Interesting Sailboats - Page 584 - SailNet Community
 1272Likes
post #5831 of 6763 Old 01-26-2014 Thread Starter
On Design
Originally Posted by robelz View Post
Wide (and flat)
- is slow in low winds
- is slower upwind (and usually isn't able to point as high as narrow boats)
- able to plan downwind (and then way faster)
- is more stable in what regards heel
- has more space inside
Narrow
- is less harsh in wave movement
- has less wetted surface and therefore faster in the light
- points higher and faster
- heels a lot
If you consider ocean traveling with the tradewinds (most of the time downwind) and do not care of a light and simple interior, the wide french performance-cruisers are your choice. If you are going mainly upwind and looking for a traditional wodden interior you might look for a more traditional boat.
In neither case you should take a fat (but not wide&flat) cruiser like a Bavaria or a Beneteau: These are made for living, not for sailing...
I agree with most but big generalization like that are dangerous. For instance a narrower hull shape like the one of a VOR 65 is able to go faster planing downwind than an Open60, even if they had 65ft. The same with many other boats. Planing downwind has mostly to do with lightness and shape of the hull. The difference is that while on a narrower boat you will have to have a crew to have it in perfect balance, a beamy boat (Open 60 type) is much more forgiving, so forgiving that it can do that on autopilot, but it also has more drag and is therefore slower.
Of course, you are talking about boats with similar weight but it is convenient to point that as well that the wet surface is mostly a consequence of weight (and design of keel and rudder).
Also to point out that the situation were narrow boats are more effective is upwind with considerable sized waves. You are right when saying that normally a narrower boat can be faster in light wind but that difference can be pretty marginal and when the beamier boat is considerably lighter (and that happens many times) it is not always the case. Going upwind with considerable sized waves is where narrow boats really have a big advantage, even heavier ones due to wave drag that is much bigger in a beamy boat than in a narrow one.
Also in what regards Bavaria and Oceanis series (or any other main market boat) I do not agree that they are for living, since they sail pretty well, as well as in most cases older performance cruisers, but I agree that on their design program, living, interior space and cost have a bigger influence on the design criteria.
Regarding fast performance narrow boats, more than to the French performance cruisers I would look for the Danish, American or Italian ones, boats like the J 1boats, Luffe, Xp or NM yachts.
EricKLYC likes this.
post #5832 of 6763 Old 01-26-2014 Thread Starter
Re: Interesting Sailboats
Originally Posted by Jaramaz View Post
This I do not agree with. Sweeping generalizations, as I see it. Robelz view is the rather old fashion view that many "old salts" (who owns narrow boats) use to claim.
Any meaningful comparision must have some common ground, point of reference. Otherwise one compares apples with bananas.
My personal experience defies RobelZ statements:
My boat is about the size of 12 m x 4 m, quite fat then. In the area we are sailing there are many long and narrow boats, as Safir, Smaragd, Wasa 55, Omega 42 and so on. In light winds we are usually faster, maybe with an exception for light downwinds. We usually can point higher, still go faster than the narrow ones (a bit of a chock for the Safirs, I can tell you, these are famous for very high pointing ability).
When the wind increase, speeds start to approach hull speed, then the longest waterline usually dominates, as expected.
What regards heeling stability, one usually talks about
- initial stability
- final stability
Initial stability is stems mainly from form stability, ie the shape of the boat where a fat boat has an advantage. On the other hand, many narrow boats are more or less intended to sail heeling, and has often a pronounced final stability, which is not as pronounced on a fat boat. Fat boats are often intended to be sailed with just a minor heeling.
The statement is often used in the debate in one or the other form, usually naming some mass produced boats (but I have heard it about many other boats as HR elder generations, Vindö, and so on).
It is of course incorrect. In the case of Bavaria and Bene, they have both models that are fast and can compete with many others, both manufacturer also produces slower boats.
/J
yes I agree regarding wide generalization but I believe that what Robelz said implied boats with the same weight.
What is your boat?
post #5833 of 6763 Old 01-26-2014
blt2ski's Avatar
Paulo, The Jeanneau has a base price of 120K US$. So if the Bavaria is teh same, I am sure some of the lack of difference is getting the boat transported from Germany to to the US shores. From that standpoint, the 349 is the better deal $$ wise here.
I am sure I would end up at about 150-170, as I would probably add the performance pkg to name a few things, along with some electronics, initial epoxy coat the bottom and bottom paint. Then some of the dealers add things like a commission kit, Anchor, fenders, pfds etc.
Marty
She drives me boat,
I drives me dinghy!
blt2ski is offline
post #5834 of 6763 Old 01-26-2014
No, Robelz did not sate anything about the weight. We all know, one can use may parameters for boats, none will capture all important aspects.
Even if we assume weight, the generalizations have not sufficient basis: It is well known that narrow boats have to have more lead as they have less form stability (which in itself is a generalization, agreed).
Narrow boats have their charm, without any question. I have had several . Fat boats have other charms.
But I do not see the need for sweeping generalizations, looking down at this or that brand. We all make our choises, most often these are comprimizes.
/J
Jaramaz is offline
post #5835 of 6763 Old 01-26-2014 Thread Starter
/J
I think you are being too harsh with Robelz's post. I implied he was talking about boats with the same weight and as a generic generalization it does not seemed bad to me.
Yes, we can say that generically a narrow boat needs more ballast or more draft or a much more efficient keel to compensate the superior stability given by the hull form stability of a beamier boat, if both boats have about the same displacement and speed.
For understanding your comments and since you have given your boat as a reference it is useful to know what boat you sail. What is your boat?
post #5836 of 6763 Old 01-26-2014 Thread Starter
Alliage yachts
Long go the days where Alliage were one of my preferred aluminum 41ft sailboat. The brand had abandoned the smaller cruising market and today his smaller boat has 45fts but the really are pointing tho bigger models.
They have two ranges, one with non ballasted centerboarders (like OVNI; Boreal or Allures) and another one that they call Azzuro, with a lifting keel. All the boats are beautiful and well designed by Berret Racoupeau, kind of "chic" voyage boat, but not less effective. I still like them a lot even if regret they finish making smaller boats:
Who would say this baby has already 14 year's old:
The 41 had already a two rudder set up.
Have a look at the Alliage 53
and to their two lines (very nice boats):
Azzuro 53 Voiliers De Voyage Aluminium De La Gamme Azzuro
Today they belong to the Alubat group, the ones that make OVNI and its their "luxury" brand. These ones are supposed to be "yachts" already while the OVNI are just sailboats
post #5837 of 6763 Old 01-26-2014
I think you are being too harsh with Robelz's post. I implied he was talking about boats with the same weight and as a generic generalization it does not seemed that bad to me.
I could have written a book with 300 pages but wanted to give a short overview. Of course a lighter boat will in most times be faster than a heavier boat, a racer should poind higher than a cruiser, a carbon/kevlar sail will be more effective in any regards than one made of dacron...
Taken into consideration he asked for a passagemaker I think I got the most important points.
robelz is offline
post #5838 of 6763 Old 01-26-2014 Thread Starter
New 24 hours solo sailing record
and it goes for a sailor on its 1st year on multihull at top level, Armel Le Cléac'h on Banque Populaire with an average of 28.2K and 677nm.
Second record on a row. Here on the last one, the Med record:
Let see if he can beat also the record of the "Route de la Découverte"
post #5839 of 6763 Old 01-26-2014 Thread Starter
Thomas Coville circumnavigation record attempt
And Coville keeps pushing trying to recover the delay. Can imagine going like this for weeks?
Sodebo - Tour du Monde 2014: Ambiance "humide... por sodebo-voile
post #5840 of 6763 Old 01-26-2014
Thank you all who put effort and explained. Every bit helped.
Probably got confused by watching lot of videos, and not sailing enough on different type sailboats. Thanks again.
Osprey 26 is offline
Closed Thread
