Lippincott 30 - Info wanted - PLEASE - Page 2 - SailNet Community
post #11 of 22 Old 02-04-2010
andrea
lippincott 30
If you have any manuals on this boat please let me know.
acdc is offline
post #12 of 22 Old 02-04-2010
4arch's Avatar
I don't have any manuals but I'd be happy to answer questions. The water tanks are filled through ports under the port and starboard settees.
s/v Spindrift
Beneteau Oceanis 400
formerly Lippincott 30
4arch is offline
post #13 of 22 Old 02-20-2010
elkscout's Avatar
Bluewater capable?
Would anyone go so far as to say this boat could stand up to the rigors of ocean passages? Just concentrating on the construction of the boat, assuming the crew was capable and it was properly equipped and and in a desireable condition.
elkscout is offline
post #14 of 22 Old 02-20-2010
4arch's Avatar
Although the build quality is above average as compared to many other 30' racer/cruisers of that era (e.g. Catalina 30), there are several things that in my opinion disqualify the factory configuration from being bluewater capable. My main concerns would be the spade rudder, plastic portlights and molded fiberglass hatches, cockpit is a bit oversized and cockpit drains don't have seacocks, lazarette lids aren't sealed and don't have latches, the saloon settees are acceptable as sea berths but not great and would need lee cloths added, stove is non-gimbaled alcohol, the open saloon design not ideal for passagemaking and sacrifices storage on board, and there is no charting table, not even a stand-up. All that said, bluewater sailing has been done in lesser boats with upgrades and a lot of the issues with the L30 could be overcome if one wished.
s/v Spindrift
4arch is offline
post #15 of 22 Old 06-13-2010
Need advice
I am looking at a used 1985 boat. Hull, engine and rigging in excellent condition. Sails unknown but by report good. Interior looks 25 years old with cabin roof lining badly deteriorated and needs replacing. Floor stained and cushion covers etc old. Asking price is $14000 I am looking for first time crusing boat for narragansett bay and the local island (Block, Marthas Vineyard and Nantucket) and have some questions.
1. Do you recommend this boat for the purposes I have described
2. Is replacing the roof lining a huge job.
3. What are the negative and positive sailing characteristics of this boat
Many thanks for your replies and advice.
JM
jmovson is offline
post #16 of 22 Old 06-13-2010
4arch's Avatar
JM,
To answer your questions:
1. I'd really need to know more about the type of cruising you expect to do. Weekending, long term, full time? What kind of wind conditions do you expect to be sailing in? Are you going solo or will you have others aboard?
2. Replacing headliner is a dirty job but not hugely time consuming or expensive. The hardest part will be getting the old one without creating a huge mess. There are numerous threads on this site about headliner replacement. A bad headliner wouldn't necessarily deter me from buying an otherwise sound boat - though it might make me more cautious if it was severely water damaged/stained.
3. She seems happiest in winds of about 8-18 knots. Pros - Points quite well for her design. Doesn't have a lot of excessive weather helm. Doesn't have excessive heel - I've seen other boats bury their rails on those 8-18 days where I've been hard pressed to do so. Base PHRF is 180 on the Chesapeake but I believe she's faster and the 180's generous. She'd probably keep up with boats based in the 170's. Cons - Not a great light air performer, but she will keep moving. Foretriangle is a bit large compared to mainsail size so even with a 100 jib and reefed main you still have a lot of headsail out.
Beyond that, I'd be a little concerned about the staining on the cabin sole you mentioned on the boat you're looking at. Usually a stained cabin sole is a sure sign of excessive water having entered the cabin.
s/v Spindrift
4arch is offline
post #17 of 22 Old 06-18-2010
Would like to talk to you about your Lippincott 30
Andrea,
I live in Rhode Island and am interested in buying one of these boats. Any chance of meeting you to take a look at yours and perhaps even go for a sail.
I currently own a Pearson 26 but there is one near by going for a reasonable price. My email is jmovson@lifespan.org. Thanks JM
jmovson is offline
post #18 of 22 Old 06-20-2010
love my Lippincott 30
I have owned a 1984 Lippincott 30 for about 3 years now and its really a great boat...assuming the boat passes an inspection by a reputable surveyor, $14k is a great price for this boat...they usually go for about $25k..my headliner needs work too, just need to get to it...make sure you check the internal chainplates bolted to the bulkhead above the settes...make sure they're not water damaged...engine in good shape?
good luck!
Lippincott 30
Heartamann is offline
post #19 of 22 Old 07-16-2010
Lippincott 30 wiring
Any idea how the mast head running light wiring gets from breaker panel to mast step? Some of my running lights work, some do not, and for the life of me I cannot figure out how to trace the wiring pre mast. Thanks.
McKemey57 is offline
post #20 of 22 Old 07-16-2010
4arch's Avatar
I haven't traced wiring going specifically to the mast step yet but I'll tell you what I know about the routing of 12V wiring. On my boat, a large number of wires come out of the breaker panel and head toward the starboard side behind fiberglass panels accessible from the port cockpit locker. From there they dive down into the engine compartment and run aft behind the firewall, traversing it above the battery tray. From there they go down into the compartments under the quarterberth and continue forward in a conduit on the inboard side of the starboard settee. I haven't traced them beyond there but I suspect if they go to the mast on that side they'd go up into the head storage locker and then between the wood bulkhead and the shower liner up to the mast step. There are also a limited number of wires traveling under the lip of the galley locker shelf and forward along the inboard side of the port settee. Don't know what was added aftermarket on mine but I hope this helps!
s/v Spindrift
4arch is offline
Vacuflush toilet, head, info wanted Myblueheaven Gear & Maintenance 1 03-04-2005 11:53 AM
Abacos Info... BobbieP Cruising & Liveaboard Forum 4 02-04-2005 03:53 AM
Dufour sailboats in the 50'' plus - info wanted. Myblueheaven Boat Review and Purchase Forum 0 09-07-2003 09:54 AM
Lippincott 30 Bro Boat Review and Purchase Forum 1 04-15-2002 11:07 AM
Auto-Helm Wind Vane Info wanted captnorm Cruising & Liveaboard Forum 0 05-04-2001 05:05 AM
