SailBoat Speed - Page 2 - SailNet Community
post #11 of 14 Old 04-23-2010
Lots of info here. The question is not so simple as it seems. There are many ratios, specifcations, ratings, etc that are used to compare sailboats. If you want to know max speed under power it will be close to calculated hull speed assuming you have sufficient HP. Very close for these boats. Between 5.5 and 6.0 kts. If your looking at these boats the condition of sails, rigging, added weight, and bottom condition are the things to consider.
PHRF is a good gauge of average performance potential for boats with good racing sails, clean bottoms, properly distributed weight, sailed competitively.
Different areas have slightly different rating systems.
Sailboat guys have many ratios and ways to compare speed potential. I'm thinking that stuff is more than you are looking for. Find out what the boat was designed for- racer, racer/cruiser, day sailor/cruiser, ocean capable,
power/sailor, etc. Also, I'm sure guys on this blog will be happy to compare designs for you.
Max
Maxboatspeed is offline
post #12 of 14 Old 04-23-2010
It really doesn't matter that much.
First, neither of the boats you're comparing can be considered fast in any way. Second, you could spend an inconcievable sum of money to make either of these boats sail faster, but they will never be fast. Third, you could spend a lifetime learning to sail a boat fast, so you are at a disadvantage to those that have done just that.
If you are just learning to sail, few things are as frustrating as being spanked by boats that are known to be slower than yours. However, that's exactly what you should expect. Every club has that dude that bought a Bene 10R or C&C115, etc thinking they were a shoe in for the club trophy, only to be outsailed by more experience sailors on "lesser" boats.
My advice is to not worry much about the boats PHRF rating and buy the one that a) seems most likely to suit your use, and b) is in the best condition. Then go out and enjoy the boat and don't worry if some other boat is 10 seconds a mile faster or a minute a mile faster. PHRF ratings have very little impact on how much you will enjoy your boat. They only matter if you race, and then you'll only complain about the rating.
PalmettoSailor
s/v Palmetto Moon
1991 Catalina 36
PalmettoSailor is offline
post #13 of 14 Old 04-23-2010
GeorgeB's Avatar
PHRF is a regression formula based on a boat’s principal dimensional data for the most part. It is not like a golf handicap and it does not take into consideration the condition of the sails, rigging or other gear (like microwave ovens and BBQs). Often you will hear a racer lament that his boat ”doesn’t sail to her number” which means his own boat is slower than indicated by his PHRF number.
Yes, the Islander has a much lower PHRF number, ergo, it should be faster than a C22. However, the Islander is a much different kind of boat. The questions you have posted here are all over the place which is fine for general information, but you need to be much more focused if you are trying to narrow down your boat selection. For example, if your primary criteria is speed, (and money is not much of an object), consider a Melges 24 which is the same size but roughly two times faster than the Islander. The Islander isn’t really a trailer sailor per say. You would most likely need a travel lift or hoist to launch her, which pretty much ties you to a marina that you can dry store and that offers “free” use of a hoist for launching. Can you write down in a single message what exactly is important to you and your wife. What are your expectations and desires? That way I can be more focused and helpful to you. For example: Minivan as a primary tow vehicle? This will eliminate most of the boats out there. Three quarter ton pickup? Not a problem.
GeorgeB is offline
post #14 of 14 Old 04-24-2010
Sailing101,
I'll bet you've lost interest in all this speed jabber. Good advice from Midlife and B. If you're 101, the first thing to learn is that these types of boats are not fast. If you need to get from A to B fast, drive, fly, get a power boat, or even ride a bike. I don't think you care about racing as it is not part of the 101 class.
Learning general sailing principals (101) is necessary to get these boats anywhere near their speed potential. Also, 101 is needed to sail at all.
Evaluating used boats is best done on the water, if possible. That way you can see how she sails and best evaluate sails, rigging, ect.
Good luck with your search
Max
Speed Week Redux Dan Dickison Racing Articles 0 09-27-2002 08:00 PM
The Need for Speed Dan Dickison Racing Articles 0 10-03-2001 08:00 PM
Speed Sailing Overview Dan Dickison Racing Articles 0 05-16-2001 08:00 PM
Hull Speed Demystified Steve Colgate Learning to Sail Articles 0 06-10-2000 08:00 PM
Hull Speed Demystified Steve Colgate Buying a Boat Articles 0 06-10-2000 08:00 PM
