C&C 38 vs CS 36 Merlin - Page 3 - SailNet Community
post #21 of 26 Old 04-03-2010
Maine Sail's Avatar
And some of that build quality translates through the years to longeveity of the boat, but when buying a 20-30 year old boat it all depends on how the boat was taken care of. The CS I looked at certainly did not look like yours under the sole. It was a wreck. As many have posted on here before you need to get a good surveyor...and a thorough survey.
Exactly why I said... (see quote below ) I would always try and buy the best maintained boat you can find regardless of construction details unless those details were big detractors.
All that being said the C&C is a great high quality boat, as is the Merlin, so I would base any assessment on current condition & maintenance.
We are currently undergoing the same analysis as we are looking for our final boat as retirement is comming in 5 years and we want to cruise to the Bahamas regularly. Speed is no longer the driving force it was 15 years ago, but I dont want a total barge either. We have narrowed our short list down to late 80s early 90s 45.5 Baltic, 44 Hylas, Tayana 42 and 43 Hans Christian Christina. We have looked at some already, but are looking for one which is in as good a condition as the C&C we bought 15 years ago.
That is really the deternmining factor, once you narrow it down to 3 or 4 designs.
Dave
I really like the Baltics.
______
-Maine Sail / CS-36T
Maine Sail is offline
post #22 of 26 Old 04-03-2010
Electrophysics CT33...
Originally Posted by KeelHaulin View Post
I would consider the Baltic or the Hylas; eliminate the Tayana and HC unless you want a boat that is much heavier displacement and not nearly as nimble as your C&C.
What type of moisture meter were you using Maine Sail?
sailingdog is offline
post #23 of 26 Old 04-03-2010
STARBOARD!!
KeelHaulin's Avatar
Again; moisture meters need to be used in a very specific way to determine hull moisture below the waterline. I'm quoting a marine survey website (Marine Survey FAQ Dixieland Marine )please review.
  • We own and use an Electrophysics GRP 33 Marine Moisture meter.
    We probably will not use it on the bottom of the boat during a standard pre-purchase survey (unless it is a dry-stored boat). They are useful to assess moisture intrusion into cored decks, or in wood cored transoms or stringers. Most people, including many surveyors, do not understand the workings of moisture meters or the constraints necessary to achieve a reliable reading on a boats hull.
  • Moisture meters for use on fiberglass hulls are essentially radio transmitters/receivers.
    The measurement actually being made is dielectric constant or AC conductivity, which is affected by type and thickness of bottom paint, trapped water in the paint, thickness of gel coat, thickness of laminate, resin/glass ratio, as well as absorbed water.
  • The "Code of Practice for the Measurement and Analysis of the Wetness of FRP Hulls"* specifies the methods necessary.
    These include:
    1. The hull surface must carefully cleaned.
    2. A large number of random 4" x 4" areas of the hull must have paint or other coating removed down to the gel coat.
    3. The vessel should be out of the water at least 24 hours.
    4. Minimum number of measurements must be = approx. one per sq. meter (3.3 feet) or 50-100 on the average 35-40 foot boat.
    * International Institute of Marine Surveyors (1998) Witherby & Co., London, 17p.
KeelHaulin is offline
post #24 of 26 Old 04-14-2010 Thread Starter
So I made an offer on the CS. Fingers crossed.
jwreck is offline
post #25 of 26 Old 04-14-2010
good luck
post #26 of 26 Old 04-26-2010
This is a pretty interesting thread since last year I was shopping for our first boat ever, and after looking at 40 or so boats we ended up focusing on CS36Ts, Merlins, C&C 35-3's and 38-3's. There were some very well maintained and well-equipped Ts, which would have been my overall choice, but my wife hated the cabin and vetoed the type (sorry, Maine). She liked the Merlins best, but on an apples-to-apples-basis they were 20k more than Ts (in our local market).
So we bought a C&C 38-3 :-) I admit I went nuts scrutinizing the boat, and we had a reputable surveyor go over her thoroughly. Metered dry, percussion tests said dry.
I'm a beginner sailor, so I don't really understand what I've bought, yet. Give me a couple years. I admit I liked, with no good reason for it, that the 38-3 has a proportionately bigger main and smaller foresail that most of the masthead rig boats I was considering.
Good luck on your offer. Looking forward to hearing how it goes. I probably can't show this thread to my wife. Don't want her to spend much time thinking about the sleek Merlin interior she's not going to experience.
CatchingUpSlowly is offline
C&C 39 Northeast? fsivo C & C 2 02-07-2010 08:39 AM
C&C Buying Archwood C & C 3 11-10-2009 01:55 AM
Who has a C&C 38 Mk 1 CliffRuckstuhl Boat Review and Purchase Forum 1 10-22-2009 08:25 PM
Merlin Rocket Silver Tiller at Salcombe @ Sail World UK NewsReader News Feeds 0 04-12-2006 12:15 PM
Pearson 36 vs C&C 37 dnr Boat Review and Purchase Forum 1 11-16-2002 05:07 PM
