Interesting Sailboats - Page 161 - SailNet Community
 1272Likes
post #1601 of 6763 Old 10-30-2011
Moderator
JohnRPollard's Avatar
Pacific Proa
I hope this design meets the thread criteria for "Interesting Sailboats."
Test Sailing a Pacific Proa
PCP likes this.
JohnRPollard is offline
post #1602 of 6763 Old 10-30-2011
What is this "optimum heel angle" stuff? Most designers will tell you its zero degrees. In any boat in order to get max performance you try and sail the boat upright.
I don't know how you say this. For skiffs and many dinghies, of course what you say is true, but I wasn't referring to them.
I am positive that you of all people know that a keelboat (unless crew weight is a large percentage of total weight) will in fact heel when there's much breeze, that for best speed one doesn't trim and adjust amount of sail carried to maintain overly-low let alone flat heel but rather best speed will be with some significant heel, that the boat can be designed to offer reduced wetted area when heeled and usually is designed to do this, that when shaping the hull for best speed while actually sailing this surely would have to be with heel taken into account, etc.
If you want I could find a specific boat for which a specific value has been given. But I am guessing that most likely it is now clear what I was meaning so there may be no need for a particular example (I'd really guess not as you have vast experience of course.)
estaban is offline
post #1603 of 6763 Old 10-30-2011
Hi Estaban,
If you really insist and if they see that you would not buy the boat without stability data the factory will provide you with a stability curve made by the boat designer and used to certify the boat.
Good to know, thank you!
If you use a RM curve you can calculate all those values.
Yes, if having the curve. I was trying to think of ways to have a limited set of numbers to compare with. Agreed that the curve itself will always have more information.
About the resistance to heel at 0º I don't understand what you mean. You have to explain that better. At 0º the boat is not heeled .
I wrote it horribly, not according to what I was thinking. I was thinking of the derivative, the rate that stability increases from zero degrees: the slope of the curve. In other words, does stability increase only slowly as the boat begins heeling from zero degrees, or sharply? A single number could give a reasonably good picture here.
estaban is offline
post #1604 of 6763 Old 10-30-2011 Thread Starter
Estaban, What Bob said is right (of course). What you are talking about is another thing: When the boat heels generates a righting moment, initially ballast counts very little for it and RM comes almost all from form stability but when the boat heels more and more, ballast starts to count on the RM.
Max righting moment normally happens around 60º and that means that it is at that point that the boat has more power to carry sails. We know that no boat sails well at 60º of heel and that it will sail faster at lower angles of heel.
Why? Because the drag is so much that will not compensate the more power (righting moment) that the boat can generate with all that heel.
What you are talking about is about the heel angle that represents the better compromise between power (RM) and drag. The heel point were the sailboat will sail faster.
post #1605 of 6763 Old 10-30-2011 Thread Starter
Yes, I understand what you mean
You can see that on a GZ (or RM) curve and it is exactly as you say, a step curve indicates a boat that generates RM with small angles of heel. Multihulls have a very step GZ curve, so step that it don't look like a curve
Beamy boats have more steeper curves comparing with narrow boats but, providing they have an adequate RM to sail, they will have also a higher AVS and a smaller inverted stability.
post #1606 of 6763 Old 10-30-2011
That's right, that's exactly what I was talking about.
If a given boat, say a Finot-designed boat, stays flatter when sailed optimally (best speed for course and conditions) than some other boat, then even if total area under the curve is the same between it and another boat, it has a significant "head start" so to speak and in practice will require more energy to capsize.
Not more energy from zero degrees, but more energy from an angle hopefully similar to what the boat was at before the gust or wave, as the flatter-sailing boat "has more of the curve left."
As you say, it's not irrelevant how flat the boat will tend to stay in the first place. The number for a given condition when the boat is sailed properly is not zero. (Well for some conditions it will be zero. But for example, it's unlikely to be zero at say 20 knots TWS upwind.)
And for the given condition it can differ between boats, sometimes by quite a bit.
Your other considerations you were talking about are on different points than energy required to capsize beyond optimal heel (as opposed to beyond flat, which I think isn't as useful as the difference has already been used up) and I agree with what you're saying.
To summarize really briefly, what I was saying is that while it's impossible to reduce stability to a single number, a small set of chosen numbers could give a reasonable picture. I was trying to give examples of a small set.
The "Q" value posted earlier is I think a nice example of a single number that can give a guideline, but as you said back at that time, not the whole picture.
estaban is offline
post #1607 of 6763 Old 10-30-2011 Thread Starter
Hi John,
Certainly it meets and nothing had been posted yet about Proas. Thanks for posting it.
By the way do you know that Proa means in Portuguese and Spanish, Bow? Those boats are probably called like that because when the Spanish or Portuguese find the first native ones they found out they had two proas and no popa (stern).
That one looks particularly interesting.
Proas did never manage to get a grip on mass production cruising boats, i don't know why, perhaps because they sail in a different way.
On this site we can find a good explanation about the differences between a Proa and a Cat, advantages and disadvantages:
Pacific Proa Advantages:
The Pacific proa gets advantages over the catamaran by using the same weight of materials (cost!) to create a significantly longer main hull with higher speed potential:
a longer hull is more easily driven for fast ocean passages and more appropriate to the scale of large seas offshore.
transferring up to 100% displacement to the single large leeward hull as the windward hull lifts results in smooth, comfortable speed with minimal wetted surface.
when pressed for maximum speed, the longer leeward hull with similar rig and no additional lateral stability (the ability to resist tipping over sideways) results in greater longitudinal stability than a catamaran. Instead of pitchpoling, the Pacific proa will roll gently onto the leeward pod .
a small, lifting hull to weather for stability is mechanically easier and lighter than connecting two hulls of equal size and weight (catamaran) or using "floats" of 100%+ buoyancy on either side (trimaran).
While modern materials and methods make structure less of an issue, the crossbeams on a Pacific proa are less stressed than a catamaran of similar displacement.
For the very same reasons, however, it is also true that the Pacific proa carries much less weight for it's length than a catamaran.
Catamaran Advantages:
The catamaran has broad flat transoms aft that carry weight well and reduce pitching; the proa is pointed at both ends.
The catamaran has extra privacy afforded by two hulls for accommodations.
Since there is only one large hull, adding length to a proa returns less accommodation volume and weight carrying capacity than the same length added to a catamaran.
The proa's main hull might be narrower than the catamaran, using a length to beam ratio of 17:1 for speed, resulting in a smaller interior space.
For these reasons, a 21 meter (69') proa has barely the same accommodations as a 43' catamaran. When compared to an 18 meter (59') catamaran, the 21 meter proa has significantly less accommodation volume...
Pacific Proa compared to Catamaran
Of course the guy is a bit partial about Proas
There are other advantages in a Cat: A substantially bigger righting moment for the same weight and beam and also a more straight forward way of changing tack, losing less time and distance.
post #1608 of 6763 Old 10-30-2011
If we can post about non-cruiseable boats:
The new Marstrom M32 is very interesting.
A 32 foot extreme high performance catamaran that can be sailed by only two.
Torvar Mirsky testing Marström 32 - YouTube
Katamaran M32 in Travemünde | NDR.de - Fernsehen - Sendungen A - Z - Schleswig-Holstein Magazin - media
Taufe des Hightech-Katamarans* - * SAT1 REGIONAL
Marstrom Composite AB
estaban is offline
post #1609 of 6763 Old 10-30-2011 Thread Starter
This thread is also about racing boats. there are several racing boats posted here. That one is a nice one and the movies are impressed. I hope that they don't pitch pole as easely as the ones from the America's cup
I also was impressed by the fact that a new racing cat is matter for the TV news in Germany. Impressive. That shows the public interest in sailing. I had no idea, I thought that only happen in France
I also noticed that the company that makes the M32 is the same that make all parts for the Seacart 30. That one has just a big defect: Not having a performance cruising version
post #1610 of 6763 Old 10-30-2011 Thread Starter
After some hard racers almost a classical performance cruiser,the first serious Salona 38 sailtest, by Voile and Voiliers:
And a test with more than some hours on the water, they passed 24 hours on the boat on a delivery trip and experienced different sea and wind conditions.
The boat was not sailed with a full racing crew seated on the sides, but only by two guys, one of them, a journaliste.
First interesting note, the title they have chosen for the article: “Salona 38, already a great classic”. Well, that’s a good omen.
They sailed with a jib (solent) and that worsens the boat performance with light winds. The boat can come with that sail or with a 140% genoa.
Personally I would choose the bigger front sail and for stronger winds a jib mounted on a removable stay sail.
Even handicapped by the small front sail the measured speeds in light winds were not bad:
With 7K true wind at 45ºTW they made 5.9K
With 7K true wind at 120ºTW they made 6.1K
With stronger winds:
With 19K true wind at 70ºTW they made 8.2K
With 22K true wind at 95ºTW they made 10.5K
With confused seas and waves, sailing with a small spinnaker (for stronger winds):
With 18K true wind at 150ºTW they made never less than 9.5K and sometimes more.
They say that if the sea was not so confused and if they had proper following waves they would probably have surfed the waves, getting more speed. They say also that with a bigger spinnaker and that wind they would have probably the boat planning.
I know of similar typed boats that with strong winds and spinnaker had sailed at 16k (Elan 37).
These speeds were expected, considering the small front sail and the small spinaker, what gave me more satisfaction on this test was the confirmation of something that I also was expecting but that I never had heard confirmation:
I was expecting that the considerable rocker of this boat, the fine entries and a moderate beam would contribute to a good wave passage with not much wave drag and with a reasonably good comfort motion.
They have said about it:
“Without effort, the Salona 38 …passes easily the chop, dragging little water …. In every sailing conditions the dominant impressions are: the easiness at the wheel, the good balance, the softness of the sea motion" (soupless dans le passage à la mer).
It seems that I got it right. Those characteristics they talk about and a good speed, especially in what regards light wind sailing are my top sailing priorities, in what regards sailing performance.
Of course, I want other things from a cruising boat, but those others things are more objective and easy to observe, like a comfortable interior with good storage, a well built and strong boat and a god reserve stability.
Of course, in what regards a comfortable interior I am talking about the 2 cabin boat. On the 3 cabin boat the head is just too small unless you are a small guy, and not a big one, like me.
Here you have a movie with the guy that tested the boat. The boat was (obviously) that one.
Salona 38 : un Croate astucieux et plaisant
Closed Thread
Currently Active Users Viewing This Thread: 7 (0 members and 7 guests)
THE Yacht Builder List T37Chef Boat Review and Purchase Forum 27 10-04-2015 02:38 PM
Cruising sailboats for sale welch Cruising & Liveaboard Forum 10 04-25-2012 06:20 PM
Noob wonderings and questions about sailing, life at sail and sailboats Vans General Discussion (sailing related) 49 06-20-2011 01:18 AM
A List of ALL sailboats made with layouts? Myblueheaven Boat Review and Purchase Forum 8 10-08-2010 12:32 PM
Failure to Navigate - interesting post on Panbo Blog & from the NewsReader Mass Bay Sailors 0 12-11-2006 07:15 PM
