Old 04-20-2011
sailpower's Avatar
sailpower is on a distinguished road
Morgan 34 vs Morgan 35
60’s vs 70’s vintage.
They look pretty similar. Other than condition would there be a reason to choose one over the other?
It is hard to find any direct comparison info.
Use would be coastal and the Bahamas.
Thanks.
Old 04-29-2011
maarty10 is on a distinguished road
Morgan 34 versus Morgan 35
If you go to Carls Sail Calculator (Sail Calculator Pro v3.53 - 2500+ boats) and enter both boats for comparison, you will find that the Morgan 34 is better than the Morgan 35 in several ways:
The capsize ratio of the 34 is better, and the comfort ratio is much better, than the 35. Most of what this is a result of is the greater weight in the ballast of the 34.
The theoretical hull speed of the 35 is a bit higher than the 34, but bear in mind that the 34 can do better than 7knots quite easily; I would not rely on the hull speed numbers in this case.
The popularity of the 34 is reflected in the greater numbers that were built.
In my opinion the 34 is prettier too.
A factor in buying a 34 is the interior configuration. Unfortunately many of the 34's were built with the galley starboard; which makes the salon awkward and unsafe underway. They were done this way to pick up an extra berth, so that this configuration could sleep 6 instead of 5; the galley starboard has 2 berths underneath the cockpit.
I hope this helps.
Old 05-02-2011
sailpower's Avatar
Thanks Maarty. I am familiar with the different layouts. Appreciate the link.
Morgan 323 nk235 Boat Review and Purchase Forum 22 1 Week Ago 02:20 PM
Morgan 60 dennisfrakes Morgan 2 04-10-2008 10:15 AM
morgan 36-R bucephalos310 Racing 4 11-28-2007 05:34 AM
Morgan 36 O/i rridgeway Morgan 4 03-02-2007 07:55 AM
What about a Morgan OI? tuco General Discussion (sailing related) 9 01-07-2003 11:51 AM
