Interesting Sailboats - Page 531 - SailNet Community
 1272Likes
post #5301 of 6763 Old 12-02-2013 Thread Starter
Benoit Marie crossing the finish line on the mini transat
Arrivée de Benoît Marie - 1er Décembre 2013 por minitransat
"I never had given up...I did not knew I had won.....I pushed my boat more than ever, all the time"
It seems we have a deserving winner and one that nobody would expect to win this race, a true outsider, one whose best result had been 4th in a minor race. I guess we have a new contender for the mini class races Now he would not be an outsider no more.
post #5302 of 6763 Old 12-02-2013
Re: Interesting Sailboats
Can one explain me in which conditions a staystail will give extra speed when the asym is up? Or is it just because of the very long bowsprit making the distance between fore- and mainsail too big?
robelz is offline
post #5303 of 6763 Old 12-02-2013
EricKLYC's Avatar
Re: Aureus XV
... impressive and somewhat stark all at the same time, and far too much reliance on systems (impressive machinery space, though) As to the tool storage (and knives).. very trick and clean but only good for those specifics.. hope there's room somewhere for a regular toolbox.
Of course it's all moot anyhow, the price on this baby must be something else.
Too bad Google doesn't do audio translate yet.
I fully agree. A blue water cruiser should first be simple and efficient, with good back-ups in case of failure of all the gizmo's. Also the galley and saloon/nav configurations don't seem seaworthy to me.
Otherwise this presentation is no less, no more than a good commercial talk, so the images mostly speak for themseves. The extra valuable information is:
* Only available in two cabin version, both with en-suite heads/showers;
* The saloon configuration can be changed;
* Self tacking or 105% solent;
* Teak deck or easy maintenance imitation (as shown);
* Last but not least:
- 1.200.000 € full option ex VAT (carbon/epoxy hull, deck; carbon mast/boom, 4D sails, hydraulic systems, genset + hydrogenerator, dishwasher, multimedia, airco, etc., etc.)
- or from 800.000 € ex VAT for a much more basic version (glass/epoxy, aluminium boom, Hydranet sails and without the rest of the above).
So even with the Euromillions jackpot in the pocket, I would personally re-think a lot about this kind of yacht before considering even the ARC.
Best regards,
Eric
Faster and MrPelicano like this.
EricKLYC is offline
post #5304 of 6763 Old 12-02-2013
EricKLYC's Avatar
I think you’re right Robelz, at least considering asymmetric spinnakers and code sails.
Because the relatively small staysail can only add efficient sail area and give extra power if there’s enough distance between the luff of the mainsail and the spinnaker.
This only works with a (long) bowsprit. Without this, the bigger spinnaker and mainsail are too close to each other. The airflow between them is very much slowed down, because the upwash from the mainsail is fighting the downwash from the spinnaker.
The staysail between them would then not only be inefficient (little airflow) but also disturbing this slower an therefore more delicate laminar flow, which is essential for the power of the mainsail.
Mini’s also carry swinging bowsprits that can bring the tack of the asymmetric upwind. Not only to catch the upwash of the main earlier (= stronger and under a better angle), but also to produce a more leeward and thus weaker downwash from the spinnaker.
In this case less is more, because the delicate laminar airflow between spinnaker and main is less slowed down, making a staysail between them even more efficient.
With a symmetric spinnaker things are of course very different. Especially dead downwind when these sails are much more efficient on boats that don’t benefit from gybing downwind for an optimal VMG. But then there’s no more laminar flow, so almost no interaction between the sails and therefore also no added value for staysails.
Best regards,
Eric
Faster likes this.
EricKLYC is offline
post #5305 of 6763 Old 12-02-2013 Thread Starter
It would not add much if you are cruising but will add something if you are racing. It has not to do with the long Bowsprit because on Figaro II they do the same (as in other boats). For what I can understand they don't use it in very strong winds neither in very light ones. They don't use it also when they are trying to go as downwind as they can. They use it in all other conditions even if some use it more than others. Some movies will give you a better information:
This one is not a good example he is just showing off
These are good examples:
Pelicano, what you say about this?
Edit: I did not saw Erick post about this subject. I do not agree that the use of a staysail with a spinnaker in what regards racing is only useful on the mini racers but on the mini racers, or in any boat with a big spinnaker pole, it will be more effective. Well, I don't know any racer with a pole as big in proportion with its size as a mini-racer so Erick is right in pointing that it is specially useful on those boats.
post #5306 of 6763 Old 12-02-2013 Thread Starter
Re: Aureus XV
Best regards,
Eric
I would not agree with you on that one. The boat can be sailed solo with all those electronic and hydraulic controls but can also be sailed the old way, manually. You can have more (sail at the touch of a button) but still you can sail the way all the others boats sail, manually. So only gains nothing to lose. I would also point out that those systems are used on maxi yachts (100ft) for many years now and have reached a very good degree of reliability.
sure the boat lacks hand holds but that is a boat with a very high degree of customization so that would not be a problem.
Regarding not doing the ARC on this one I hope you are kidding. This boat as I have said can work with hydraulics and electric engines but can also be sailed manually as a back up. It even has a self tacking stay sail. This boat is a carbon boat, very strong and with a huge stability. Eric, this is a 15 m boat with over 12 000kg od displacement a B/D ratio of 35% almost all of it in a torpedo at 2.60m . I am quite sure it is a very seaworthy boat not only to do the ARC but to go anywhere.
Click on the red dots and you will see that the boat is not just talk but the specifications are as impressive as the price
Wild luxury yacht - The Aureus XV sailing yacht presentation
If I was very rich this one would be on my short list.
post #5307 of 6763 Old 12-02-2013 Thread Starter
Light vs Heavy Displacement monohulls
I have found this article so interesting and so according with my own thought that i will post it fully. It was written by Aurélien Poncin the founder of Aureus Yachts:
Light displacement versus Heavy displacement sailing yachts is an old and passionate debate in the monohull offshore cruising world (Luckily this debate is long gone when it comes to multihulls).
First of all, let me tell you what I mean by “Light displacement”, or “Heavy displacements” hulls, yachts or designs, and what exactly will be compared in this post:
In both cases, I assume boats are properly built, and especially the composite parts. Achieving a proper building and reaching the optimal mechanical properties to weight ratio for the composite mix you use (fiber, resin and core material) requires a lot of skills, experience, tools, researches, tests and above all care for “the state of the art spirit”.
Producing state of the art offshore yachts requires curiosity, as technologies are evolving quickly, and a passion for sailing of course. A properly built heavy displacement sailing yacht will always be a better offshore yacht than a light to medium displacement yacht built without caring for details and/or with bad processes…and vice versa.
When it comes to safety, I assume that both light displacement and heavy displacement yachts are well prepared, and carry a full safety inventory that matches the ISAF recommendations. The first safety is the sailor’s care for safety. Wearing an adequate inflatable life jacket when on the watch, a harness together with a reliable safety line, a multi purpose knife and a personal MOB device (alarm + AIS) makes any boat safer for offshore cruising. The preparation and a good knowledge of the boat are also very important.
Now, to give you a precise idea of what I call “light” and what I call “heavy”:
A typical heavy displacement 50 feet monohull offshore cruiser weights 18 to 20 tons.
A typical light displacement 50 feet monohull offshore cruiser, with the same level of equipment, weights 12 to 14 tons thanks to carbon/epoxy composite and T-shaped keels.
Today’s offshore racing sailing yachts are “ultra Light” displacement yachts. For instance, the extreme IMOCA’s 60 footers , that run the Vendee Globe, weight under 8 tons.
For more than 2 decades now, offshore sailors are debating “light vs heavy” and strangely the dominant argument of the heavy displacement enthusiasts is Safety.
I say “strangely” because the obvious and main reason to go for heavy displacement hulls today is because of the bigger inside space that can be offered and the big amount (and weight) of equipment that can be put on-board (generator, washing machine, air conditioning, water maker, etc.).
As you will discover in this article, light displacement yachts, when properly built by skilled and carrying craftsmen and properly equipped, are now as safe as heavy displacement sailing yachts, can be almost as comfortable and carry an impressive equipment inventory…and they are much faster.
As the passionate builder of the Aureus XV, you might argue that I have a strong bias in favor of light displacement hull designs, and of course you would be right. I believe light displacement sailing yachts are the best fit for demanding offshore sailors, and my point here is to illustrate why, with facts.
This being said, it’s also important to notice that whatever your choice is, none of those philosophies can, alone, make a great offshore sailing yacht. There are great boats, properly conceived and manufactured in both categories.
It is crucial to look for a builder that is coherent, masters the composite technologies and cares about all the details involved in the construction, and there are a lot. The best way for this is to visit the yard and talk to the technicians.
There is nothing worst than a light to medium displacement design that ends up weighting 10% or 15% more than the architect’s and builder’s optimal target, by lack of care or skills. Those boats are usually bad performers, uncomfortable yachts, and less safe (the center of gravity always suffers from such a non predicted weight gain).
Keep in mind that such designs won’t tolerate laxity or approximation from the builder. Being 2 tons heavier on a heavy displacement design is also bad, but the effect on the behaviour and safety of the boat won’t be as bad as on a lighter boat.
I see a boat as a long chain of choices to be made that must remain coherent with the initial choice of displacement type. Each piece of equipment is chosen not only for it’s general quality, reliability and fair price, but also for their compactness and their weight (or the weight they allow you to save elsewhere on the boat).
A “state of the art” boatbuilder, after he has chosen the design, sets a realistic target of weight and develop a coherent and balanced yacht keeping those targets at the center of any construction steps. There are now luckily many materials and technologies that offer the same quality, resistance, reliability and durability for less weight. Those materials and technologies allow builders to offer boats that are very well equipped and still light. Here are the most common and popular ones:
The infusion process, when done well, considerably reduce the amount of useless (excessive) resin in any composite part. In comparison, the way it was done 20 years ago, and is still done in some traditional shipyard is pre-historic. The pre-preg technology goes even further, pre-impregnating all the fibers with just the sufficient amount of resin.
Carbon fibers and epoxy resin allow builders to manufacture lighter, stiffer and more durable hulls, structure and deck. It’s even more true for masts and rigging. The result is a need for a less powerful, thus lighter engine, less demanding in Gasoil. It’s a virtuous circle.
New batteries (gel or Lithium-ion technologies) and renewable energies
sources on-board allow builders to put less battery weight, while maintaining a high capacity for a good electronic installation and modern electrical comfort equipment. A Hydro-generator, under sail, and solar panels at mooring can produce a lot of energy. On a well-conceived boat, it allows to reach a high level of comfort without having to run the generator too often (reduce the amount of Gasoil to carry).
A careful selection of each piece of equipment, and accessories can lead to another saving of a few hundreds (yes hundreds!) kilos.
During the last decade, more and more light to medium displacements sailing yachts have participated to offshore rallies and they are now overtaking heavy displacement yachts in most of the events, such as the ARC. Of course, light displacement yachts trust the winnings and they have proven to be as safe as their heavier competitors in offshore conditions.
Here are 14 key facts to help you make your mind, or remake it…
Safety at sea:
#1:
Though they have usually a keel ratio around 40%, which is high, the center of gravity is usually higher on any heavy displacement yachts than on good light to medium displacement sailing yacht. This is due to the slightly deeper T-Shaped, , keels of the light to medium displacement.
When it comes to safety, know that the lower the center of gravity of the boat is, the better. The center of gravity is very important when the boat is brought to extreme angles (above 90°) as the lower the center of gravity is, the more chances you’ll have not to capsize (we’re talking about really extreme conditions here, that can be avoided with a serious weather analysis).
It means a well designed and properly built light displacement sailing yacht will perform better and be as safe in hard conditions. By the way, the center of gravity both vertical and longitudinal of your boat are precious data to collect.
Comparison heavy and light displacement yachts – center of gravity for the boat (blue points) and the keel (green points). Those are two typical designs.
The light displacement is a 13 T (Keel 4.8T – Draft 2,95m) Aureus XV Absolute, fully equipped for offshore navigation. The heavy displacement, on the left, is based on an average 50 ft heavy displacement central cockpit, weighting 19 T (Keel 8T – Draft 2,35m)
I must say that when comparing two stability curves, heavy displacement yachts will prove to have a better stability between 30° and 120°. It means their weight will reduce the amplitude of movements. It’s an advantage of heavy displacements, the disadvantage being a lower speed. But the curves also show that at threatening bank angles, the light displacement will offer a higher stability (capsizing at a higher angle and being easier to redress).
Finally, the stability in the common angles (0° to 35°) is quite close for both design. To sum it up, both designs offer a very good stability in common angles, Heavy displacements will be more stable (less amplitude and slower movements) in the uncomfortable zone between 40° and 90°, but will lose their advantage in critical angles, above 120°.
Stability curves. Comparison between the curves. In blue the heavy displacement (the one from the drawings above), in Red the Aureus XV Absolute. Both designs offer a nice stability in the common angle. The heavy displacement stability is better in the “unusual angle zone”,between 30 and 110°, due to its superior weight. But the light displacement will offer a better stability in the “critical zone” where it’s about not capsizing, or recovering from capsizing, due to its lower center of gravity.
#2:
In tough downwind conditions, when the boat is running with the waves, heavy displacement sailing yachts will be caught-up by waves more easily, due to their reduced speed potential. That will affect the steering reactivity, which is not good in hard conditions (note that the term “hard conditions” is relative.
A professional offshore sailor will be just fine in 8 to 9 Beaufort, whereas some people will define “hard conditions” as a wind above 6 Beaufort, probably 5 when sailing upwind).
#3:
Both heavy and light displacement yachts can equally benefit from fully centralized maneuvers at the helm station (automatic reefing system, electric or hydraulic furlers, electrical winches, etc…) thus allowing crew members to stay attached in the cockpit when conditions are tough.
#4:
Speed is also a safety issue. When faced with the imminent arrival of hard conditions, speed allows you to get away as fast as possible or reach a shelter.
Speed and sensations:
This is the tipping point. A light displacement sailing yacht is a much better performer than a heavy displacement one, both in terms of speed and sensations.
#5:
Light Displacement yachts are faster, the sail area/displacement ratio is more important giving the boat more power. Light displacement yachts offer less resistance to water (reduced “wet surface”) and their hull designs are less asymmetrical, meaning a light displacement design will create less rolling downwind. It’s an important point to consider, since downwind is what offshore sailors are looking for when planning trips.
#6:
When it comes to performance and balance, Light displacement yachts’ T-shaped keel are much better than the traditional long shoal fin keels usually fitted under the heavy displacement hulls. The downsize is that they have a bigger draft (the center of gravity of the keel is as much important in its efficiency than its weight). If you want to solve that issue on a light displacement yacht, go for a lifting keel.
#7:
Light displacement monohulls can sail to descent speed in light winds, where heavy displacement monohulls will have to use the engine propulsion. It means you need to embark and burn much more Gasoil and will be sailing less often. I think this is a very important point pleading for light displacements.
Generally, many things on a heavy displacement must get heavier to get the same level of resistance or reliability as the light displacement yachts. A heavier anchor, a heavier mast, heavier rudders, heavier keel to balance the heavy structure and equipment, and so on. This is a vicious circle.
Comfort on board:
#8:
Heavy displacement hulls generally offer more living space as comparable length. To get the same level of equipment and space on a modern light displacement hull, the solution is to go for compact and clever accessories. Their draft is also generally lower (60 cm in our example), meaning you can go closer to the beach.
#9:
Heavy displacement sailing yachts are generally slower and less comfortable downwind. But in return, they can provide an improved comfort at helm station. The reduction of the boat’s windage is not a real concern on heavy displacement yachts, and a lot of them offer central cockpits with hard tops structures. The aesthetic is not really modern, but the result is a dryer helmsman in agitated condition.
Basically, if getting a little wet in tough conditions is a central concern to you, a heavy displacement is what you need. I really consider this as a comfort issue, not a safety issue.
A light displacement sailing yacht’s cockpit is as safe as the cockpit of a central cockpit, but definitively exposes the skipper more to water projections and wind. I find those conditions thrilling and rely on a modern, very comfortable and light full weather Gore Tex® gears, but others are OK to trade the thrill for a dry place under heavy conditions.
#10:
Light displacement sailing yachts tend to roll less downwind.
#11:
Light displacement sailing yachts above 50 feet can now benefit from a lot of equipment without having to embark tons of fuel and dozens of heavy batteries. Modern batteries offers 2 to 5 times more disposable energy than traditional lead batteries and their lifecycle is 2 to 3 times longer. And wait for it: They are lighter, at comparable capacity.
With integrated hydro generators, light yachts are now rewarded with an easy and durable energy source while sailing and the fact that they sail faster allow them to reach an incredible autonomy at sea. A single very low drag hydro generator, such as a Watt and sea hydro generator can produce up to 500W at 8 knots, and you won’t see the difference in your speed. Have a try of the Aureus XV absolute and you will be amazed by how effective a modern sailing yacht can be in terms of energy consumption and production.
Price and value:
There was a time, in the boat industry, where people said: you can estimate the price of a yacht looking at its weight, and this was quite coherent. This was correct when all builders and brands were stuck with the same materials (Basic Fiberglass and poor quality Polyester). Since everybody was using the same materials, the heavier the boat was, the more raw material was included, the higher the cost. So naturally, heavy displacement yachts were higher priced and considered as the “premium or luxury solution”.
But now, carbon fibers, titan and new technologies are available on the market and allow major gain in weight…at a relatively heavy cost. So this old wisdom is not right anymore. Now you can reach the same mechanical properties at half the weight.
A carbon hull costs more to (properly) produce than a heavy displacement hull, even twice as heavy. A multiplexed DC cabling is half the weight of a traditional DC cabling but also costs three times more. Gel batteries cost twice as much as standard lead batteries and Ion-Lithium batteries 10 times more.
#12:
Today, to offer the same level of comfort and equipment as a heavy displacement sailing yacht, a light displacement sailing yacht must be built in carbon/epoxy using vacuum infusion (or pre-preg) process. This is the only possibility to counter the weight of equipment such as Generators, descent fridge and freezer, dishwasher, water maker, hydraulic and electric manoeuvres, etc… So a state of the art offshore cruising light displacement sailing yacht will be more expensive to build than a heavy displacement yacht.
#13:
On the other hand, carbon/epoxy hulls are much more durable than Polyester or Vinylester hulls. A remarkable light displacement yacht using carbon/epoxy offers, contrarily to what is generally said, a much better durability than a traditional E-glass (fiberglass) using polyester or vinylester. This value in time is to be considered. To learn more about resins or fibers, check out our post: Polyester vs Epoxy and Fiberglass vs Carbon.
#14:
Light displacement offshore sailing yachts have considerably reduce their dependence to combustion engine or generator. It reduces the need for Gasoil consumption, isn’t that good news for environmental concerned sailors ?
Most of the heavy displacement sailing yachts brands keep using the same materials as 20 years ago (Fiberglass, Polyester resin and plywood).
In the meantime, materials like carbon and epoxy have made their proof on hundreds of sailing yachts’ laminate, they are now totally reliable and allow innovative builders to produce much faster, safer and durable yachts. I really think that a “state of the art” modern light displacement sailing yacht is the best fit for offshore sailing, even though the appearance of a good old heavy displacement keeps on reassuring some sailors.
I think a lot of brands are very conservative both in design and construction because they are used to it, and because a lot of customers are also used to those good old materials and design. They assume their qualities are better, since they are used for years on good quality yachts, and they assume they will naturally last longer. Well, that’s kind of wrong ! A properly built epoxy hull will automatically last longer and with better performances than a Polyester hull or deck, plus you don’t have to fear any osmosis any more.
I hope this plea for lightness will resonate and encourage skeptical sailors to give a try to well-built light displacement offshore sailing yachts, for more sensations.
Please feel free to disagree or comment, for the sake of the debate.
Thanks for reading,
Aurelien"
bjung and EricKLYC like this.
post #5308 of 6763 Old 12-03-2013
Have you heard of T-Yachts? They are not new but they are new to me.
T-Yachts Germany auf der Interboot 2012 - T Yachts
Specs of the 34 are similar to a JPK 1010. I love the interior. They also have a 38 and soon a 42...
robelz is offline
post #5309 of 6763 Old 12-03-2013
Re: in which conditions a staystail will give extra speed when the asym is up?
Well, the are in a different situation, going upwind with the Spi. I was thinking on reaching courses with the Asym as often seen in Minis and more seldom on other boats (sometimes on Class40s, never(?) on IMOCAs)...
robelz is offline
post #5310 of 6763 Old 12-03-2013
robelz is offline
Closed Thread
