Old 05-23-2011
stephaneg is on a distinguished road
Cold-Molded Boats good or bad?
Hi everybody first of i m new here
well i have a question about Cold-Molded sailboat. I hear that they are the best. I am going to buy a sailboat to be living abord and sailling around the world and i like to know if a Cold-Molded sailBoat is good or a bad idia? I like to find one that is about 40 feet. what you all think about it? or is it better to get a older 1967 vintage fiberglass? i red that they are better then the newest one.
thank you for your help.
steph.
Old 05-23-2011
WanderingStar is on a distinguished road
Welcome aboard. A well built cold molded boat will be light, stiff, and durable. But they were mostly built for racing, and they represent a very small percentage of the market. Glass boats built in the 60's tend to be heavy, therefore solid, and less prone to blisters than 80's boats. But older boats often need much work: new rigging, interior or engine. You really should read this site thoroughly and spend time with sailors and aboard boats before you buy one. Good luck, it's a great lifestyle.
Old 05-23-2011
puddinlegs is on a distinguished road
Cold molded boats are great! There are few because they're labor intensive to build.
Old 05-23-2011
thanks to both of you
Old 05-23-2011
SlowButSteady's Avatar
Senior Slacker
SlowButSteady is on a distinguished road
I believe that Bruce Schwab's "Ocean Planet" has a cold-molded hull. Managed to complete the Vendee Globe in 2005.
Old 05-23-2011
mitiempo's Avatar
For a one-off boat my first choice would be aluminum and my second choice would be cold-molded with epoxy construction. They are in the minority because they don't lend themselves to series production. But they are lighter and stronger than a conventional fiberglass boat. This is where fiberglass wins - one mold and they can pop out hundreds if not thousands affordably. As with any boat you find maintenance is more critical than hull material.
Brian
Old 05-23-2011
imagine2frolic's Avatar
imagine2frolic is on a distinguished road
Ocean Planet is cold molded. I sail a cold molded boat, and if ever I was to build a boat. I would use the process. I am very happy with her. You do have to be careful of fresh water, and I have had a couple of small drainage problems. You don't have to be an artist to do a good fix, and the repairs can be easy. Make sure to get a syrveyor who is familiar with the construction.......i2f
20 MPH ain't fast unless, you do it in a 1000sq 3/2 house on 10foot waves
BORROWED, No single one of us is as smart as all of us!
Old 05-24-2011
hey all i ave a new qyestion..is composit hull like Cold-Molded hull? is it the same thing?
thanks
S
Old 05-24-2011
Not always, there are different composites.......i2f
Old 05-29-2011
GaryHLucas is on a distinguished road
A cold molded boat is a boat with a laminated wood or fiberglass hull. The wood is cut into thin strips about 1/8" thick. these are then bent over frames on a diagonal to get the hull shape. Subsequent layers are added with epoxy resin, on the diagonal running the opposite way so they cross. Essentially the hull becomes a single thick piece of plywood. There is a fiberglass material made in strips called C-flex that is also used to build a boat the same way.
You don't need a mold, so it is good for a one off. However you don't get a molded smooth gelcoat, so finishing the hull is very labor intensive.
Good deals on boats uspirate Off Topic 15 01-02-2012 05:48 PM
Cold molded fibre glass elrika12 Boat Review and Purchase Forum 10 03-16-2007 04:41 PM
Old Boats still Good Boats mvsunstar Boat Review and Purchase Forum 5 09-30-2006 05:30 PM
Taiwan boats, any good? Douggie Boat Review and Purchase Forum 9 03-25-2005 02:55 AM
Opinions welcome->Good Old Boats bubba Boat Review and Purchase Forum 14 02-26-2001 02:47 PM
