07-12-2010
Because you just won a large lottery?
Seriously, houses do not vary much in price from used to new. Cars are priced less for used but there are thousands of miles of wear and tear and while there is a saving it is not always massive unless the car has many miles on it. But boats, due to the market glut of used boats, can be purchased for a fraction of the cost of a new one. Even after extensive upgrading you are still many thousands ahead of buying new. For example Yachtworld lists a 2011 model 309 for 109k. The Catalina 30, which it replaced and is very similar, is available in large numbers for anywhere from under 20k to the mid to high 40k range. The higher priced ones are probably in pretty good shape, the lower priced less so. Say you buy a mid priced Catalina 30 and spend about 30k. Spend 10 to 20k over a few years to upgrade electronics, upholstery and fix any issues. You have a boat in pretty good condition for less than half the price of a new one. There is obviously a higher resale with the newer boat but you have to spend more to start with.
And as dog posted, sometimes you can't find what you want in a used boat.
In my case I purchased used in pretty good condition and am modifying to suit what I want as well as upgrading older systems. I will end up with a boat for many thousands less than new and equipped exactly as I want. I am doing all the work myself so will know the boat inside and out.
Brian
Reason: add
