01-13-2011
ASA and PSIA Instructor
Originally Posted by MichaelZZ
Oops didn't upload the pics
Maybe a thin barrier coat, but maybe just a primer of some type. A barrier coat should have some build up as you note, but also should be still attached to the High wear areas of the bow and keel. While the paint will wear off, a barrier coat should not.
Regardless, if the boat has no blisters and you intend to use it where the prior owner did, whatever it is, or is not, should be just fine. I wouldn't worry about the lack of a barrier coat if past use demonstrates no need.
