Interesting Sailboats - Page 126 - SailNet Community
 1272Likes
post #1251 of 6763 Old 07-08-2011
Maxi11 had blog page with time counter and last time I have checked it was "Prototype launch in 7 weeks", mid of August. Now they postponed launch till November... and changed design quite a lot.
G1000 is offline
post #1252 of 6763 Old 07-08-2011 Thread Starter
Yes you are right, they have changed their project. I believe they have reformulated the boat to be more competitive in handicap racing. There are few images of the previous model but it seemed even more interesting to me:
post #1253 of 6763 Old 07-08-2011
new Maxi11 looks like J/111. initial design was much more eye catching.
G1000 is offline
post #1254 of 6763 Old 07-08-2011 Thread Starter
New boat! From Sweden, and a fast one, the HR 10.30.
First take a look at the movie: The HR in a North European race.
YouTube - ‪Bohusracet 2011‬‏
YouTube - ‪HP1030 'Earl Grey' på jomfrutur, Kronborg og Nivå‬‏
The boat is narrow and very light:
It has a good quality interior:
and is beautiful:
And it is fast...but coming from Sweden is not going to be cheap...well not everything can be perfect
post #1255 of 6763 Old 07-09-2011 Thread Starter
Beautifull boats
Billionaires Idea of a race boat. They are fast big (100ft) and need a huge crew.
This is the beginning of the TR race (Transat) that joined some of the biggest and fastest boats around, racers, cruiser racers and just big cruisers. They look nice, no doubt about that.
The fastest seem to be the Jk designed 100ft Rambler with the smaller Puma (Vor 70) putting a good fight now that Leopard has lost its bowsprit.
They have made 3 starts (slower boats first). This is the third start (fastest boats):
YouTube - ‪Third start 3rd July‬‏
This is the second start and guess who was there? The big one with the funny electronic controlled sails, the Maltese Falcon and it is not properly slow. Other two interesting boats on that start, The Ourson Rapide, the Finot designed luxurious yacht based on an open 60 and the Gunboat 66, pissing the big racing mono-hulls with big crews, going faster with a cruising boat and a smaller crew.
YouTube - ‪Second Start Transatlantic Race‬‏
YouTube - ‪Open Class Start‬‏
For the ones that want to follow the race (they have a tracker):
Transatlantic Race 2011 / Atlantic Ocean Series
There are also some 40 class boats that are putting a good fight against 50ft race boats with a full crew.
post #1256 of 6763 Old 07-10-2011 Thread Starter
HP (High Performance), the Sweden shipyard that makes the 10.30 has two more boats on the line to came out in the market, a 12.30m and a 8.5m boat.
The 41ft is interesting with a 3.7m beam, 2.5m draft and 1900kg of ballast to 5500kg of height. 106m2 of sail will make it a top performance boat.
But the one I find a knock out is the smaller boat, the 8.50:
3.05m of beam, with a very reduced beam at waterline (2.06) a draft that is compatible with cruising (1.80m) a 1650kg of weight and almost half of it as ballast (800kg) and on top of this the boat is just beautiful
post #1257 of 6763 Old 07-11-2011 Thread Starter
I hate the handicap concept
Some very interesting information about the Elan 350 and its optimization for IRC racing. The information is provided by the boat designer.
Most sailors would think that when you optimize a boat for racing that we are talking about making a boat as fast as we can. But that is not really about that, it is just a way of making a boat do best under an arbitrary set of rules and that means many times a considerable SLOWER boat.
Let's see what happens with the Elan 350 optimization for IRC racing:
Compared wins in time with different boat configurations.
Wins in time over the Standard boat:
Standard sail plan with carbon rig & rod rigging – 14 seconds/hour
S.G. iron & lead 2.35m draft keel – 38 seconds/hour
Elan Race Team RP version with taller rig & deep draft composite keel – 4m 12s/hour
Spinnaker pole – 17s/hour
These modifications affect the IRC rating like this:
1. 2.15m iron keel / alloy rig & wire rigging TCC = 1.029
2. 2.15m iron keel / carbon rig and rod rigging TCC = 1.033
3. 2.35m iron & lead keel / alloy rig & wire rigging TCC = 1.040
4. 2.35m iron & lead keel / carbon rig & rod rigging TCC = 1.044
5. 2.35m iron & lead keel / Elan Race Team RP carbon rig & rod rigging TCC = 1.101
6. 2.15m iron keel / carbon rig / pole, 100sqm SPA & 4.31m STL TCC = 1.035
7. 2.15m iron keel / carbon rig / pole, 110sqm SPA & 4.31m STL TCC = 1.038
Conclusions:
About the fastest configuration with 2.35m iron & lead keel / Elan Racing Team RP carbon rig : Best configuration in under 6kts TWS as this option has highest sail area to wetted surface area.
Above 6kts TWS the boat is very uncompetitive under IRC due to its high rating. She must be capable of sailing 4 mins 12 secs per hour faster than the standard boat to perform better under IRC and the VPP is simply saying that she will not be able to do this above 6kts TWS.
The best configuration for winning in IRC:
For optimum performance under IRC, our recommendation would be to go with 2.15m draft S.G. iron keel and standard sized carbon rig with rod standing rigging. This will give best compromise between performance and rating. It is then down to what sort of racing the boat will do as to what best option is between spinnaker pole and bow sprit. If more reaching type courses are envisaged then the best option would be to remain with the centreline bowsprit and not carry a spinnaker pole. If a large amount of windward leeward type racing is envisaged then the best option would be to use a spinnaker pole with a combination of asymmetric and symmetric spinnakers.
Well, if you really want to win, make your boat slower. Just through out the lead keel and make it a lot heavier (lead and smaller draft will be compensated with a lot more ballast). This is the conclusion we can take from all this and the reason that I really hate handicap races: they don’t make sense and contribute to the design of slower and less effective sailboats.
post #1258 of 6763 Old 07-11-2011 Thread Starter
There are some that follow and participate on this thread that have a special interest in the Transaquadra. Just to say that the race is on...kind off
You can follow here (router):
Le dpart de la Trasquadra est report | Transquadra 2011-2012
And for the ones that don't know about what I am talking about and why this race is special to some of us you can read here:
Transquadra: Good start to Barcelona | en.NauticWebNEWs.com
THE TRANSQUADRA'S LESSONS - Agathe Armand (English Version)
Some videos here:
Transquadra 2011 2012 - A Video PlayList on Dailymotion
Dailymotion - depart barcelone part 1 - une vidéo Sports & Extreme
Regarding interesting boats this race shows what are the types of boats best suited to be solo sailed (or duo sailed) by a non professional sailor (with more than 40 year's old), fast across the Atlantic. That is an interesting information and this is an interesting race
post #1259 of 6763 Old 07-12-2011 Thread Starter
TRANSQUADRA and boat's performance
The Transquadra is very handy to take relevant information about boat performance, specially in what regards solo or duo sailing. This information is interesting because these guys are not super sailors that can sail fast a very powerful boat, but mostly average sailors like you and me.
There are some big boats there (40 to 49ft) and mostly small boats, from 30 to 35ft. The first conclusion is that small boats are faster with a small and not super experienced crew. This is not a conclusion from this edition but a conclusion we can confirm in past editions.
Let's take a look at how the boats are doing on this edition:
The ones that sailed from Barcelona (they departed sooner) had very weak and variable winds. The leader is a Jeanneau SF 3200, followed by another SF 3200, a JPK 110 and the leader on solo sails a A35. The bigger boats are way back (2 Dufour 40, a Hanse 411, a Comfortina 42) and the last is a Jeanneau SO 49.
The ones that departed Yesterday from Saint Nazaire had good winds and are sailing downwind with 14K winds. The leader is a A35 (doing 8.7K). There are several A35 on the leading pack, a A31, several JPK 110 and a JPK 9.6. The Sun Fast 3200 are close, just a little behind but ahead of bigger boats like two First 40.7, a GS 37, two 40 Sun Fast and a GS 40.
The fastest solo boat seems to be a First 35 followed by a Jod 35. Close there are a A31, a JPK 110 and a SF 3200.
It seems that the guys on the bigger boats, like the First 40.7 or GS 40 are not able to exploit the boat to its full potential while the guys on smaller boats manage to go faster, probably because the boat and the smaller sails are easier to handle.
post #1260 of 6763 Old 07-12-2011 Thread Starter
Closed Thread
Currently Active Users Viewing This Thread: 6 (0 members and 6 guests)
THE Yacht Builder List T37Chef Boat Review and Purchase Forum 27 10-04-2015 02:38 PM
Cruising sailboats for sale welch Cruising & Liveaboard Forum 10 04-25-2012 06:20 PM
Noob wonderings and questions about sailing, life at sail and sailboats Vans General Discussion (sailing related) 49 06-20-2011 01:18 AM
A List of ALL sailboats made with layouts? Myblueheaven Boat Review and Purchase Forum 8 10-08-2010 12:32 PM
Failure to Navigate - interesting post on Panbo Blog & from the NewsReader Mass Bay Sailors 0 12-11-2006 07:15 PM
