  #21 (permalink)
Old 08-09-2010
hobieman21sc is on a distinguished road
If you want more detailed information about F-24's you should check out the Yahoo Group called F-Boats. Lots of information including discussed the 2 versions of F-24, the Mark 1 with a fixed mast , and the Mark II with rotating wing mast.
I cannot understand why others are shocked that sailing at mid-teen to 23 knots is wet. Of course high speed is wet. My point is that you can sail them slower and they are dry if sailed at 8 knots. You have the choice to sail faster if you want and you have the wind.
If you want lots of interior space, this is not the boat for you. If you enjoy experiencing the beauty of outdoors and prefer to spend more time outside viewing the water while enjoying the sail - then this is a great boat.
The tiller is balanced and can be held with almost no pressure even at higher speeds. It will point upwind as high as any boat. It will sail well upwind with the main only. It will tack with main only. It will sail upwind and tack with jib only - although it's not the most comfortable ride with jib only upwind.
I admit, you will probably find the speed can be addictive. I enjoy taking friends for high speed sails when I can. But if the crew is uncomfortable it's easy to take her off warp speed and do relaxed sailing even with strong winds (under 25 knots).
At my marina I'm normally the only boat going out if the wind is blowing over 20 knots. I'm also normally the only one sailing if the wind is under 5 knots. It's great to be able to go out most of the time.
Gregg
Corsair Sprint 750 Owner
  #22 (permalink)
Old 08-09-2010
Sea Slacker
brak is on a distinguished road
I am looking for relaxed flat sailing, actually Tri owners I spoke to promise that it, like any multihull, can be sailed flat and feels a lot better at anchor. I think, though, that speed is something that should be directly under control - it isn't hard to sail *slow*, I don't mind reefing early and often Going fast, on the other hand, is not always an option on another boat.
Anyway, I scoured the listings and the specs. It's either this or a small shoal draft monohull. Since I had a few of these in the past - they just don't seem like something I want to try again, unless I have to.
The cockpit space, on the other hand, is an issue and I do think based on specs and photos at least, that F-24 actually has a decently sized cockpit, open at the back - which is a good thing. F-27 seems cramped. In fact, even F-31 has a cockpit that to me seems very undersized. I think they tried to increase interior space - which is a good idea, but not at this cost.
From experience I found out that I spend most of my sailing time in the cockpit (though I do like to have a shade over my head). I really only go down below to check instruments and, may be, cook when anchored - and sleep, of course. Since long-distance cruising for various reasons is out of my plans in foreseeable future, interior space is not quite so important anymore.
  #23 (permalink)
Old 08-10-2010
Of the 2 versions of F-24, the older F-24 Mark 1 with the fixed mast has a slightly larger cockpit - maybe 6" longer - than the newer Mark II with the rotating mast. You'll also find the older Mark 1 to be priced less.
Good luck on your search. If you find one you want to see and need a checklist of things to look for to judge how good of a condition the boat is in , you can go to the designer Ian Farrier's webpage at Trimaran and Catamaran Designs By Farrier Marine, Inc. he has a detailed list of what to look for to see if the boat has possible issues or damage.
water is life,
Gregg
Corsair Sprint 750 owner
  #24 (permalink)
Old 09-02-2010
Sea Slacker
So, the search ended with this, in case anyone wonders:
Wish me luck
  #25 (permalink)
Old 09-02-2010
zz4gta's Avatar
I don't discuss my member
zz4gta is on a distinguished road
Picture no workie.
Merit 25 # 764 "Audrey"
  #26 (permalink)
Old 09-02-2010
smackdaddy's Avatar
Last Man Standing
Wish me luck
Sweet! Congrats brak! I can attest that those boats do actually go fast. We did 17 knots in a Corsair at the beginning of the summer.
BFS Gear: SNers started it....
  #27 (permalink)
Old 09-02-2010
Sea Slacker
We did 10 kts on a sail trial with fairly light wind. I actually had to work pretty hard to keep it under 8 (I don't think I feel very comfortable going much faster yet - got to get used to moving fast ).
  #28 (permalink)
Old 09-02-2010
FarCry's Avatar
Bombay Clipper
FarCry is on a distinguished road
Congratulations. Apparently you weathered Earl without too many problems.
  #29 (permalink)
Old 09-02-2010
Sea Slacker
Originally Posted by zz4gta View Post
Picture no workie.
I can't attach a picture here. I think photo hosting site is being flaky - but it should work eventually.
  #30 (permalink)
Old 09-02-2010
JohnRPollard's Avatar
Moderator
Brak,
Looks nice, congrats!
Is it a 24?
