-   Boat Review and Purchase Forum (http://www.sailnet.com/forums/boat-review-purchase-forum/)
-   -   Irwin Citation 34'' (http://www.sailnet.com/forums/boat-review-purchase-forum/6929-irwin-citation-34-a.html)
Bob Turk 05-06-2003 05:30 AM
Irwin Citation 34''''
Help, I am thinking of buying my first boat, an Irwin Citation 34'', but I have a concern regarding the centerboard. our family always had full keel sailboats,(ocean sailing) so that is what I am familiar with. This boat will sail Lake Ontario. My question is, was this boat, with it''s shoal keel, made specfically for shallow, easy sailing and/or how is it for hard handling? Am I asking for trouble with the centerboard? Also, is there a supplier for Irwin yacht parts? Thanks, I am looking forward to responses. Bob
irwin34bob 06-04-2007 01:11 AM
Hey Bob, Bob here, I can't shed light first hand with regards to the centerboard other than I have heard the cable that moves it does get jammed, there may be an easy fix, hopefully you will get more insight on that. I purchased a the same(1984 nodel) last December with a shoal draft keel. I have had very few issues,seems to sail fast and feels solid. as far as spare parts, it seems slim pick'ns. Good luck!
sailingdog 06-04-2007 09:40 AM
Bob-
Keel/Centerboard boats have been sailed around the world. They really aren't much different to handle most of the time from a keeled boat. They have a bit more maintenance, since the centerboard pivot mechanism needs to be looked after, but also have a few advantages over a regular keel.
First, they can go in to more waters more safely than a keel boat—due to the reduced draft allowed by retracting the centerboard.
Second, they can alter the helm balance of the boat by adjusting the centerboard's position. Raising it slightly moves the center of lateral resistance aft, lowering it more moves it a bit forward. This can help reduce or eliminate any lee or weather helm issues a bit more easily than on a keel boat.
A centerboard boat often can have better windward performance than a shoal keeled boat with the same draft as it would have with the centerboard retracted, since the centerboard adds lateral plane area below the water.
citation34 08-07-2007 08:35 PM
Bob, I can't help on the center board issue. But, as far as the Irwin 34 Citation goes, I love it. I bought a 1984 34' Citation shoal draft this past year and sail it on Lake Michigan. It handles heavy air and swells well and I don't need to reef 'til 20 knots apparent air. Boat is not tender and seems to refuse to heel past 30 degrees. Even with a shoal keel it points with the best of them. Wife wise, the cabin has real room and is equipped from Irwin very comfortably. Prop walk to port is the story when powering in reverse until you have some motion going (3 cyl yanmar). I've had to replace the ports and the surroundin panels as the originals (Greys) were installed over the paneling and leaked as flex let in H2O. Installed new Greys (sailboat owners.com) directly to the fiberglass (couldn't afford better than Grey) and applying new panel butted up to flange of ports. This past summer I've sailed with the best of them and this Irwin continues to impress me. This boat is not talked about enough (alhough I've gone on, haven't I).
Mark
Citation 34' 'Liberty'
_/)
Csobanc 04-03-2009 10:11 AM
irwin citations
Bob,
I also am interested in a 34'-35' citation ('84-'88 models). Is there anything you could tell me about these boats (pros and cons). I am hearing that these boats are prone to leak... do you find this true? Thanks for any info!
rikhall 04-05-2009 05:16 PM
I would pretty much say that any boat that is maintained correctly will be fine, any that is not will leak somewhere. But - the "leaks" you are probably hearing about are not sea water coming in, but rather, rain water through improperly maintained ports, chain plates, fuel and water fillers etc.
If you want a non-leaking, totally tight sailboat - try a new Morris, Hinkley, Island Packet etc. (showing my personal preferences) If you cannot afford those, then get a good sailboat from the early 70s on and maintain her properly.
Also - a 70s on sailboat will often have many of the little annoyances already fixed and can quite often have lots of extra gear already added by previous owners (POs)
Plus - guys like me can afford them. Me, I can only dream about a Morris :)
Good luck in your search.
Rik & Linda
Alfone6613 08-05-2015 12:14 PM
Re: Irwin Citation 34''''
Did you buy the 34' citaition? and if so, how did you make out with it.... Im looking at 34' citation, Ericson 28' or Catalina 30'...
I do plan on sailing the gulf of mexico from LA, MS to FL, Cuba, and Bahamas....
chuck53 08-05-2015 03:48 PM
Since Bob only posted here once 12 years ago, I don't think you will be hearing from him.
Alfone6613 08-05-2015 05:57 PM
Thanks alot for your reply.... so any recommendations on a vessel for my gulf excursion?
chuck53 08-05-2015 11:38 PM
Start your own thread, Looking for a boat to use in the gulf.
Give us some details...
How many people will usually be on board...creature comforts you want...must haves...like to have...any special requirements...size range...style of boat...and very important, budget to buy and budget to outfit-maintain.
There's a huge difference between a 28 and 34 footer...what draws you to those 2 boats?
