Old 01-26-2011
nbarnes333 is on a distinguished road
Need help identifying this Cape Cod - interesting rudder
I came across this day sailer for sale and thought it might be a fun project boat. Can anyone help me identify this boat?
The builders plate says Cape Cod Shipbuilders and the number is 21 - 61, which I believe is hull 21 in 1961. I've scoured their web site to try to identify the model, with no luck.
I am very interested in figureing out this rudder configuration. (The boat is in the water so I haven't seen the bottom yet.)
Hopefully you can see the pictures. The tiller goes over the stern then to a rudder under the transom towards the keel. There is no centerboard, so Im assuming there's a keel under there.
Thanks for any suggestions.
Norm
Need help identifying this Cape Cod - interesting rudder-dscn0945-1.jpg   Need help identifying this Cape Cod - interesting rudder-dscn0957-1.jpg
Old 01-26-2011
Why don't you call them up. They can probably give you a lot more information over the phone, since they're still in business.
Old 01-26-2011
Thanks! I did send them an email and will definately call them. Figured I better have the accurate length first. hoping to get back up there to look at it this weekend.
Old 01-26-2011
By the way, love the quote at the end of your post! Very appropriate given the love it will take to get this beauty up to par!
Old 01-26-2011
Jeff_H's Avatar
Super Moderator
It would be helpful if you gave the length of the boat, but that appears to be a Bullseye, which was a fiberglass version of the Herreshoff 12 1/2 (waterline length) also known as a Doughdish. The Bullseye had several notable differences from the original Herreshoff 12 1/2's. The Bullseye's were bermuda rigged (rather than gaff), had a small cuddy cabin, some had self bailing cockpits. Depending on who you believe the Bullseyes were slightly heavier, and had less sail area and ballast than the 12 1/2's.
Curmudgeon at Large- sailing my Farr 11.6 on the Chesapeake Bay
Old 01-26-2011
Fstbttms's Avatar
I don't discuss my member
Fstbttms is on a distinguished road
"Clean bottoms are FastBottoms"
Old 01-26-2011
my friend's boat is about thirty feet from the hull molds for that boat iirc.
Originally Posted by Fstbttms View Post
Old 02-09-2011
Professional Sailor
DoubleShotDejaVu is on a distinguished road
This is a Cape Cod Shipbuilding Co Bullseye - and is, as you suspected, the 21st bullseye hull built in 1961. The rudder is attached at the transom and at the deadwood behind the keel by pintles and gudgeons. Feel free to message me with any further questions.
Old 02-09-2011
Just curious, are you affiliated with Cape Cod Shipbuilding? If so, you really do need to read and follow the SPECIAL INTEREST DISCLOSURE post in the boat buying forums.
Old 02-11-2011
Thanks for the assistance! It is indeed a Bulls Eye. Quite an interesting boat. Designed by Nathiel Herschoff and built since the early 1900's. I did contact the builder and I must say what an impressive response I got...specs, details, history...they were extremely responsive and helpful. No wonder they have been around for 100 years!
Cape Dory 28 Cape Horn Self-Steering Installed BillOfCapeCod Gear & Maintenance 6 05-20-2009 07:49 PM
Need help identifying a boat canoeman256 General Discussion (sailing related) 2 01-25-2007 08:03 PM
Sailing Coach of the Year for the Cape and Islands (Cape Cod Times) NewsReader News Feeds 0 08-04-2006 08:15 AM
Ahoy! Who's sailing on the Cape, islands? (Cape Cod Times) NewsReader News Feeds 0 05-25-2006 04:15 PM
Identifying an O''Day Daysailor voodooacrobat Boat Review and Purchase Forum 2 06-16-2002 02:17 PM
