Old 04-24-2010
bellefonte's Avatar
bellefonte is on a distinguished road
Schooners as passage makers
I intend to cruise, live aboard and sail blue water.
Does anyone have advise on this type of boat? I have been attracted to the Ketch rig because of its versatility in heavy weather. I began reading the post on Mahina.com about blue water boats and the steel hull Freya 39 caught my eye. Then I found this, quite by accident:
1987 Corten Steel Schooner (DRASTIC PRICE REDUCTION) Sail Boat For Sale -
Thoughts?
My Cruising blog:
But it's not who you are underneath, it's what you do that defines you. ... Rachel Dawes
Old 04-24-2010
nickmerc's Avatar
nickmerc is on a distinguished road
I sail on charter boats that are schooners. They are great fun, but do require a crew to safely handle the boat. The one you are looking at has gaff rigged sails. You will need at least two people to raise sails safely. If you have an autopilot you are set, if you do not, or do not want to rely on one you will need a helmsman. That's up the three people now. If it were marconi rigged you could get away with one person handling sails if it were rigged well. One other drawback of a schooner rig is you cannot point as high as a sloop with full sails.
The benefit of schooners is you can carry lots of sail with less crew required to handle them safely. You also have lots of options with your sail plan. One thing I really like is in heavy air you can, on a two masted schooner, just fly the stay sail. You will make headway and the helm is balanced since the center of effort of this sail is usually directly over the center of resistance of the keel.
Nick
S/V Blue Bayou
1974 Pearson 30 #517
Old 04-24-2010
bellefonte's Avatar
I see. So, it we have an auto pilot and its just me and the wife, we dont have enough hands to safely manage it?
My Cruising blog:
Old 04-24-2010
klem is on a distinguished road
Schooners have been used for offshore sailing for hundreds of year and the boat looks quite capable, the question is whether it would be a good fit for you.
Gaff rigged boats are a bit different to sail so knowing the difference is important. When raising or lowering the sails, you have both a throat and a peak halyard. Typically, this means one person per halyard although if they are lead correctly, one strong person can do both. As long as the autopilot works and both of you are in good shape, it should not be an issue. Gaff sails don't do as well to windward as marconi sails generally so that needs to be taken into account. Offshore if it is rolly and there isn't much breeze, the gaff will swing around wildly. This means that you have to set a preventer on each boom and sometimes you even need to drop the sails. The lines drawing makes it look like the boat is setup for a jackyard topsail which is yet another level of complexity.
Schooners are sailed slightly differently than ketches due to the distribution of their sail area. Most schooners have some weather helm due to the large mainsail although this specific boat looks as if it might be better balanced than most. Generally, the foresail is the last sail left up and you start with reefing the main, then taking down the jib. On a ketch, you would normally take down the middle sail (main) whereas on a schooner, you take down sails from the ends. Most schooners will sail in a gale under foresail alone or foresail and staysail. The foresail will often be built out of heavier cloth and have heavier gear associated with it for this reason.
I don't see any reason why the boat you listed could not be made bluewater capable. It will take a lot more user input to sail it but it is easily done by two skilled and fit people.
Old 04-24-2010
First, I would ask how much sailing experience you and your wife have.
Also, have you owned a boat previously??
I'd point out that when cruising as a couple, a majority of your sailing is done as two singlehanded sailors, sailing the same boat, since the other will be otherwise occupied—sleeping, cooking, etc.
Also, a steel boat has maintenance requirements that are a bit different from GRP or wooden boats. In many ways, the GRP boats are easier to maintain, and easier for the average person to learn to repair.
A sloop-rigged boat would probably be easier for you and your wife to handle and maintain.
Old 04-24-2010
Freesail99's Avatar
Freesail99 will become famous soon enough
I have to ask, just how much sailing have you done?
S/V Scheherazade
Old 04-25-2010
MARC2012's Avatar
MARC2012 is on a distinguished road
From the looks of it I think it has running back stays,If you are neither familiar with there nor experienced this could be a problem..marc
Old 04-25-2010
wind_magic has a spectacular aura about wind_magic has a spectacular aura about wind_magic has a spectacular aura about
Dog are you saying it is hard to learn how to use a piece of sand paper ?
What are you pretending not to know ?
Old 04-25-2010
Corrosion never sleeps and maintaining a steel boat is more than just sanding away corrosion. Steel boats require very regular inspection and maintenance, where a GRP boat can often be less demanding. Yes, gelcoat oxidizes and waxing and polishing the hull is nice...but the oxidization of gelcoat doesn't really affect the integrity of the hull, just its appearance. Rusting of a steel hull is far different as it can and often does affect the integrity of the boat itself.
Old 04-25-2010
bellefonte's Avatar
Freesail,
after reading the responses, not enough. I'll be looking for a simpler sail plan.
I sure do love the idea of a ketch rig, but again, its fairly complex; more rgging, sails etc. All equating to more expense. Now Im studying an old post by Jeff on Cutter vs Sloop.
Thanks everyone for the input.
My Cruising blog:
New to Sailing, please Help =) xyris Learning to Sail 19 11-17-2008 08:30 AM
Reflections of an Offshore Passage Bermuda Seamanship 4 07-23-2006 08:03 PM
A GUIDE TO OFFSHORE PASSAGE MAKERS (Sailing Vessels) piclarke Crew Wanted 0 05-13-2003 04:43 PM
Panama Passage TakesMeAway Crew Wanted 0 06-30-2001 08:00 PM
An Offshore Training Passage John Kretschmer Cruising Articles 0 05-24-2001 08:00 PM
