etaps. They are in the Ft Myers area.
05-07-2007
Etap 30 - Local to Chesapeake Bay
I'm looking for owners of any Etap 30's on the Chesapeake Bay, especially those that race them in PHRF.
Also, I'm interested to learn if anybody has recommendations on rig tension numbers and rig tune.
Take care,
Carl
Etap 30, "Cadence II"
USA108
05-07-2007
Senior Moment
Carl,
I know of one just south of Annapolis -- Herrington Harbor area. The guy posts a lot on Sailing Anarchy and I will track him down over there to hook up with you. Current name of the boat is "Duck Sloop", which I think this guy wants to change for some reason?
Ooops...just noticed you are that guy!!! So never mind. You changed usernames on me, Cheap.
SailorMitch Sailing winged keels since 1989.
1.20.09 Bush's last day the end of an error !! Hopefully we still have a constitution and economy left by then.
"Compassion and tolerance are not a sign of weakness, but a sign of strength." The Dalai Lama
good planets are hard to find-- a song by steve forbert
I have but one lamp by which my feet are guided, and that is the lamp of experience. I know no way of judging the future but by the past.-- Patrick Henry.
05-07-2007
Best Looking Moderator
Etap= Portugese racing boat without a removeable anchor roller. (smile).
Catalina 400 Technical Editor
Catalina 400, HN#289
Com-Pac 16
Are you trying to talk your spouse or family into cruising or sailing? Want to know what it is like, every day? Click here and enjoy: To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
05-23-2007
Originally Posted by SailorMitch
Carl,
Sorry about that! Yup, I'm one and the same. "Duck Sloop" is now "Cadence II" and we sail out of Herrington Harbour South.
I had heard that there was another Etap 30 on the West River but I haven't been able to locate any additional information on it. If you hear of anyone with an Etap 30 on the Bay (or someplace else for that matter), please let me know. There aren't a lot of us in the States!
Carl
Etap 30, USA 108
"Cadence II"
| Thread Tools |
Search this Thread |
| Thread |
Thread Starter |
Forum |
Replies |
Last Post |
ETAP
h20ski |
Boat Review and Purchase Forum |
1 |
01-19-2005 06:12 PM |
ETap 30
KenD |
4 |
01-14-2004 07:54 AM |
ETAP 39
Sharlyn |
2 |
04-23-2002 03:45 PM |
ETAP???
murph182 |
2 |
01-26-2002 07:12 PM |
Etap 39
stord |
1 |
10-16-2001 07:42 AM |
