10-01-2010
Columbia built 3 different designs at various times during the period '63 to '74, all referred to as "Columbia 26" (one was the Columbia 26 MkII). If yours is a '66, it would be the first version of the 26 - a stretched version of an Islander 24. Good headroom, outboard in a lazarette well (not a very efficient location for an outboard). I have a Bristol 24 with the same setup and the outboard is always starving for air unless the hatch is wide open. This means that when I'm running my 2-stroke, all conversation in the cockpit ceases.
As with many of the older boats in the 20' - 26' range, much of the value of the boat would be in the engine and sails. You didn't mention these, so its hard to judge whether this is a good value or not, but without both in good condition, the value of the boat is likely zero or less.
Look for soft (water damaged) decks and loose bulkheads. With the boat in the water and the stick out, you're at a disadvantage. You can't evaluate the rudder and hull, nor can you see if the mast is deflecting the cabin top, not to mention that you can't take it on a test sail! Good luck with the search.
Bill Sullivan
Allied Seawind 30
Bristol 24
Old Saybrook, CT
