C&C 38 vs CS 36 Merlin - Page 2 - SailNet Community
post #11 of 26 Old 04-01-2010
Dirt Free
boatpoker's Avatar
I am a little biased as I have owned our C&C35 MKIII for 20 years and have found very few boats in its size range which are crossovers (racer/ cruisers) that can out sail it. It also Is comfortable for cruising and has superior joinery and is well thought out as Saildog has described.
The issue of the basa cored hull is really non issue, and btw not all C&C are cored. If it is one of the cored hull, check on its integrity. These cored hulls were made with sandwiched with very thick laminate and have very little problems over the years with water. Top decks is another story. The end grain basla core is what gave it strength and lightness and why the C&C 35 MKIII or C&C 38 MK III will be a turn faster than the CS Merlin in all points of sail Hence the 117 to 126 phrf ratings. The C&C jib tracks are further in closer to the coach roof therefore its pointing ability is better when close hauled than the CS. Another consideration is if the model has a k/c like mine does. If so it has more flexibility in where you can cruise it as well.
As far as the CS being the "best" Canadian Boat built, I would beg to differ with that analysis. I certainly do not put them above the C&C of that era. Both are good boats. There is a reason there are so many of these C&C still around...had the core been a problem that would not be the case.
As in buying any boat a good inspection and survey is the most important determining factor. I would go for a balsa cored DRY C&C before and boat not similarly cared for. Both are good boats. Get the one which was best taken care of and do not be scared off by the general brush strokes painted of the C&C cored boats by the one poster on here.
Dave
My "general brush strokes" are based on 100 surveys of C&C's and 93 surveys of CS's. All C&C's over 33' have balsa cored bottoms according to George Cuthbertson and confimed in every survey of these boats that I have done.
Be the man Sharon thinks I am - wg
I can do that
- wg
Be the master of your own disaster - wg
If you're not laughing, you're not doing it right. - wg
if you can live with the consequences, go for it. - wg
I yam what I yam an' thats all that I yam. - Popeye
boatpoker is offline
post #12 of 26 Old 04-01-2010
Gary M's Avatar
You may well be right for the 36s, the 38s the 41s etc. I am not sure of any of them but the MK 1 and Mk II 35s had solid glass hulls and cored decks. No ifs ands or butts about it.
The 35 MK III is a much different boat and had a cored hull.
Gary M is offline
post #13 of 26 Old 04-01-2010
Dirt Free
boatpoker's Avatar
George disagrees
I can do that
- wg
post #14 of 26 Old 04-01-2010
chef2sail's Avatar
Again my point is that just because they are balsa cored does not make them inferior or suspect as you keep implying. There are plenty of DRY C&C boats and they are superior or equal to a DRY CS was the point I was making. Thats why your comment about the balsa cored hull was superfluous.
I do not challenege your ability to survey or that they are cored, just if it is a sound hul....it is a sound hull...makes no difference cored or not.
Again I DO challenge you statement that the CS is the best Canadian Boat. I beleive they are equal with the C&C being a faster boat in general. Facts seem to prove that.
___________________________
C&C 35 MKIII Hull # 76
Parkville, Maryland
(photos by Joe McCary)
Our blog-
chef2sail is offline
post #15 of 26 Old 04-02-2010 Thread Starter
Originally Posted by boatpoker View Post
The C&C 38 has a balsa bottom (beware) and build quality was highly erratic. Unless its already been done you will have to rip out the entire AC system and start again.
The CS are by far the best built of the Canadian boats but the Merlin has a significant flaw, the liner can separate from the hull around the mast step. The first sign of this shift is in the cut outs under the seat at the starboard settee. If you see fractures in the liner running from the corners of these cut outs go look at another boat. CS almost always t'd the propane locker drain into a scupper line which is unsafe. The Merlin will likely also have solid core copper AC conductors.
This is exactly the kind of information I was looking for. Thanks.
jwreck is offline
post #16 of 26 Old 04-02-2010 Thread Starter
Dave
The cored hull doesn't really scare me. As you said, there sure are a lot of them around for it to have been a serious issue. Besides, my understanding is that the Merlin is also cored. IMO the Merlin looks almost exactly like the C&C 35 MK III at first glance. There are definitely difference though.
jwreck is offline
post #17 of 26 Old 04-02-2010 Thread Starter
Both C&C, at the time, and CS were high quality builders with decent construction techniques and materials. If it is a C&C 38 Mk III, I believe it's got rod rigging, unless it was replaced, and is probably overdue for new standing rigging. Rod rigging can be tricky to inspect and can fail without much warning, unlike wire rigging.
Both should be pretty good boats and fairly comparable in many ways. The C&C is going to be a bit faster, as it is a larger boat with a greater SA/D IIRC. It will also have a bit more room. I like the C&C 38 Mk III a lot as monohulls go...
How are the two boats equipped? How are the prices??
The CS has more electronics. The C&C has more sail inventory. The CS has much greater tankage. The biggest knock on the CS equipment wise is a lack of (I know this will make some cringe) A/C. Living aboard in Texas (for me anyway) requires A/C. The CS is more than $10k cheaper, but is several states away (Florida). I really like the C&C, but it has been sitting neglected, with portlights that leak like a siv for months now. I'm investigating the condition of the CS but I don't have any reliable data yet, just the yachtworld listing. There's also the fact that the brokerage that has the C&C has given me a few reasons to not trust them at all.
jwreck is offline
post #18 of 26 Old 04-02-2010
Maine Sail's Avatar
What facts prove that? The CS's are very, very well put together. As one who initially wanted a C&C, and looked at lots of them from Maine to Florida, and who has surveyed, worked on and raced on many I can assure you that they are great boats but not built to the level of a CS, as Boatpoker has pointed out.
I pulled my meter and very closely examined four C&C's in my search and every one of them had hull core moisture, two of them so severe I wondered how they were even still standing on the keel. I did find one that was dry but the rest of the boat was a basket case. After the fifth one I gave up and began widening my search to other high quality builders.
My sail maker just spent over 40k on his C&C to have the entire bottom re-built. Was in the shop from October until just about three weeks ago. The entire bottom, 100% of it, was re-cored a process that is very, very time consuming as you need to do small sections at a time. Core damage can and does happen, with no core, this can not happen..
The Merlin only has core above the waterline and a vacuum bagged deck construction. These boats were also bedded with butyl tape a process far more time consuming and labor intensive than marine sealants other builders used. This stuff never hardens and has kept many a CS bone dry beyond the 30 year mark. My own CS has over 80% of her deck hardware un-rebeded. I pulled the chain plates this winter to inspect, test and replace or re-install. They are all going back in, as they were still bone dry at 31 years of age, with zero leaks. Part of this success is the sealant choice and the other part is the way CS attached, built & designed their chain plates. There are few builders, at any cost, who attached chain plates the way CS did. This design came directly from Ray Wall who was CS's first designer and the ex chief designer for Camper Nicholson. Camper Nicholson was one of Europes highest quality builders.
The stringers in our boat are glassed to the hull, massive, and are solid fiberglass U-shaped beams with no core to rot. Engine beds are also solid glass with no core to rot out.
The chain plate knees of the CS-36 are made of solid fiberglass, are massive, and are integral to the hull not the bulkheads. The inward flange for the hull to deck joint also covers these knees and creates a solid fiberglass deck at the chain plate penetrations with no core to rot, if a leak developed.. This inward flange covers the entire chain plate knee so no water can get in from the top. This means that in the areas of the knees the inward hull flange is some 12 - 13" deep. The chain plates are not attached to free floating screwed in place bulkheads or even tabbed bulkhead which can rot if exposed to a leak. Inside these knees is a massive ss backing block laminated into place. Every bolt came out with zero issues 31 years after being put in place due to the well thought out sealed design.
The bulkheads are also tabbed directly to the hull and then a 1/4" teak veneer facing is laid over the actual bulkheads. This type of detail yields a very strong boat and also a boat not prone to chain plate leaks and the resulting bulkhead rot. I have never once heard of a CS that needed to have the bulkheads replaced due to rot but there most certainly is one out there somewhere.
Stringers on our boat are also solid fiberglass U shaped beams glassed & tabbed in place. Morris Yachts does the same but at a HUGE cost. The hull also has longitudinal foam cored stringers and an engine bed that also has no wood core in it and no "lag" bolts holding the motor in place,. A hull liner was then added but because of the construction this was not for structural rigidity.
The ice box was factory insulated with poured in closed cell foam giving nearly 4" or more if ice box insulation. 35 minutes a day of running our Sea Frost system keeps the ice box below 40 degrees for roughly 24 hours..
Also, take note of the keel bolt backing plates. The keel bolts are of very high quality and show no signs of any corrosion or rust even at 31 years old. CS used 316 SS and massive backing plates when other builders used standard washers and a lesser grade of bolt.
The picture below is just as I found the knees after being covered for nearly 31 years by teak cabinetry. I was the first to remove these cabinets for the re-wire I am undertaking. There is no sign of leaking, even at 31 years old.
Here's a photo of the underside of the starboard deck. The bolts directly over head are for the genny track. These bolts pass through solid fiberglass with no core and in 31 years have apparently never leaked. They also show no signs of it. You can hardly find a three year old boat with no signs of deck leakage let alone a 30+ year old model. The track is still bedded, as is the hull to deck joint, with factory butyl tape. In the background you can see the hull to deck joint with through bolts 4" on center that is also bone dry along it's entire length.
If you look to the third bolt down from the top of the pic you will see a line in the udeside of the deck radiating outwards towards the deck flange. This is another hidden gem of a detail CS used. It is a core break. This break prevents large areas of a deck fro getting wet as it creates an internal solid fiberglass dam keeping sections of core isolated..
Little details such as the thickness of the veneer on the cabin sole are big issues when it comes time to re-finish. My buddy with an Ericson simply had to replace his entire cabin sole, at a HUGE expense, because there was no room for refinishing with the paper thin veneer they used my Catalina 36 was the same way. CS used a full 1/8" think teak & holly veneer. This can be stripped and refinished multiple times before wearing through. I still have lots of meat left after refinishing in 2008..
There is no perfect boat and all boats are a series of compromises but I do tend to agree with Boatpoker on the CS. Ours has many, many hard ocean miles on her as she was liveaboard cruised for five years from Newfoundland to South America thought the canal and up to Alaska and back. The deck has virtually no crazing and she shows no visible signs of wear and tear, all tabbing is 100% intact and just as it left the factory.
Having built boats, worked part time with a marine surveyor and worked in multiple boat yards I have learned to look at the tiny details that most miss or don't know what to look for. When I first really looked, in detail, at a CS, had not seen many as there were no dealers close to Maine, I was amazed at the high level of construction and the well thought out attention to design, much of it hidden away for no one to admire but the designer and builder. No boat is perfect and the CS's do have some draw backs, namely the use of solid conductor 110v wiring but I am unsure when they stopped doing this or if they ever did.
All that being said the C&C is a great high quality boat, as is the Merlin, so I would base any assessment on current condition & maintenance. My preference, after seeing so many wet core re-builds, over many years, is that I now stay away from them if it extends below the waterline, but I do know of many cored hull boats that are dry..
P.S. I installed some seacocks and a transducer on a C&C 35 MKII and she had a solid glass hull..
______
-Maine Sail / CS-36T
Maine Sail is offline
post #19 of 26 Old 04-03-2010
chef2sail's Avatar
Ha Maine...I was wondering how long it would take for you to weigh in with your perfect boat.
I am humbled by your anaylsis and years of experience. I have only have 30 years of sailing. Having sailed with others on their boats across the Atlantic a few times when younger and some cruising like the 1500 and races to Bermuda and Newport over the years, I realize my qualifications to judge boats may not quite be up to yours or Boatpokers. I have only owned 3 boats, A 27 Tartan....28 Islander.... and my current boat of over 15 years our C&C 35 MKIII. Forgive me for voicing obviously biased opinion. Your finidings about the CS were spot on.
I must have gotten the only good dry C&C made. Funny I moisture tested 4 other C&C;s before I bought this one and none of them had moisture problems at all. And Boatpoker you are dead wrong...not all have basla cored hulls.
I wanted a small racer/ cruiser which was not slow...and was well made. The other boats I had narrrowed it down to before I bought my current vessel..a 36 CS....a 34 Sabre....and a 37 Tartan all had issues. The worst of which was the CS, which you aptly described as having so many small attentions to detail, the PO had destroyed it by putting enough homemade Rube Goldberg contraptions on it that it looked like a Mr Magoo Christmas tree. It really goes to the main(e) point that I was making that it all depends on the vessel you are looking at. Sure you can quibble about boats when they are new about the difference in build quality between an A and a B+ which all four of these boats IMHO were. And some of that build quality translates through the years to longeveity of the boat, but when buying a 20-30 year old boat it all depends on how the boat was taken care of. The CS I looked at certainly did not look like yours under the sole. It was a wreck. As many have posted on here before you need to get a good surveyor...and a thorough survey. I narrowed our choice 15 years ago to these four boats and bought the one in the best condition I could find. I was partial and narrowed it to these four boats as the designers as well as builders had good reputations and built quality boats which fit the needs I had. No boat is perfect..and 15 years ago a turn of speed was important as I was heavily into racing, and the C&C 35 MKIII was very competitive (and still is) yet comfortable for a 3 week coastal trip. Our boat has traveled to New England 15 times from the Chesapeake as well as been to Bermuda and Florida. She has stood up well to the test of time...and really we have constantly improved her with upgrades and new systems as older ones got outdated or wore out. All these should be considered in additon when buying an older used boat, but only after the basic integrity of the boats hull...and engine. Whomever gets our boat when we sell her will get a well maintained upgraded boat. (BTW its hard to think about parting with her,,even though we will go larger she has been part of the family for so long)
We are currently undergoing the same analysis as we are looking for our final boat as retirement is comming in 5 years and we want to cruise to the Bahamas regularly. Speed is no longer the driving force it was 15 years ago, but I dont want a total barge either. We have narrowed our short list down to late 80s early 90s 45.5 Baltic, 44 Hylas, Tayana 42 and 43 Hans Christian Christina. We have looked at some already, but are looking for one which is in as good a condition as the C&C we bought 15 years ago.
That is really the deternmining factor, once you narrow it down to 3 or 4 designs.
Dave
Parkville, Maryland
Our blog-
post #20 of 26 Old 04-03-2010
STARBOARD!!
KeelHaulin's Avatar
I would consider the Baltic or the Hylas; eliminate the Tayana and HC unless you want a boat that is much heavier displacement and not nearly as nimble as your C&C.
What type of moisture meter were you using Maine Sail?
KeelHaulin is offline
C&C 39 Northeast? fsivo C & C 2 02-07-2010 07:39 AM
C&C Buying Archwood C & C 3 11-10-2009 12:55 AM
Who has a C&C 38 Mk 1 CliffRuckstuhl Boat Review and Purchase Forum 1 10-22-2009 07:25 PM
Merlin Rocket Silver Tiller at Salcombe @ Sail World UK NewsReader News Feeds 0 04-12-2006 11:15 AM
Pearson 36 vs C&C 37 dnr Boat Review and Purchase Forum 1 11-16-2002 04:07 PM
