Interesting Sailboats - Page 600 - SailNet Community
 1272Likes
post #5991 of 6763 Old 02-04-2014 Thread Starter
Re: Chines
Originally Posted by olianta View Post
May be it works for less rolling when motoring in flat seas, sails dropped.
BTW, do you happen to know what are the cines of river/canal barges, do they look similar to the ones of this Hunter?
Rumen
No doubt they will work for that, also at anchor. In fact that looks like a motorboat displacement hull and that's why canal barges look like that. But it will add drag while sailing upwind and on this one you are right, that immersed chine will do nothing good to make sailing easier since it will be dificult to put the boat on a groove when you are sailing on top of the angle of the chine.
After giving a second thought to what I posted previously and reading all your posts I think that hard chines do not contribute as prevention from heeling. For example would the hard chines on a narrow hull sailboat make it stiffer than the same hull and ballast boat without chines? I don't think so. If caught by a gust the boat will heel past the chines and the latter will create just more drag. I think we saw a similar thing on the Swedish video regarding the Jeanneau Sun Odyssey 409, where at some point it heeled to starboard past the chine. And sailing in the groove on a hard chined boat will be more a matter of perfect sail trim, which is again more likely to be archieved by professional sailors than majority of cruisers.
Rumen
There is little point in used chines on a narrow boat because the boat will sail at the most effective upwind heel point with a lot of heel and with almost if not all freeboard on the water and in that case the chine would be submersed. A little gain would be won regarding stiffness but it would not compensate drag. Only on the transom or very near chines would be of any use on a narrow boat.
Regarding the Sun Odyssey 409 it can effectively sail with a lot of heel before that chine hits the water and be effective. The hull is very different from the one on the Oceanis (or the Hunter) where the chine starts near the bow and goes around all hull. On the 409 it is only on the back of the boat:
Hard chines increase stiffness and if well done it will increase it where it is more useful, at the best upwind sailing heel angle. It helps also in what regards to put the boat in a groove there since it will offer resistance to pass over it. Boats sailed past its optimum heel angle will lose performance.
post #5992 of 6763 Old 02-04-2014
grumpy old man
Re: Interesting Sailboats
If you want to see a very successful narow boat with chines you should check out RAGTIME, a Spencer design. This boat is a downwind rocket and has been winning for about 35 years.
I'll leave it to Paulo to dig up some pics of it.
Bob's Blog ....
bobperry is offline
The Following User Says Thank You to bobperry For This Useful Post:
olianta (02-04-2014)
post #5993 of 6763 Old 02-04-2014
Re: Chines
Then I guess that the chines' effectiveness (without being punished by increased drag) depends on their location, extent of pronouncement and most of all by the angle of heel, the latter being dependant by many other factors. That's why I think that the no chines hulls are more versatile. And versatility is the most practical goal for a cruiser sailboat.
Rumen
bobperry and capt vimes like this.
olianta is offline
post #5994 of 6763 Old 02-04-2014 Thread Starter
Re: Chines
Rumen
On the first part you are going very well...then you messed up
Yes it is easier to design a hull without chines than with chines, I mean a good one with effective chines and it is also true that different hulls will have optimum chimes in different locations but sailing versatility has nothing to do with it.
Both on the Oceanis and on the sun Odyssey the chines will not interfere with the sailing ability till the optimum heel angle upwind is reached. The boat will be less effective past that angle and the chines are not to be passed but reaching that point of optimum heeling those chines will increase the stiffness of the boat and will help to prevent passing it, maintaining the boat on an optimum groove making sailing easier for a beginner or a cruiser on autopilot.
The boat will tell you very effectively when the optimum heeling angle is reached. You really have to try hard to pass over the chine...and you can almost hear the boat insulting your sailing abilities for trying it
That is not the case of the Hunter 40 that has very good chines to improve the boat stability while motoring or just downwind but that will create drag and hull instability at any significant amount of heel.
post #5995 of 6763 Old 02-04-2014
capt vimes's Avatar
I can remember ragtime, but never cared about her hull at that time...
Nevertheless if i look at her hull now, it reminds me strongly on the boats i posted previously - v shaped hull with the chines more or less used as lifting strakes...
capt vimes is offline
post #5996 of 6763 Old 02-04-2014 Thread Starter
Please Vimes, put that picture smaller. It is taken the thread out of configuration.
That hull seems pretty dated to me. If the boat still wins it is because it has not much of a competition. Some fast hulls (for the time) had those chines. Vand de Stadt use them on Black Soo in 1957. I don't think that for many years now nobody relevant is designing a hull with that kind of chines, for performance or for cruising and for a good reason.
post #5997 of 6763 Old 02-04-2014
Re: Chines
Then it means that the chines' purpose is to put limitations on your manner of sailing., acting as rails on a tram - you get punished if you derail, tram gets insulted . Like a modern car that alerts you if you cross the incessant line on the road. Do you think this feature is useful regarding sailing boats in the open sea? I do not want to adjust my sailing to the chines because I do not think they are the final word for optimal sailing.
Rumen
olianta is offline
post #5998 of 6763 Old 02-04-2014
Thank you! This was new for me.
It supports the point that chines matter even on narrow hulls in downwind planing mode. http://m.youtube.com/watch?autoplay=...autoplay%253D1
Rumen
olianta is offline
post #5999 of 6763 Old 02-04-2014 Thread Starter
Re: Chines
Then it means that the chines' purpose is to put limitations on your manner of sailing., acting as rails on a tram - you get punished if you derail, tram gets insulted :..
It seems you really have some difficulty on this. Yes your way of sailing should be adapted to each boat characteristics and not otherwise.
Each boat has an optimum way regarding being sailed effectively. Not all are the same. Some are more effective upwind with more heel, other with less.
If a boat does not only reminds the sailor about the better and more efficient heeling angle but also makes easier to find it and makes difficult bad and less efficient sailing, preventing him to pass that angle it is worse or less flexible than a boat that does not pass any information to the sailor?
Let me remind you that on top of all this that chine increases stiffness at the more efficient angle of heel, making the boat go slightly faster.
It beats me how you can see any of this as negative but I will insist no more, have it your own way
post #6000 of 6763 Old 02-04-2014
Downwind about the lift I agree 100%. Upwind, when heeled, the leeward chine will be underwater most of the time, so it will not work, but I guess this will not be detrimental to the performance on such a narrow hull.
Rumen
olianta is offline
Closed Thread
