03-12-2010
That's definitely a pilothouse motorsailer. The mast on the Pearson 30 is significantly taller and the Pearson 30 displaces less... 39' vs 31' and 8320 vs. 10000.
It is going to be a bit tender, since the ballast is only 38% for the P300, vs. 42.8% for the Pearson 30.
BTW, I wouldn't consider the Pearson 30 a true bluewater cruiser, and the P300 is probably less seaworthy, due to the lower ballast ratio, relatively shallow draft, and the large pilothouse.
