Old 02-25-2010
scottmillington is on a distinguished road
draft
How deep of a draft would be maximum for the middle and upper chesapeake bay for cruising?
Old 02-25-2010
Jeff_H's Avatar
Super Moderator
I would say that 6'-6" to 7'-0" is a practical limit. After that there are a whole bunch of places that you can't get into. I ended up with 6'-4" draft and that has worked quite well. I have also raced and cruised on a boat with 8 Foot draft and that hasn't been a deal breaker but it certainly less than ideal.
Curmudgeon at Large- sailing my Farr 11.6 on the Chesapeake Bay
Old 02-25-2010
justified is on a distinguished road
Scott
I have been from the C&D down to Hampton Roads last fall and and stopped at several spots to anchor and I do not think you would have any problems if you are at 5.5' to 6' draft JMHO. you should be checking the charts for the areas you want to go, if you don't have them all a good resource is Activecaptain.com you can view all the NOAA charts. I'm not connected with them in anyway just a satisfied user. It is a wealth of info for planning your trips. That part of the Chesapeake is a beautiful area I would love to spend more time cruising there my self.
Peter
Old 02-25-2010
JohnRPollard's Avatar
Moderator
You will be boxed out of more than a few nice places with more than 5-5.5' draft (some real shallow water sailors would say 3-4'!)
But there is a lifetime's worth of anchorages in the Bay that will accommodate 6'+ draft.
What size boats are you considering? A 40'+ monohull will likely sacrifice a lot of upwind performance with 5' draft (assuming no centerboard). On the other hand, a 25 footer could easily get away with less draft without sacrificing performance.
Old 02-25-2010
draft
The draft is 6'2" on 35'. Would love the performance, but my perfered marina would be in Rock Hall. What do you guys think?
Old 02-25-2010
Moderator
For comparison sake, our 31 footer is the "standard draft" version at 4'10". The shoal is 4' even. I would not mind 6'2" in a 40+ footer (acceptable compromise for the additional comfort and speed of a larger boat). On a mid-30-foot cruising boat, it would be a much tougher call.
Everything's a trade-off, there's no one right answer.
Also, check with the preferred marina. It might be fine, or might require a more expensive (longer & deeper) slip.
Old 02-25-2010
wwilson's Avatar
Chesapeake Sailor
wwilson is on a distinguished road
Scott,
I've been in and out of Rockhall dozens of times over the last ten years with a 6'2" draft boat without incident. I have a good friend who keeps his 6'4" draft boat at the Sailing Emporium.
On entry - favor the red.
Wayne
Old 02-25-2010
thanks for the help, how about
Swan Creek. i like Osprey point
because of the floating docks.
Old 02-25-2010
wwilson's Avatar
Chesapeake Sailor
Hmmmm - I thought you said Rock Hall. I chartered an IP350 in Swan Ck back in the 90's and stuck her slight 4'6" draft in the mud on return.
I think Dave of s/v Auspicious has drug his 6' of lead into that Ck with better results though... Dave?
Wayne
Old 02-25-2010
I used to keep my old boat on Swan creek,4'6" draft and generally did not have a problem. There are some larger boats back there including a Hylas 54 which I figured has to have at least a six foot draft. Appreciate anyone else opinion.
First Boat - Draft Advice nolesailor Boat Review and Purchase Forum 4 11-19-2009 01:49 PM
Hunter 37 Cutter deep and shallow draft donrr1 Hunter 0 10-28-2006 11:45 AM
How Much Draft? Cheetie Cruising & Liveaboard Forum 2 04-28-2002 12:21 AM
Shoal Draft Cruisers Sue & Larry Buying a Boat Articles 0 02-20-2002 07:00 PM
Long Island Sound - Ideal Draft thomsonjd Boat Review and Purchase Forum 11 11-04-2001 06:10 PM
