02-24-2010
She's a beautiful boat, but doesn't appear to be cold-molded. Cold-molded boats, where the wood is encapsulated in epoxy resin, are often as low maintenance as GRP boats. I don't believe that is the case here.
The deck is marine plywood with teak decks screwed into it. If the teak deck have leaked the marine plywood could be in pretty rotten shape, similar to what would happen on a teak-decked cored-laminate deck boat.
