Interesting Sailboats - Page 581 - SailNet Community
 1272Likes
post #5801 of 6763 Old 01-24-2014
grumpy old man
Re: Interesting Sailboats
Paulo:
I find your comment that a wave piercing type bow can have more volume forward for a given LOA (I assume) very interesting. Could you please demonstrate that in some definitive manner. Because, I've been thinking about that since you posted the comment and I just can't see how it works without going to some silly distorted shape.
What do you have in mind? And you can skip the vague generalities and stereotyping.
Bob's Blog ....
bobperry is offline
post #5802 of 6763 Old 01-24-2014
capt vimes's Avatar
Re: Reversed bows.
The Hydroptere comes from the past (1994) and it is a design that has been continually upgraded. Both amas (lateral floaters) have already inverted bows and as all new contemporary racing trimarans, the development project previews also an inverted bow on the main hull as well as a rigid wing. As you know the project has run out of funding on the last years and that is what explains the delay in upgrading the boat.
Some pictures, the first one comparing the existent with the project from some years ago and the last one with the last development:
I hope they found the money to go ahead with the new boat that should be miles ahead from the older one. In fact the new boat makes the previous version look quite old
oh - i hope that they get their fundings as well... incredible what they achieved!
btw - their amas look like they were taken directly from some waterplane and screwed to a slender monohull...
and please do not get me wrong - while i see the merits of wave piercing bows in race boats, i do not see them in cruisers...
as mentioned in the other thread, without massive water ballast, all those ocean racing monos are prone for a nose dive - and i think you cannot disagree with that.
capt vimes is offline
post #5803 of 6763 Old 01-24-2014 Thread Starter
Paulo:
Bob maybe I did not have been clear and its good that you ask since it helps clarification. I did not mean that regarding LWL but regarding Hull length that is normally measure at the deck (well it seems not anymore). What happens his that when an inverted bow is used on a modern boat, hull length at the deck level is not reduced but the bow, instead of coming down almost vertically or very slightly backwards, extends itself forward at water level. that results in an increased volume.
post #5804 of 6763 Old 01-24-2014
grumpy old man
Paulo:
I think you are confusing LOD Length On Deck with LOA Length Over All.
As I see it:
LOA is just that and it doesnt matter what you do to the bow.
LOD would be effected by how the bow is raked.
capt vimes likes this.
Bob's Blog ....
bobperry is offline
post #5805 of 6763 Old 01-24-2014 Thread Starter
Paulo:
As I see it:
Here the most used dimensions regarding lenght are Hull Length, LOA and LWL.
The Hull length is not necessarily the LOD since many times the transom is bigger than the deck. What I mean is that when you use an inverted bow the Hull lenght that normally is measured from the beginning of the bow on the deck (where the stay is fixed) will not be measured from there anymore but from the forward tip of the bow, even if for design purposes, regarding the deck, rig and boat interior what counts is LOD or the interior space in the case of a very inclined bow.
For a given purpose you will not be designing a smaller boat on the deck and interior space when using an inverted bow instead of a vertical or slightly inclined one, so in fact you will get more buoyancy using an inverted one.
This was what I meant to say. Of course if you maintain hull length you will have not only less buoyancy on the bow but also a smaller boat not only on LOD but also in interior volume and space and what makes sense when talking about a similar sized boat is interior space not LOA.
Better with a design. Here we have the same boat that has originally an inverted bow:
If a more traditional bow was used the bow buoyancy would be smaller for the same LOA:
post #5806 of 6763 Old 01-24-2014
MrPelicano's Avatar
Re: European boat of the year: Saphire 27
The Django 6.70 was a remake of a previous boat (new hull) and a boat more limited on the program and sailing potential. The Saphire 27 just blew their minds with the performance in light wind. Look at the video of the boat testing and you will see the boat outsailing everything, including the bigger performance cruisers. The poor finish regards the interior and it is not particular to this boat but common on boats pointing more towards absolute performance.
This type of boats, narrow with a very high B/D ratio are more expensive to build than beamier boats with a lesser B/D ratio. The efforts on the hull due to the ballast are bigger and the hull has to be stronger. The boat also includes a carbon mast top rigging and good sails and all that is very expensive.
I believe the testers new what they were talking about when they made those remarks about the boat having a good price. There is nothing more expensive than top performance
Multitalent Saphire 27 im Test - Yacht TV - Segel Videos von Europas größtem Yacht Magazin
It would be interesting to see a performance comparison between the Saphire 27 and the J/88, as the boats are less dissimilar than the Saphire 27 and Seascape 27. While the J/88 is a slightly bigger boat, both designs appear optimized for all-around conditions. I don't have time right now to compare the numbers, but I bring it up primarily because the price for a J/88 is quite a bit higher than the Saphire 27, and it doesn't have a lifting keel, making transport and storage more of a hassle.
I suppose we just need to get used to the fact that the price of high performance boats will continue to rise, just like everything else (except most peoples' salaries, which in the U.S. continue to shrink). In the EU, one must deal with VAT, as well, which makes things even more challenging.
One alternative is to shift construction to China and other low-cost countries. But then, I think it is very important to maintain a yacht building industry in Europe (and the U.S., of course). And building quality boats requires a great deal of skill. And people with such skills ought be compensated properly, in my opinion (with all due respect to skilled boat builders in China and Taiwan).
We deal in lead, friend.
MrPelicano is offline
post #5807 of 6763 Old 01-24-2014
grumpy old man
Paulo:
That cryptic illustration proves nothing. I wouild have to see how much deck each example had forward and some sections thru the area.
If you drop the "weave piercing (which I doubt) bow and just use a straight stem i.e. plumb stem, you can flare the deck out more and gain a lot of volume.
No, for a given LOA, as measured in the standard method, you DO NOT get more volume forward with a wave piercing bow. You get less and that is the whole point of the shape.
I've been drawing reverse bows for years.
Bob's Blog ....
bobperry is offline
post #5808 of 6763 Old 01-24-2014 Thread Starter
Paulo:
That cryptic illustration proves nothing.....
It seems pretty clear to me. At red you have the extra volume that is added with the inverted bow.
It seems we do not have the same opinion about this.
post #5809 of 6763 Old 01-24-2014
grumpy old man
Paulo:
I have a little time this afternoon. Let me do a quick sketch to try and illustrate what I am saying. I think perhaps like a few times in the past that you and I may be saying the same thing in different ways.
I'll do a sketch.
Bob's Blog ....
bobperry is offline
post #5810 of 6763 Old 01-24-2014
grumpy old man
I think this sketch represents what we are talking about.
With the conventional bow profile I get 15.62& more area in the bow section.
I chose a section that would be representative of the area in question. The rest of my proportions are intended to be reasonable approximations of the actual shapes you would encounter.
slap and capt vimes like this.
Bob's Blog ....
bobperry is offline
Closed Thread
