Old 07-18-2003
msl msl is offline
msl is on a distinguished road
Catalina "Capri 26" comments
Would anyone familiar with the Catalina Capri 26 care to comment about:
build quality
sailing (handling)
inboard vs outboard
trailerability
It would be used as a lakeboat and coastal, bay areas. At the most a Florida - Bahamas trip in favorable conditions.
Thanks
Old 07-21-2003
Wega24 is on a distinguished road
OH its an awful boat
lousy workmanship
real slow
really high depreciation
and so forth
Now tell me where the one you are looking at is located, best with the telephone or email of the owner ...
Although I am not familiar with the bahamas I probably would not consider to sail there with a capri 26, but than i might be wrong
( as I am certainly with my first statements ..lol . I am looking for one ! )
Thorsten
Old 07-11-2008
captainjimbolio's Avatar
captainjimbolio is on a distinguished road
Capri 26
lousy workmanship
real slow
and so forth
Thorsten
I hope Thorsten was practicing his sarchasm because the Capri 26 (At least for me) has been a great 1st boat). I have a 1991 Wing keel with an outboard.
PROS:
  • Good interior room - I've had 4 adults and 4 kids sleep over night on her.
  • Stable - Have had her over to 32 degrees. The furthest I have had her out is 10 Mi off shore in San Diego. She weathered 8' swells pretty well on the way to Mission Bay.
  • Trailerable: Mine weighs in at 5100 lbs empty, but the fin keel is a little heavier I think
  • Shallow draft Wing or Fin Keel. I only draw 3.5' (Which has come in handy) but I'm sure I have given up some windward performance because of the wing keel.
  • Room: 6' Headroom-Which makes it a palace for my little 5'8" self. Two 9' cockpit benches are ideal for outdoor sleeping, the drop down talble makes a large double (Or quadruple with kids) berth, the under Cockpit Pilot berth easily sleeps two. I usually end up as the entertainment boat at a raft up. I have had 10 people in the cockpit.
  • Enclosed head, with shower
  • Pressure water - I have a hot water heater which gives me two days hot-warm water once unplugged from the dock
  • Wide - 9'6" beam - gives you 1' decks on either side of the cabin. Foredeck has room for 1/2 a dozen kids hanging feet over to catch the wakes.
  • Sugarscoop Transom - Great for access to the outboard, swimming, boarding from dingy
  • Diesel OR outboard (Diesel takes up all the room under the companionway that's why I like my outboard)
  • Tiller - Gives you the Feel of the ocean.
  • Active community of owners (there is a capri 26 yahoo group out there)
CONS:
  • Did I say it was WIDE - the 9'6" makes you only legal on the road on a trailer if you have WIDE LOAD permits, signs, etc. A pain.
  • Performance: She easily get's to within 45degrees of windward and her hull is rated at 5Kts. (I have had her up to 8.15Kts when I had the 32degree heel) but generally 4-5 kts is typical in 10-15kts breeze.
  • Sailplan: On my sloop, the foresail (IMHO) is a little undersized. I have a 100% Jib rollerfurled, that I have difficulty trimming to perfection. (Luffs a lot). I move the genoa cars around a lot. My winches are on the cabin top and if I want to upgrade to a 130-150Genny, I have to get two winches, genoa car tracks, etc mounted on the deck above the cockpit. There are oodles of C26's out there already set up with 4 winches.
  • Wood, there is not a lot of wood on the outside, but there is enough to tie you up every couple of years sanding, staining and varnishing. To me, this is part of the joy of boat ownership.
  • Parts not easy to obtain - I needed a new stern ladder (Mine developed a rust hole) and it took me a long time, photos and measurments to help Catalina figure out what the heck I had there. It's a special bend because of the sugar scoop transom. Other plastic parts have withered away over the years, and it's not easy to find those either.
I have to disagree with the workmanship comment - Occasionally I'll find a screw that is out of place, but not often. Depreciation seems to have leveled out. The range right now is about 12,000 - 22,000 for a capri 26. I paid 18K for mine in 2001. (But my 7,500 gvw trailer would add to the value, that I bought after the purchase of the boat).
I hope this helps
Captainjimbolio
You can see pictures of her in my avitar and sig.
'91 Capri 26' Hull# 131
Tiburon
Chula Vista, CA
Old 07-11-2008
I seriously doubt either one cares much at this point...since the posts in question are FIVE YEARS OLD. Please don't revive dead threads and you might want to read the dates of the posts before responding to them.
BTW Wega24 most likely was being sarcastic given his looking for one.
Also recommend you read the post in my signature.
Old 07-16-2008
LOL, my bad,
My blood just got up about my boat. You know how it is.
I read your post, and will be more careful. Thanks
Tiburon
Chula Vista, CA
Old 07-16-2008
De nada captain Jim.
Old 10-24-2008
Diverboy is on a distinguished road
Capri 26 help!
Hello there I am also A Capri 26 owner, I appreciate your enthusiasm for the boat. Its very hard to get info on her. Your last poat said you were considering getting a larger Genoa, Did you? and if so how does it sail? I am considering a 155% but my fellow sailors seem to think that the 155% will be overpowering her, and hard to handle. What are your thoughts?
PROS:
CONS:
I hope this helps
Captainjimbolio
Old 10-24-2008
Delirious's Avatar
Pearson 31-2
Delirious is on a distinguished road
Capri's are built adequate for what they are designed for - a light day sailor & weekender. I wouldn't hesitate to do some coastal crusing picking the days carefully and keeping the weather radio on.
It's got an active class association ( Capri 26 National Association ) and is a good solution for a pocket cruiser.
PS - whether a 155% is overpowering it will depend entirely on the winds in your area. I like a 140 to 135% for lake sailing and winds of 10 to 20 knots.
Charlie P.
To travel hopefully is a better thing than to arrive - R.L. Stevenson
I suspect that, if you should go to the end of the world, you would find somebody there going farther . . . - H.D. Thoreau
Old 11-10-2008
cavelamb is on a distinguished road
Capri 26
I just learned about the Capri 26.
I've sailed the 18 (for several years) and 22.
I thought the line topped out with the 25, which is a
slightly bigger version of a 22, which is a slightly bigger
version of an 18. The 26 looks like a whole 'nother thing,
though.
I've found several old links to boats that were once for sale,
but not there any more.
Does anyone here know of a 26 for sale?
Preferably somewhere near Texas, but any US boat would
be considered.
Thanks
Richard
Old 11-10-2008
astraeus's Avatar
WAFI
astraeus is on a distinguished road
though.
be considered.
Thanks
Richard
Try:
Sailing Texas, sailing lessons, sailboats for sale, sailboat rentals, charters, used sailboats
Pretty good source for trailerable boats.
Jason
S/V Astraeus
1980 Chrysler 26
"I used to be wise for my age, but then I got older."
MacGregor 22 vs. Catalina 22 lastmate Boat Review and Purchase Forum 21 02-05-2012 05:09 PM
Catalina 270? jbarros Boat Review and Purchase Forum 11 07-27-2008 03:41 PM
Winter cover for catalina capri cwilloz Gear & Maintenance 0 12-01-2004 02:00 PM
C&C or Catalina MarsMachine Boat Review and Purchase Forum 56 02-09-2004 07:02 AM
Catalina Capri 26 for Sea of Cortez monark192 Cruising & Liveaboard Forum 1 03-23-2002 06:18 AM
