-   Boat Review and Purchase Forum (http://www.sailnet.com/forums/boat-review-purchase-forum/)
-   -   Survey swing keel in trailer (http://www.sailnet.com/forums/boat-review-purchase-forum/63187-survey-swing-keel-trailer.html)
davidpm 03-24-2010 01:23 AM
Many swing keel boats are offered for sale on the trailer. Has anyone come up with any tricks to tell if the swing keel mechanism, keel itself and trunk are OK or likely to be damaged?
sailingdog 03-24-2010 08:18 AM
Visual inspection is a good start, if you can get under the boat well enough to look up into the centerboard trunk. Looking for staining will often give you a good clue about conditions, as a damaged trunk or rusting pivot pin will often have some external signs of the damage or corrosion.
Unfortunately, to really see what is going on, requires lifting the boat and lowering the swing keel or centerboard.
MikeAR 03-24-2010 09:31 AM
I was going to ask the same thing... thanks for the thread and the response!
Going to try to see a boat that will likely need some repairs this weekend - early model Catalina 22 on its trailer.
danr620 03-24-2010 09:55 AM
David/Mike,
I play with a Cipper Marine in my spare time, so I can tell you to at least look at the winch mech and see as much of the cable travel as possible. It may take a light and mirror to see this stuff and maybe remove a cover where the cable goes thru the hull to Keel. If the Keel has fell the front of the Keel trunk could be damaged. These are things to look for.
good luck
Dan
sailingdog 03-24-2010 11:43 AM
Of course, the problems will vary by boat model...so asking about a specific model will generally get a better response. :) Don't know the Catalina 22, but I'm sure someone else will chime in about it.
MikeAR 03-24-2010 01:11 PM
Thanks guys!
Many of you may recall, I've been looking for quite a while, and even put it on hold for a bit. The mirror is a great idea!
I've been told of a Catalina Mk I (unknown exact year till I see the transom), on what appears to be a factory trailer from the pictures. Dirt aside, it's difficult to tell much from pictures. I've got a firm first right of refusal, so I'm getting a bit excited about the possibilities.
