11-26-2010
Provided the boat has a centerboard, where the board is not a significant portion of the ballast rather than a swing keel, I don't see much issue with using one for bluewater passages, provided the boat is properly designed. As an example, the Ovnis use a centerboard and are well regarded as bluewater cruisers.
Shoal draft, which is a major reason many boats have a centerboard, is very advantageous, as it allows you to go more places, and gives you more options in terms of refuge from storms.
