Interesting Sailboats - Page 95 - SailNet Community
 1272Likes
post #941 of 6763 Old 05-04-2011
boats in the market at a reasonable price even if the demand is very big on the used market for that boat. Maybe you can find a 2003 boat (that's when the model started) for 150 000 € (that seems to be your budget)
Hi Paulo!
thinking about the future sales price of a used boat is always an interesting issue for me. I won't keep it indefinitely...
Do you think the loss in value of an RM is especially low? How is this in comparison with a Pogo, an Opium, First or other boats? What do you think?
Ulf
myocean is offline
post #942 of 6763 Old 05-04-2011 Thread Starter
Originally Posted by JAndersB View Post
Hi Paulo,
the main reason I do not want to go that road is that I have partially been there already and found a big drawback. Sailing single handed and often with a lot of sail area up for the thrill, modern fat aft hull sections demads twin rudders for control (or constant adjustment of main sail track, which is OK with good crew), and no manufacturer provides that in the boat type you refer to. Only Benetau has started now with the Sense, but as said before they are rather heavy.
Regards,
Anders
Hi Anders,
The Sense is not only heavy is also fat it is not designed to plane and is not very bright upwind (worse than the Oceanis). It is a boat that is interesting but I don't think it is what you are looking after.
I agree with what you say but you are exaggerating a bit and it also depends a lot on the boat. Twin rudders give better downwind control but a well designed hull is also part of the equation. I remember reading a post of a luffe 43 owner saying that he had sailed his boat (with all the family) inside doing 16/17k with fingertip control:
- LUFFE YACHTS - News
Yes it will be slightly better with two rudders but a modern hull with the draft brought back is very stable downwind. The other problem with a single rudder is to lost control sooner at the limit and broach the boat more easily . But the new Dehler have (like your boat) a high ballast/displacement ratio and has a much deeper ruder. I don't think you will have any problems controlling this boat with a short crew or solo (of course the limits will not be the same but I believe you can sail very fast solo on this boat).
I also believe it will be harder to broach than your boat (deeper rudder about the same RM, a more modern hull) and I believe your boat does not broach easily. A Opium 39 a 1200 RM or a Pogo have a much bigger need regarding two rudders because they are more beamy boats. The Dehler 41, like the First 40 or the Salona 41 are much narrower boats and that has nothing to do with the broad stern. Broad sterns have to do with beam brought aft, even on a narrow boat.
For me the bigger problems with these new generation "classic" fast sailboats (First, Dehler, Salona) has to do with the draft of the rudder. I would not have a 2.00m draft boat with one of those rudders. The keel and the rudder would be at almost the same level and that seems imprudent to me.
Take a look at the rudder on the 43CWS on a 2.0 m draft boat: way up regarding the keel.
Now take a look at this drawing with the Dehler showing the 2.40 and 2.20 (standard) keels. They have a short draft keel with 2.00 with the same ruder. Can you imagine it? That's the same with the First and the Salona: on the 1.98m keel version the rudder and the keel are practically level. Weird looking
in what concerns me, I mean the keel and rudder at the same level
post #943 of 6763 Old 05-04-2011
JAndersB's Avatar
Hi Paulo,
as I said I have been there and tried that with previous models from my Dehler. Some of them had as deep rudders as keel (almost 2 m) but it did not help. The Dehler 43 CWS rudder is also rather deep and big, but as you pointed out not to that extent, but mainly due to big ballast ratio and especially due to narrower aft section, is almost impossible to get it to round up.
We discussed this before Paulo and it is always good to give things a second thought . As I said before, boats with low ballast ratio and a lot of form stability can be very nice and fast in the right conditions (as was even my Beneteau Oceanis 40) but conditions are very seldom so stable as when these boats excel, or you need a very active crew on the sheets (and rail).
I agree, there are shades of heat also in hell , but basically, twin rudders and planing hulls is what I am looking for.
Regards,
Anders
JAndersB is offline
post #944 of 6763 Old 05-04-2011 Thread Starter
Hi Paulo,
Regards,
Anders
Anders, I would be the last to dispute that preference because it suits me well but I insist that the shape of the transom and the beam brought back has a lot to do with downwind increased stability even if two rudders can be a plus.
What I was trying to say is that in what regards hull design, shape of the hull, beam brought aft and large transom this is the first Dehler with this hull configuration. I don't think that any experience with other Dehlers is relevant in what regards downwind sailing.
If you go to the site and see the different hull shapes from the other Dehler you are going to understand what I mean.
This boat belongs in that regard to a new generation. More are coming, the Xp 38, the Max 11 and I bet it is going to be a standard from now on for this type of boat.
The Following User Says Thank You to PCP For This Useful Post:
JAndersB (07-25-2013)
post #945 of 6763 Old 05-04-2011 Thread Starter
Paulo, I take your point and if I was doing a succession of 80nm hops I'd also think the extra couple of knots would be important.
Reality is however that I'm a dawdler, a slowpoke, someone who enjoys getting to an anchorage and hanging around for a few days.
I think that is why we (that is all of us , not you and me) have these long term discussions on the subject of the "perfect" cruising boat. Need to do 80nm every day for ten days ? Hell yeah, I'd want the fastest possible ride as well. Do a lot of day sailing ? Give me speed. I wanna boogie.
Lets face it, I spend far more time slouching about , reading, listening to music, eating and drinking than I do actually sailing. Now I don't want a complete slug and yes I admit that our dear old Raven does not move in under 5knots of wind and really needs plus ten to get along little doggy (dogey?) but if I can passage make on the basis of 5knts average, reality is I am content.
To have sailed a true performance yacht up to Port Stephens in those conditions would have been seriously exhilarating with a crew of four or more. For a crew of two old farts like us it would have been exhausting. Were we doing the same up north near the Whitsundays then the fast boat would have been a gem not doubt, in the seas we were in not so much.
Cheers
A
Hey Andrews,
I agree with everything you said except with the last part. On this thread you find lots of different boats for lots of sailors with different needs and tastes. I like the differences and the different types of boats. If I could I would have several and one of them with be a classic one, a fast boat from the 30's.
Regarding this:
I don't think you are right. See, a performance boat has a huge stability that is needed to carry a lot of sail. If you push the boat and go really fast yes it could be a fun but sportive and tiring ride. But reef those sails go at less 1 or 1.5K (and even so faster than other no performance boats) and that superior stability (RM) will give you a no thrills fast and efficient motion with plenty of directional stability and little heel.
As an old Dragonfly solo cruiser (more than 70 year's old) said to a friend of mine when he asked him if that fast trimaran was not too much for him: "Well, I can go slower, but you can't go faster"
post #946 of 6763 Old 05-04-2011
EricKLYC's Avatar
May be this illustrates what Paulo and Anders mean with easy sailing on light boats with lots of stability:
Dailymotion - Petit surf Ã* 20 nds - une vidéo Sports & Extreme
Nobody on the rail, no stress, just a concentrated driver and one crew winching up to the sharpening apparent.
Enjoy!
Eric
EricKLYC is offline
post #947 of 6763 Old 05-04-2011
yus
Hello Yus,
Welcome to Sailnet and particularly to this thread
It would help to know the boat you are living in. You are used to that space and makes no sense in changing to a boat with less space.
Hello Paulo,
Thanks for you reply.
The boat we own at the moment is a Baba 35 (Perry design). It is very confortable for us and very safe, but we took decision to change type of boat and have two cabins to give a better accomodation to some friends. I think the new concept of boat, which is represented by the Azuree 33, Should be more roomy inside compare to my Baba. The Azuree uses the full lenght and it is also more width. I think we should appreciate the difference in terms of space. What do you think about?
The Elan 350 is nice too but I prefer the Azuree, I think is more roomy inside.
Regards, yus.
yus is offline
post #948 of 6763 Old 05-04-2011 Thread Starter
Originally Posted by yus View Post
Hello Paulo,
Regards, yus.
Hei Yus, I had a look at the Baba 35 and it is a nice boat with a cozy interior, but certainly a slow one
Baba 35 Review : Bluewaterboats.org
Regarding the Azuree 33, it is very unusual to me to say that I think the slower boat is better but it is what I think in your case. I don't think the problem would be the interior space but the loading capacity. The Baba has a big load capacity. It can carry 75 gallons of fuel and 100 of water. Well on the Azuree 33 the fuel tank dimension is not very important because it is a very good sailing boat that can sail with very weak winds, but the water is indispensable for having the autonomy for staying some days atanchor. The Azuree only has a water tankage of 160L and that's really not enough for living aboard. the Elan 350 has and identical problem. I think that this will be the biggest problem, not the interior space.
I really think that the Oceanis 37 (346 L of water) or the new Jeanneau 379 (336L of water) are a more realistic option.
Anyway these would be incomparably faster than the Baba and the Jeanneau will have a performance version that will be even faster (and faster than the Azuree 33). These boats will also have a much bigger freezer and a lot more storage space and probably can carry almost the same load of the old Baba 35.
post #949 of 6763 Old 05-05-2011
I think for living aboard a good solution for this issue which is actually a weight-issue is a watermaker. Use the water tank as buffer and for safety but use the watermaker for the continuous demand. However the energy for this needs to come from somewhere, e.g. from the watt-and-sea generator. So its going to be expensive...
myocean is offline
post #950 of 6763 Old 05-05-2011
yus
Hei Yus, I had a look at the Baba 35 and it is a nice boat with a cozy interior, but certainly a slow one ....
... I think that this will be the biggest problem, not the interior space.
Hello Paulo,
I think the Azuree is more strong and safe than the Oceanis 37.
About the poor water storage capacity I think it should not be a big problem because I intend to use a water mater.
My biggest problem concerns the living space in the galley and cabins, but your reply satisfies me.
Could you make a comparison between RM 1050 and the Azuree 33?
Mainly based on safety and internal space.
Regards,
Yus
yus is offline
Closed Thread
Currently Active Users Viewing This Thread: 76 (0 members and 76 guests)
