Old 02-11-2010
snickant is on a distinguished road
stripper
it has been suggested that i use a chemical stripper to remove the remaining paint on the inside of my cal 2-30. i have scraped and chipped so far. any suggestions on the best brands? is it safe to do in the cabin of a sailboat? thanks, glenn
Old 02-11-2010
Yes, just wear proper respirator with VOC filtering... Soy Strip and some others have worked fairly well and are less toxic than the more traditional strippers. Be sure you get a "fiberglass" safe paint stripper.
Old 02-11-2010
jrd22's Avatar
Courtney the Dancer
I've been using a 3M "safe" stripper to remove varnish on teak and it has worked very well. The fumes are not bad at all, I don't think you would have a problem using it inside the boat. I've used regular strippers and this seems just as fast and a lot more pleasant to work around.
John
SV Laurie Anne
1988 Brewer 40 Pilothouse
Old 02-11-2010
Part of the solution
bljones has a spectacular aura about bljones has a spectacular aura about
This thread isn't nearly as interesting as the title led me to believe.
*tucks $10 bills back into wallet.*
Best Bottom Paint Stripper talbot Gear & Maintenance 6 10-31-2009 12:01 PM
Anyone know a good stripper? GilStump Gear & Maintenance 11 10-26-2009 12:42 PM
stripper ring for Lewmar 40ST winch L124C Gear & Maintenance 32 10-15-2009 06:00 PM
Txs-alamo TXS-ALAMO Gear & Maintenance 1 06-03-2006 11:18 PM
Bottom Stripper walt123 Gear & Maintenance 0 06-26-2001 07:06 PM
