08-20-2010
The VHF and SSB registration is done through OFCOM and they assign you your MMSI numbers - free of charge and no license is required. That means that the radios (VHF, SSB, EPIRB, etc.) is registered to the ship. You need a license in order to legally use the VHF and SSB deivces, the SRC and LRC respectively [except in emergencies, when all is allowed]. The UK tickets are among the easier ones and I recall reading that in Germany the UK SRC is not accepted (for Germans) but apart from that if you have one valid license from the EU it should be acceptable anywhere. The SRC course is interesting and goes into repetitive detail on correctly using DSC to submit various type of messages in correct format. The LRC is a bit strange - part of the examination is using a simulated INMARSAT-C teletype-like radio to submit requests and I know of no private sailor who has an INMARSAT-C device aboard.
If the boat is UK registered and has radio(s) then they must be registered.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
Reason: Added missing information
