Old 06-09-2003
salecm is on a distinguished road
Jeanneau 36 Steering
Steering behavior while under power of a 1990 Jeanneau 36 that I am considering to buy has me concerned. While at cruising speed or any other speed, the wheel behaves as if it has some play in it and feels like it''s encountering severe turbulence. Also while cruising the wheel pulls to port strongly like no other boat I have ever been on. I think the problem is probably not the rudder since the problem is eliminated as soon as the transmission is disengaged. The wheel is also very smooth and the boat handles beautifuly under sail. I had the boat surveyed prior to sea trial but the surveyor was unable to inspect the rudder and wheel linkages due to inability to find access.
My broker''s explanation is the two bladed prop that is centered in the hull and the semi-balanced high aspect ratio rudder that makes this boat such a nimble sailer.
Has anyone else experienced this behavior on any boat? Is so much torque steer while at cruising speed normal? Would a three bladed prop minimize the wheel vibration as my broker is suggesting? I would appreciate any help!
Old 06-09-2003
Sailmc is on a distinguished road
Every boat I have ever owned has pulled to port to some degree under power. My current boat does so as well with a 3 blade MaxProp. I think this may be a normal occurence for some boats. The vibration is probably due to loose steering cables. They need to be snug but not bar tight. The prop does put out a turbulent wash and the distence between rudder and prop may have something to do with it. I rarely hand steer the boat under power except in a harbor so it really doesn''t bother me much. Maybe JeffH has some input on this subject.
Control Head fix for Merriman Steering System tdp Gear & Maintenance 1 06-09-2011 03:00 PM
Jeanneau 36 Steering Under Power salecm General Discussion (sailing related) 12 05-14-2008 05:05 PM
Jeanneau quality is fine (Jeff H) JHodor Boat Review and Purchase Forum 7 12-28-2003 02:38 PM
Jeanneau 37.1 - observations from a charter DuaneIsing Boat Review and Purchase Forum 5 12-27-2003 08:35 PM
Jeanneau Tonic 23 dpcolohan Boat Review and Purchase Forum 0 03-11-2001 04:00 AM
