First Boat - Pearson 26 vs Seafarer 26 - Page 2 - SailNet Community
post #11 of 17 Old 07-31-2011
The P26 seems to be a more popular choice. This is an actual great one to get. I am all for it as well.
Boatinglifeaway is offline
post #12 of 17 Old 08-02-2011
I agree with sloanfiske . There are many more Pearson 26 than Seafarer 26 so you will get alot of opinions on Pearsons. Might take a look at Seafarer Research Center
There are Seafarer "original" information sites, like brochures that make Seafarers sound like the best thing since sliced bread. Quote. " McCurdy and Rhodes designed and for offshore sailing". Excellent construction and very roomy inside. Excellent hull to deck joint. *I would have to see both boats that I was looking at to decide.
---Every review or comment about the -Pearson 26- says small or cramped inside- AND the rudder hardware needs replaced or to make sure you watch it for a breakdown.
---Every review/comment about Seafarer says they are roomy and well built. There is no consistent, constant negative comment about the Seafarer 26. I agree and I own a Seafarer 26 for 2 yrs.
sidney777 is offline
post #13 of 17 Old 08-03-2011 Thread Starter
Many Thanks
Looked at the Seafarer this past weekend and found it well cared for. Couldn't get it together with the Pearson owner for an inspection. Like the trailerability of the Seafarer and will likely make an offer. Thanks again to all who have responded with valuable input. It is a great into to sailboat ownership that the "community" takes the time to offer a newbie advice and guidance.
Sailski3 is offline
post #14 of 17 Old 11-11-2012
Re: First Boat - Pearson 26 vs Seafarer 26
I have a Seafarer 26 and my 'slip neighbor' has a Pearson 26.
See Sloanfiske's info. In addition to the skeg hung rudder and
encapsulated keel (no keel bolts to worry about) one major
enhancement the Seafarer has over the Pearson is where the
chainplates connect to the sidestays. The Pearson connects on
deck...eventually, unless you are maintenance meticulous, that
is where your soft spots will begin. The Seafarer's chainplates
are on the side of the boat...no soft spots or costly deck repair.
Both are solid and neither will win a race...but I'd take the Seafarer26
over the Pearson26 every time.
Whiskerpole is offline
post #15 of 17 Old 11-11-2012
our first boat was a 1980 Seafarer 30, which had been impeccably maintained. We liked the fin keel/skeg-hung rudder so much we looked for the same in our current boat. don't know how the 30 compares to the 26, but our 30 was fun, fast, great in light airs and lived large for a 30' boat. We sailed her extensively in the Cheseapeake, and had a lot of good times. She did better to windward, didn't really like downwind sailing as much. Seafarers are very reasonably priced, and very good value... perfect for a Chessie boat. Ours drew 4'11", and we managed to get into a lot of gunkholes. Make sure to check portholes for leaks, and integrity of chainplates. Good luck.
bobnpaula is offline
post #16 of 17 Old 11-12-2012
Senior Smart Aleck
jameswilson29's Avatar
The Pearson 26 chainplates are fastened to the cabin bulkhead, not the deck. Fastening chainplates to the hull is not necessarily an advantage.
According to N.E. PHRF, the Pearson 26 rates 213 while the Seafarer 26 rates 240. That means the Seafarer will be given approximately an extra half a minute (27 seconds) a mile to catch up with the Pearson.
jameswilson29 is offline
post #17 of 17 Old 11-12-2012
Chastened
Ajax_MD's Avatar
Assuming two boats in equal material condition, consider the following:
Seafarer 26:
Ballast to displacement ratio: 35.5%
Sail area to displacement ratio: 14.5%
Displacement: 5200lbs.
Beam: 8.25'
LWL: 22.25'
Pearson 26:
Ballast to displacement ratio: 40.75%
Sail area to displacement ratio: 16.75%
Displacement: 5400lbs.
Beam: 8.67'
LWL: 21.7'
The Seafarer will be more tender (tippy), and the Pearson will be a little stiffer.
The Pearson has the higher SA: Displacement ratio, while being only 200lbs heavier, and so should be a little quicker.
The Pearson's waterline length is a hair shorter, but I'm not sure if this will really slow her down compared to the Seafarer.
The Pearson is a tad beamier, which might give you a little more cabin volume.
The cabin layouts are very similar, so no clear victory there.
I give the performance edge to the Pearson, possibly the edge in comfort.
I give the maintenance edge to the Seafarer, with it's encapsulated ballast and skeg-hung rudder.
On the Pearson 30, the ballast is encapsulated like the Seafarer. I believe that the ballast on the P26 is cast-iron and bolted on.
I would carefully inspect both boats. If the bilge sump of the P26 is clean and dry, and the keel bolts are in great condition, I would buy the P26 for the performance edge.
If the keel bolts are suspect, I'd buy the Seafarer, all other things being equal.
If these boats are in the Maryland Chesapeake area, I'd be willing to take a look at them with you.
Just remember- My opinion is worth exactly what you paid for it.
Alacrity, 1981 Tartan 33 #168
Ajax_MD is offline
Tags
new boat purchase advice , pearson26 , seafarer26
My first boat...Pearson 22? djherse Boat Review and Purchase Forum 35 10-21-2013 12:32 PM
Does this boat have value, Pearson 35 Sailmachine Boat Review and Purchase Forum 10 06-10-2010 01:40 PM
1962 Seafarer Polis in trouble - Owner giving away boat N0NJY General Discussion (sailing related) 3 12-31-2008 04:14 PM
Pearson vs Seafarer - 30 ft sloop johnrobert Boat Review and Purchase Forum 2 03-14-2001 06:25 PM
