02-27-2010
We frequent Rock Hall and Swan Creek and have used Hharbor Haven to work on the boat when it involves things I cannot do (even though it it across the bay from us). Having a 4'6 draft with the centerboard up ( 6'5with it down)
is a great advantage back in the creek as it has some definate shallow spots.
You should have no problems with what you are looking at at the Emporium. The shoal draft is an advantage in places like the Bohemia River Still Pond and can make the difference between anchoring inside or outside on Worton Creek. As stated make sure you slip has plenty of water as there are times when the water is blown out of the bay and there is a 2/3 ft difference and your boat may sit on the bottom.
Dave
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. ___________________________
C&C 35 MKIII Hull # 76
Parkville, Maryland
(photos by Joe McCary)
Our blog- To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
