Sailboat financing in Hampton Roads, VA - Page 2 - SailNet Community
post #11 of 16 Old 08-13-2011
Jorge_cast,
Just so you know, yes, interest on a live aboard boat is deductible on your taxes. However, the amount of interest you will be paying on a $25,000 boat may not be enough to be of any help to you unless you have a lot of other tax deductions.
When it comes to tax time, even with the boat interest deduction, you may be better off taking the standard deduction instead of itemizing.
chuck53 is offline
post #12 of 16 Old 08-13-2011
dhays's Avatar
SunTrust Bank
I financed my boat through SunTrust Bank in Texas. Check the page out and clink on the rates and terms link. See if you qualify. They have very competitive rates for boat loans and will even handle the USCG Documentation Process for you.
Dave
47⁰20'11.7" N
122⁰35'20.8" W
M/V Kinship, North Pacific 43
Formerly
S/V Legacy, Catalina 400 MkII, Hull #328
dhays is offline
post #13 of 16 Old 08-14-2011
If you go the CG documentation route, do it yourself for $95. Most service companies that do that, charge $400-500 to handle it for you.
chuck53 is offline
post #14 of 16 Old 03-06-2012
F15EWSO's Avatar
Re: Sailboat financing in Hampton Roads, VA
Just finished getting "pre-approved" with my bank for $99.999 at 5.49% on a 15yr loan. Can anyone share if this is a good rate? I've been with this landlocked bank for 25+ yrs so getting the approval was about a phone call and 10 minutes.
Should I shop around?
F15E_WSO + 1
Deale Md, to Caribbean Oct 2012-Aug 2013
Boat Type Irwin 43 Mk III Center Cockpit--Sold it
Boat Yr, 1989
Boat Length 43'
F15EWSO is offline
post #15 of 16 Old 03-06-2012
I assume they are filing a lien on the boat, which you should likely want for tax deductibility, then it's a pretty good rate.
Jeanneau 54DS
Minnewaska is offline
post #16 of 16 Old 03-06-2012
Ditto SunTrust, they seem to know what they are doing in terms of yacht loans.
You might also pick up a Spinsheet and check the advertisements for local lenders.
PalmettoSailor
s/v Palmetto Moon
1991 Catalina 36
PalmettoSailor is offline
DIY Yard in Hampton Roads sailne1 Chesapeake Bay 4 10-03-2010 02:49 PM
DIY Yards in Hampton Roads sailne1 Gear & Maintenance 0 09-26-2010 09:52 PM
Hampton Roads, VA crew wanted for Dec 29th ncstatesailor Crew Wanted/Available 2 12-23-2009 12:18 PM
Greetings, and looking for a good A/C contractor in Hampton Roads CleverName Introduce Yourself 0 08-07-2009 11:37 PM
Beaufort, NC to Hampton Roads? Angelgal918 Cruising & Liveaboard Forum 3 04-01-2009 01:32 PM
