Swan 42 - Ron Holland Design - 1980-1985 - Page 4 - SailNet Community
 1Likes
post #31 of 38 Old 12-14-2012
Re: Swan 42 - Ron Holland Design - 1980-1985
Would anyone be able to forward the dimensions of the top opening of the companionway hatch on a pre 1985 Swan 42? Thanks.
Finnmark
Finnmark is offline
post #32 of 38 Old 12-14-2012
If you are interested in the sliding acrylic version on a 1981 42, Yes. Which
particular dimensions?
jamesjle is offline
post #33 of 38 Old 12-14-2012
Fore & aft from the fwd vertical teak face to the back side of the ss plate that keeps the washboard, and athwart; from inside both vertical teak faces (1 measurement) and also between the 2 vertical GRP surfaces outboard of the track that the acrylic hatch slides on (2nd measurement). This 2nd measurement would be slightly more then the width of the acrylic hatch glass. Many thanks for this!!
Finnmark is offline
post #34 of 38 Old 12-27-2012
Sorry for the delay on this I have been away from the boat. Its not quite clear to me, do you want the size of the actual hatch, IE acrylic sheet plus add ons
or do you want the internal size of the companionway hatch opening plus slide
dimensions.
jamesjle is offline
post #35 of 38 Old 12-27-2012
Thanks for the reply. Hope you had a nice Holiday! What I need are he dimensions of the opening: fore&aft from inside the teak (fwd) and to the inside of the stainless parts that hold the washboard. Athwart: inside the teak verticle trim (that the acrylic slides on). Thanks!
Finnmark is offline
post #36 of 38 Old 12-27-2012
Bon, demain.
jamesjle is offline
post #37 of 38 Old 12-27-2012
Hatch dimensions as follows;
Internal teak opening.
Length to inner side of S/S washboard retainer, 692mm, 27.24"
Across 590mm, 23.22"
External fiberglass slot, Wide, 700mm, 27.55"
Long 700mm, 27.55"
Outer edge tufnel slide, wide 670mm, 26.37"
Acrylic hatch Long 760mm, 29.92"
Wide 720mm, 28.34"
Thick 15mm, .59"
jamesjle is offline
post #38 of 38 Old 12-28-2012
Thank you James! Very helpful. Can't remember if I mentioned it, but as I sail offshore often with this boat, and it does extremely well in the big stuff, the leaky companionway is it's Achilles heel (now that I've ditched the wood sliding hatch on the fore deck and cured the babystay leak issue). Not even worth attempting to restore the interior varnish work around the area until it's resolved.
I am ordering an aluminum sliding hatch that seals when closed to fit.
Finnmark is offline
nicholson Ron Holland River Racing 7 10-30-2013 10:26 PM
AC / DC Lighting – a stylish design solution for the design obessive DIY… artbyjody Electronics 0 11-03-2009 02:33 PM
sailing in Holland. janboer644 Introduce Yourself 5 01-29-2009 10:55 PM
Swan falls in love with plastic swan (TVNZ) NewsReader News Feeds 0 05-29-2006 11:15 PM
Lovesick swan falls in love with swan paddle boat (Reuters via Yahoo! News) NewsReader News Feeds 0 05-26-2006 02:15 PM
