Old 07-08-2010
Valhalla225 is on a distinguished road
Question about this 28' Shannon Cutter
Hello all,
I just joined because I have a question about this boat. Here is the link:
Sorry I can't post actual links yet so you need to take out the space.
h ttp://bit.ly/cFuq7M
I have never purchased a boat and I am still learning about them. I'm wondering about the hole behind the rudder because it doesn't look right to me. I have tried finding pictures of other 28's but I can't find another one of this view. Anyway, it looks like an opening for the prop but it seems more like a gash than a factory design. Could someone explain what that is?
Thanks
Old 07-08-2010
What hole are you talking about...there is NOTHING BEHIND THE RUDDER...There is a PROP APERTURE forward of the rudder, and the prop is in it. This is pretty typical on boats with a skeg hung rudder. .
Old 07-08-2010
JohnRPollard's Avatar
Moderator
As Sailingdog mentioned, that is a perfectly ordinary propeller aperture (in this case, in the trailing edge of a full keel). Nothing to worry about.
Those Shannons are fantastic boats. If you like this style and layout, some similar boats are the Pacific Seacraft Dana 24, and the Morris Linda 28. Might be worth comparing.
Good luck and welcome to Sailnet!
Old 07-08-2010
Ah ok. Like I said I'm new to this, sorry for the wrong terminology
I guess I've never seen that before. Good to know.
Thanks for the info and the recommendations.
Old 07-08-2010
Moderator
No apologies necessary. Ask away. Lots of knowledgeable sailors here willing to help.
Old 07-08-2010
JRP—
Look again, I believe that's a fin keel with a skeg...not a full keel AFAICT.
Old 07-08-2010
Moderator
JRP—
Oops -- right your are, SD.
I didn't even look at the photo. I was just working from memory.
That is indeed a cruising fin keel, with an aperture in the skeg from which the rudder hangs. Good set-up -- just like my boat.
Old 07-08-2010
Just out of curiosity how would a boat like that compare to a Cape Dory 30' in terms of handling and stowage space?
Old 07-09-2010
MARC2012's Avatar
MARC2012 is on a distinguished road
Nice looking boat.marc
Old 07-09-2010
I think the Shannon 28 would probably handle a bit better than a CD30, as it is a fin keel, as opposed to a full-keel. It is also going to be a tiny bit faster, as it has a longer waterline than the CD30, despite being shorter overall. In terms of space, it is probably slightly larger, since it has a 9.5' beam versus the CD 30's 9' beam—and I think that difference will give the S28 a bit more interior room overall.
Another House v Boat Question creedence623 Cruising & Liveaboard Forum 5 05-11-2010 04:25 PM
Cutter to sloop wallm Boat Review and Purchase Forum 6 07-24-2003 12:27 PM
How do you tack a cutter? JeffC_ Seamanship 7 02-22-2003 12:55 PM
Sailing a Cutter Rig Dan Dickison Buying a Boat Articles 0 12-09-2001 07:00 PM
Sailing a Cutter Rig Dan Dickison Gear and Maintenance Articles 0 12-09-2001 07:00 PM
