Old 06-13-2010
thisiswater's Avatar
thisiswater is on a distinguished road
How to remove non-skid on decks
The boat we're considering has ugly brown skid-prevention-stuff (sorry I don't know the proper name) on the deck and even on top of the cabin. How do we remove this ... it's the color that's bad. Thanks everyone!
Old 06-13-2010
eherlihy's Avatar
Finally found the needle!
eherlihy is on a distinguished road
Options:
  • Sand it with 36 grit
  • A router
  • A machine called the Marine PaintShaver
  • Paint over it with new nonskid
Old 06-13-2010
It may be a 'treadmaster' style of non skid..i.e. a glued on rubber sheet style. While effective and very uniform in appearance when new, it does not age particularly well.
If that's the case unfortunately it has to be scraped off and the remaining adhesive removed with solvents
1984 Fast/Nicholson 345
Old 06-14-2010
merc2dogs is on a distinguished road
Also, a cheap power plane ($20 +/- at HF) works on flattish areas, set the front part of the sole so it sits on the nonskid with the rear part sitting flat on the smooth part of the deck.
in use, DO NOT push down on the nose, light pressure at the rear of the plane is all that's needed.
run in strips till it's gone, then sand smooth and finish as desired.
Large areas will call for a few blade changes along the way.
For areas that have a heavy curve, I've used a belt sander and rapid movement, don't let it sit anywhere because it will form flats that will take forever to fair in.
Ken.
Old 06-14-2010
SailingWebGuy's Avatar
SailingWebGuy is on a distinguished road
Interlux has a video that shows them removing some non-skid. The site is yachtpaint.com - the website of International and Interlux paints. Click the Video Library link.
Don't know if it will help...but it's an interesting video.
My complete refit is taking completely too long!
Restoring non skid decks Petar Gear & Maintenance 9 06-13-2006 04:23 PM
Techniques for Removing Teak Decks Sue & Larry Buying a Boat Articles 0 11-24-2003 07:00 PM
Non skid decks pblais Gear & Maintenance 10 08-19-2003 11:49 AM
Cleaning Fiberglass Hulls and Decks Sue & Larry Gear and Maintenance Articles 0 03-07-2002 07:00 PM
Cleaning Fiberglass Hulls and Decks Sue & Larry Her Sailnet Articles 0 03-07-2002 07:00 PM
