Interesting Sailboats - Page 166 - SailNet Community
 1272Likes
post #1651 of 6763 Old 11-11-2011 Thread Starter
Do you know Saffier daysailors and week-end cruisers? They are well known in Europe since the smaller one won last year the European boat of the year contest. Saffier is a small Dutch shipyard specialized in high quality daysailors and weekend cruisers.
The boat are classic in appearance but have a modern bulbed keel and a spade rudder, are light and made with modern materials. The wooden old loock is just that, a look
The one I like more is the classic 10m week-end sailing boat that really is a beauty:
[IMG]http://i804.photobucket.com/albums/yy322/Paulo_Carvalho/Saffier_Sc10
m_009.jpg[/IMG]
The boat is light and has a high D/B ratio (it needed to have with that narrow hull) and contrary to what one could except is not boring to sail, just take a look at this movie from a sail test from Zeilen magazine :
MOVIE:
Saffier Sc 10M - Sport - Video - Zie.nl
Technical specifications Sc 10 m.
length 10,00 meter
width 2,50 meter
draught 1,13 meter
total weight 2,4 ton
keel weight 1 ton
mainsail 23,5 m2
jib 15,2 m2
light weather Genua 19,8 m2
gennaker 58 m2
spinnaker 52 m2
post #1652 of 6763 Old 11-11-2011 Thread Starter
Lecture for the weekend:
"HINTS AND ADVICE
on rigging and tuning
of your Seldn mast"
http://www.c-yacht.com/upload/files/...igging_ENG.pdf
This is a quite complete manual. It is a Selden one but what they say applies to most masts.
post #1653 of 6763 Old 11-12-2011 Thread Starter
Some very rich guys have the good taste of having big beautiful sailboats instead of motorboats and they like to race. Take a look at these beautiful movies:
But you don't need to be rich to have a lot of fun sailing (theses guys are crazy). Beautiful traditional boats:
post #1654 of 6763 Old 11-12-2011
jppp's Avatar
That Last video is fantastic! That is pure sailing joy
1985 C&C 35 MK 3
jppp is offline
post #1655 of 6763 Old 11-14-2011 Thread Starter
A post about a really extreme boat, a narrow one, a boat that is commercialized in America, is designed by an Australian and is made in Singapore: the Admiralty 30 OD.
The boat has a deep draft and a very strangely designed bulb. I think that it is designed to creates an up-force and that helps the boat to plan sooner.
This movie was made with a a Swede one, imported by a local racer. He have been racing it with success. Jimmy Hellberg was close to win with it the big class in the Round Gotland offshore race (2th) one of the biggest races in Sweden.
He says about the boat:
"It's pretty damn funny when you sometimes can keep the same speed of a 50fter in a small 30-footer ."
I'm used to plan and sail alone, as I sail a lot of surfing and the IOM (radio-controlled boat). I think that sailing should be fun, easy and inexpensive and does not involve as many people. Because then becomes increasingly complicated. After having taken some bigger boats I got tired of constantly pick up the crew and found the Admiralty 30 - a perfect boat is really fast even though you are alone or with two sails.
The narrow hull cleaves efficiently waves resulting in a very comfortable ride, even in rough seas, and the long foredeck makes it surprisingly dry back in the cockpit. The hull has almost no form stability, the stability is provided by the deep and 700 kg heavy bulb, making the boat heeled a lot initially but then the boat starts to get a lot of RM and ends up to be very stiff.
the boat is easy it to sail with littlet work. It has a self-tacking furler jib, fixed bowsprit, gennaker instead of spinnaker, mainsail with a fathead and without back brace ...The boat is completely focused on racing and Jimmy has already sailed Gotland Runt with it.
There is hardly a cabin but there is enough space under the deck to take a nap and get shelter. It is never boring as in a larger boat whenthe only thing to do is often just sitting on the rail. Here you are constantly active.
Because you can raise the keel and the rudder is in a cartridge the boat can easily be trailed.
The boat is extreme but fantastically exciting to sail and I think you get a lot of boat for the money.
Technical characteristics
LOA 29' 11" 900 cm
LWL 27' 11 851 cm
Beam 5' 8" 173 cm
Draft (keel down) 7' 2" 220 cm
Draft (keel up) 2' 4" 71 cm
Displacement 2,425 lbs 1,100 kg
Ballast 1,543 lbs 700 kg
Sail Area 430 sf 40 sm
Spinnaker Area 612 sf 53 sm
SA/DSPL 30.63
It uses as auxiliary just a small outboard and that will give it plenty power.
The boat price in the States is $51,995.00-
post #1656 of 6763 Old 11-14-2011 Thread Starter
Originally Posted by G1000 View Post
Take a look at Yrvind demonstrates his boat. Ocean crossing on micro-cruising boat is just crazy stuff!
I had missed that one. Obviously Yrvind gives a lot of thought to each detail and this boat has good materials everywhere, lots of carbon.
While I was looking at it I found this one with Bris, its older boat, a much less researched one to my eyes, but that nonetheless had taken him and is Girl first from France to Ireland and then from France to Terra Nova (New found land).
What I really found delicious is the way he found to transport the boat
post #1657 of 6763 Old 11-14-2011 Thread Starter
They had already shown a sketch but these are the first realistic drawings of the Dufour 36 performance and it looks a very promising boat. It looks beautiful to me
Technical Specifications
LOA : 10,99 m
LWL : 10,21 m
Beam: 3,61 m
Draft: 2,20 m
Weight: 6,4 t
Ballast/ratio: 1,9 t / 31%
Main sail: 40,6 m
Genoa (114%): 31,5 m
The boat with a beam of 3,61m and a 31% ballast ratio, with all the ballast down in a bulb down at 2.2m, is going to be stiff. 31% does not appear to be a lot but that 31% would correspond to a much bigger number if the boat had instead a non bulbed fin keel with a smaller draft.
With a similar keel and with the bulb 25cm up (less 25cm of draft) the Jeanneau 379 has a B/D ratio of 26,5%. No, it is not the Jeanneau that has a bad B/D ratio. On another thread with some basic calculations I estimated that ratio would roughly correspond to the same GZ of the Catalina 385.
It really is the new Dufour that will be a very stiff boat. I hope they will not change those numbers
post #1658 of 6763 Old 11-15-2011
Dufour 36e
Hi Paulo
That dufour 36e looks like a real beauty.
Any idea when they are planning to make it available and pricing?
My calcs show the following:
D/L - 168 - will be a good light wind performer
SA/D - 19.2 - fairly low compared to Salona 38 which is 26.4 ...
B/D - 29.7 - this what my calculator shows but I am sure that AVS will be high given the depth of the keel and the bulb
L/B - 3.04 - moderate beam by modern standards
Draught - 2.2m - may be too deep if you are planning to use it as a performance cruiser - I am sure that the standard version will be around 1.95
There is definitely space for a 36e in their lineup given that they have the 34 e and the 40e is the next one up in terms of size.
I like the position of the galley ( not a bow to stern layout) as well and the fact that they are offering it with 2 berths as opposed to 3.
All the best
David
daviid is offline
post #1659 of 6763 Old 11-15-2011
Frederick32 is offline
post #1660 of 6763 Old 11-15-2011 Thread Starter
Originally Posted by daviid View Post
Hi Paulo
All the best
David
Hi David,
You are right, there are some error in those numbers: As you say with that Ballast and Displacement the D/B ratio would be 29.7%. Let's hope that the error is in the displacement that I find high for a performance 36ft.
Regarding to the sail area numbers you give I think there is a mistake. The SA/D for the given sail areas is 21.29 and not 19.2. Besides that boat has a small genoa (114%). With a 140% Genoa those numbers are going to be bigger.
The boat will be presented at the Paris boat show (December). They did not tell anything about the price.
This one will be in direct competition to a new Salona, a 35ft that is going to be presented at the Dusseldorf boat show (January), with Elan 350 and First 35.
Closed Thread
Currently Active Users Viewing This Thread: 5 (0 members and 5 guests)
