06-05-2003
Super Moderator
Blue water and single handed liveaboard?
This is a question that involves a lot of subjective issues. For example some might answer that if you are going to sail a boat that small go for the maximum displacement so that you can carry the most amount of supplies and fluids. Someone else might argue that you should go with a simple boat with reasonable speed so that you are able to make reasonably quick passages and therefore not need as much tankage or storage.
The example you gave of keel type. Someone could argue go with a full length keel because it will track a little better and will have more area in a grounding. Someone else might argue that most tracking ability on a boat that size is actually dynamic rather than steady state, go with a centerboard boat so that you can balance your helm, get into shallower water and have better performance than a full keel boat. Still, someone else would argue that most boats that size really will not self steer anyway (except perhaps upwind) without some form of windvane or autopilot and that fin keel spade rudder boats work much better than the other two with vanes and autopilots and also offer better performance on all points of sail so make the best choice.
You can make the same arguements about rigs. You can argue that a cutter rig offers a lot of flexibility in it sail plan and therefore is a good choice. It would be easy for someone else to argue that these are way too small a boat for the extra complexity and weight aloft of a cutter and cutters this size are a real pain in the butt to single-hand since it is is so hard to drag the headsail past the jibstay and so would argue that a masthead sloop rig is the obviuos way to go. And still someone else would argue that a fractional rig is the ideal cruising rig. The jibs are smaller and easier to tack. Fractional rigs are easier to depower so the need to be reefed less. They can be sailed quite easily under a just the mainsail without a jib or under a reefed mainsail in a blow making a really handy self-tacking heavy air set up.
It is all about perception and what you are comfortable with.
