03-15-2010
Originally Posted by sailingfool
Many small boats have a short line hanging off the backstay, with a clip on the end, which serves as a topping lift. The problem with this arrangement is that it really can't be used when the mainsail is raised.
To me one of the impartant features of a topping lift is that having one in place makes reefing the main a lot easier, as you don;t have the boom swinging around in the cockpit during the reefing process.
Do your own lift: add a strap to the top of the mast, a small block at the aft end of the boom, and a cleat near the forward end of the boom. Run a piece 5/16 line from the strap, through the block to terminate on the cleat.
If you have the space in the boom, you could duplicate your main halyard to use as a topping lift, then you have a backup halyard.
I believe SF means the mast, not the boom. I prefer leading the topping lift from the end of the boom to a block on the mast and then down to the mast base, since you generally have to go to the mast to raise, lower or reef the main. Also, if you've led the halyards aft, you can lead the topping lift aft as well.
