Interesting Sailboats - Page 174 - SailNet Community
 1272Likes
post #1731 of 6763 Old 12-02-2011
blt2ski's Avatar
Was looking at a local freeby rag, 48north.......local tartan dealer's add had something that said what I thought "new28", along with the normal other Tartans......looked online......interesting little 26' boat to say the least! now will it sell etc.....
Tartan Yachts Article
Going back to the express 37. There are a few of them here in puget sound. One, Declaration of Independence. or DoI won the 48north best of the top 25 yearly for about 5 or 6 maybe 7 yrs running. Others also won a lot of races too. The DOI disappeared. Not sure if Brian still owns it, or retired her.........Very fast boats.
Marty
She drives me boat,
I drives me dinghy!
blt2ski is offline
post #1732 of 6763 Old 12-02-2011
blt2ski's Avatar
then another tartan/c&c new boat
C&C Yachts Article - Introducing The New C&C 101
Hopefully maybe sorta kinda another NA builder will start building some neat designed boats eh!
anyway, late here on the left coast of NA, so how is tomorrow working out for all the rest of the 22 or 23 times zones ahead of me in the world?
marty
She drives me boat,
I drives me dinghy!
blt2ski is offline
post #1733 of 6763 Old 12-02-2011 Thread Starter
Marty
Thanks Marty,
Yes, it looks to be a very nice daysailer, fast and beautiful and it seems that it is only the first of a new series and that bigger boats will follow:
The Fantail Series is the first new model development by Jackett Yacht Design and Development for Tartan Yachts. The Fantail Series is available in three configurations; The DS (Daysailor), WE (Weekender), and the ST (Sail Trainer). All three feature classic good looks, “sit in” not “sit on” sailing, efficient high performance and a “green” sailing experience.
The hull form is a contemporary shape without extremes, designed to deliver predictable and rewarding performance. She has a fine entry forward with plenty of hull volume in the topsides to properly balance the full aft sections. Through her mid body the sections are vee'd for a sea kindly motion.Running aft the sections are broad and flat for great stability and off the wind performance. The freeboard must be carefully balanced to provide adequate sitting headroom below, a dry ride on deck and exceptional good looks.The Fantail strikes the perfect balance. The Fantail is not a “retro design” or bare bones, white-knuckle race boat, but rather a well-mannered, high performance, contemporary design with classic lines.
post #1734 of 6763 Old 12-02-2011 Thread Starter
marty
Olé!, this one seems to be made for you Marty.
Very nice boat with impressive specs! A truly modern design.
Designer Comments
From the bottom of her lead keel bulb, to the tip of her carbon fiber mast, the new C&C 101 is designed and built to accommodate the discerning sailor. The C&C 101 offers a hull design that is built to maximize performance on the water and incorporates the most advanced boatbuilding technology in the market.
An ergonomic deck layout with a wide open cockpit and an easily handled sailplan eliminates the need for an army of crew and guarantees to put a smile on all those who sail her.A functional interior to meet the needs of overnighting and distance racing eliminates parasitic weight, minimizes maintenance and guarantees maximum time on the water.
The all new C&C 101 is fast, fun, and functional.
The C&C 101 hull is designed to maximize overall performance without trending to any extreme, creating a boat that offers exhilarating performance on all points of sail. Her nearly 11 foot beam offersexcellent form stability and in conjunction with the 6'6” bulbed lead keel provides the stiffness to support a sail area to displacement ratio of 25.8.
With a BPA modified epoxy infused hull and deck, optimized uni-directional e-glass laminates, and synthetic hull coring, the 101 is the stiffest, lightest and strongest hull structure available in her size range amongst production builders.
The 101 features a fractional carbon fiber mast, carbon fiber rudder post and retractable carbon fiber bow sprit.Co-engineered by C&C Yachts and SP Systems, the world leader in composite engineering and materials technology....
...The retractable carbon fiber bow sprit and masthead asymmetrical spinnakers ensure exhilarating off wind performance while making the sailplan easily manageable when cruising or shorthanded.
Below decks, the new C&C 101 offers refined luxury in line with her pedigree.Lightweight composite components combined with varnished cherry cabinetry and laminated curved trims provide a spacious and comfortable interior while minimizing weight. Bulkheads are attached to hull, deck and interior components using engineered adhesives and epoxy resins; adding stiffness to the hull structure without adding weight....
Aerospace quality composites, modern construction techniques and careful attention to detail afford the 101 with an interior arrangement that belies her performance capabilities...
Tom McNeill, C&C 101 Designer
I hope they can make it affordable because this just seems to be a very interesting boat
The only thing I don't understand is the tankage. This boat with a super sailing performance will only need the engine as an auxiliary and a 18hp diesel engine needs very little fuel to keep running. I don't understand why this boat needs a 75L fuel tank. A 35/50 L tank would be more than enough and those extra 40L would be better employed in water tankage. 113L of water seems a bit short to me.
Design Dimensions
LOA.....33'0” (10.0 m)
Beam.....10' 11-1/2”(3.34 m)
Draft.....6'6”(1.98 m)
Displacement......8100 lbs (3674 kg)
Capacities
Fuel.....20 gallons (75.7 l)
Water.....30 gallons (113.6 l)
Auxiliary.....18 hp diesel saildrive
Berths.....6
Sail Dimensions
Sail Area.....671 sq ft (62.3 sq m)
Mainsail Area.....399 sq ft (37.06 sq m)
100% Foretriangle.....272 sq ft (25.27 sq m)
Bridge Clearance.....54'6”(16.61 m)
Ballast/Displacment......40
Displacement/Length.....136
post #1735 of 6763 Old 12-02-2011 Thread Starter
This time Golias beat David, but just by a little bit
I am talking about the ARC rally where the 93ft Maxi racer Med Spirit (ex Bols) beat by about 1 hour the cruiser/racer Rayon Vert (a Pulsar 50ft trimaran that had already circumnavigate while cruising).
The 17 guys crew on the Maxi had finally managed to beat the 5 guys crew (father and son, more three friends) on the trimaran, that lead most of the race.
Some Images of the 2003 93ft canting keel Med spirit, and a movie:
MOVIE:
Bols Maxi - YouTube
The Gunboat 66 Cat and maxi Rothmans racing boat have already arrived and VAQUITA, the 40ft Aquilaria racer is also very near, leaving the rest of the boats way back.
Some thought about the first to arrive: All the monohulls that constituted the first pack (far away from all the others) were racing boats, two big maxis and a small 40class racer. The two multihulls that had a similar performance were cruiser/racers, being the Gunboat 66 a luxurious cruiser, while the Pulsar 50 offers a good but more spartan accommodation.
http://www.worldcruising.com/arc/new...ID=173629&src=
http://www.worldcruising.com/arc/viewer.aspx
post #1736 of 6763 Old 12-02-2011 Thread Starter
May I also call your attention to Optim'x, a French X-40 very well crewed that has made a great race and it is now on a strategic position to a very fast finish, overtaking several much bigger boats?
World Cruising Club Arc fleet viewer
I think that among small performance cruisers this is going to be the first to finish beating a British First 40.
The X 40 is yet on the line of x yachts, but it will be replaced soon by a faster and more modern boat, but as it is, it is a delightful cruiser with all amenities and interior comfort while maintaining a very good sailing performance.
post #1737 of 6763 Old 12-02-2011 Thread Starter
Well, that one is out of topic, but it is so beautiful and frighten I had to share it with you. It is about sea and boats and remember us that we all sail in small boats and that the sea can be huge
post #1738 of 6763 Old 12-02-2011 Thread Starter
We have already talked here about the Pacer, a very interesting South African boat (race and performance cruiser) that has started a world wide expansion. It has already dealers in several European countries.
The boats are very well designed and have an interesting price.
Some interesting videos, this one about fast sailing (the better comes after the middle):
And this one about the 400. I have already posted about the boat and it is the one that I find more interesting for cruising. The boat has a good interior with closed cabins and a warm ambiance. Great stability on a fast boat.
post #1739 of 6763 Old 12-02-2011 Thread Starter
Pacer are great boats but as all boats it has a limit and when you really push the envelope....
post #1740 of 6763 Old 12-03-2011 Thread Starter
Beautiful movie. Don't miss this one
A sail celebration: Old and new boats, young and old sailors all together sharing sail pleasure in Seattle, USA.
Closed Thread
Currently Active Users Viewing This Thread: 6 (0 members and 6 guests)
