04-04-2011
Tartan 27' owner
Cool find.
Sunfish can be a fun boat to sail. Before I dumped a lot of effort into the sails though I would try to check if the hull stays pretty dry when in the water.
Older hulls can leak and become water logged and no matter how good the sail is, you ain't sailing anywhere fast. Find out how long it takes for water on the deck, in the mast step and on the hull/deck joint to take on water, if at all.
If you are lucky it will remain buoyant for a long time. In that case I'd check out everything from craigslist to ... for a new(er) sail for your new Sunfish.
This place sells the newfangled (and better) rudder hardware for the Sunfish: APS - Sunfish - Rudder, Tiller and Daggerboard
Not cheap but worth it (cheaper) if you make your own center board and rudder from wood stock. Mahogany wood is what was mostly used for these parts with a varnish finish.
Good luck.
Fun, but wet boats.
