-   Boat Review and Purchase Forum (http://www.sailnet.com/forums/boat-review-purchase-forum/)
-   -   Comfortable, Fast, 30 feet (http://www.sailnet.com/forums/boat-review-purchase-forum/63333-comfortable-fast-30-feet.html)
CaptinRedBeard 03-29-2010 06:51 AM
Looking to purchase a cruising sailboat with good speed. The boat has to be solid enough to cruise off shore, A wide boat with a good layout for comfortable overnight stays. The boat will be cruising interisland on my days off and will have to be able to make good time so that I'm not stuck on the water when I should be at work. I'll be working on a budget and hope that I can pick something up in working condition around 30k.
what fits these guidlines at 30ft.
Jeff_H 03-29-2010 07:30 AM
To a great extent the terms 'Comfortable', 'wide boat', 'blue water', 'good speed' potential and a tight budget are mutually exclusive. Probably the closest boat that comes to mind would be a Tartan 30. You can buy one of these for around $20K in good shape and then spend the remaining $10K adapting the boat to your needs.
Depending on what you are willing to compromise, boats like the J-28, J-29, J-30, Laser 28 depending on where you live you might also find a Farr 8.1, 9.2 or keel version of the Binks 30, all of which might suit your needs.
CaptinRedBeard 03-29-2010 07:37 AM
Jeff I will look into these boats. Thanks for the knowledge!
sailingdog 03-29-2010 08:35 AM
I'd also point out that generally fast and comfortable are not that compatible... most fast boats aren't comfortable, most comfortable boats aren't fast... especially on a budget.
I'd highly recommend you try and get out on some of the boats that Jeff_H mentioned, so as to get an idea of what you're really looking for in a boat.
Another boat that might fit your criteria is an Iroquois 30 catamaran or a Catalac 8/9M. These are certainly seaworthy little cats, as they came to the US on their own bottoms. They're going to be more comfortable at anchor than a similar LOA monohull and probably a tiny bit faster as well.
kwaltersmi 03-29-2010 09:21 AM
You might consider a few models from S2. In particular, look at the 11.0, the 10.3 and the 9.1. All are available for around $30k and reasonably speedy (10.3 the fastest), reasonably well-built, reasonably comfortable, etc.
CaptinRedBeard 03-29-2010 01:44 PM
sailingdog, my research has confirmed your statement reguarding fast and comfortable which is the main reason for this post. I'm just trying to find the best fit so I can get it right the first time. I'm currently crewing on a 26 ranger (fun little boat) and a Beneteau 44 (an older boat designed for racing). As for cats I have no experience. I'm definatley leaning towards more of a cruiser but a fast one. When it comes to cats is it harder find a slip wide enough? Do the slips usually cost more? In seas 15 foot and bigger are they better or worse than a monohaul?
Kwaltersmi,
Thanks for the info I will look into those boats as well.
P.S. anything larger than 30 feet even by a small amount may not work as the marina's in the area are super strict.
sailingdog 03-29-2010 03:11 PM
The Iroquois would probably work, as it is only 13.5' wide, which means it can fit in many single-width slips... The Catalacs are wider and do have some issues with fitting in a single width slip.
In heavy weather, they handle very differently from monohulls and you have to generally use slightly different tactics. Of course, the best tactic, if you have the sea room to deploy it, is to use a Jordan Series Drogue and hide in the cabin until the weather improves. :D
olson34 03-29-2010 05:55 PM
Ericson 32-2 or E-29 (70's), Ericson 30-2 (late 70's), and Ericson 30+ (80's).
All are great Bruce King designs. A 30 has circumnavigated, FWIW.
L
blt2ski 03-29-2010 06:46 PM
The issue I see with some boats, "IF" you are limited to 30' overall, many of the 30' boats listed, will be 30' on deck, and about 31-32' overall in length. SO you may need to look at boats that are listed as 28' boats. Such as the Catalina 28mk 2 which is just shy of 30' overall. My Jeanneau Arcadia is also 29.5' long, altho listed as a 30' boat. The ericson designs mentioned, many are more than 30' overall in length, and you may need to go to one of the 27 or 28' versions too.
Marty
krozet 03-29-2010 07:57 PM
A Beautiful 1978 Tartan 30!
P.S. - Not my boat, just a nice find searching the web.
