Build Quality: Ericson, Pearson, Sabre, Tartan - Page 8 - SailNet Community
 16Likes
post #71 of 116 Old 08-31-2011
GRR,
We're Lake Michigan sailors who know folks with these boats but haven't sailed them. A T34C from the '70s that's 2/3 of the way through a total restoration is 2 slips from us, with an '80s Tartan 34 across the finger pier from it. Other friends have a Sabre 34 from the '80s. All are boats beloved by their owners - and reportedly sail well. We also know folks who have had Pearsons and Ericsons and were happy with them. Well-maintained, all are good boats, especially with full draft or keel/centerboard combinations, on the Lakes. I would add to this list the S2 11 meter, another well-built boat from the '80s (there were few 10.3s built and they are hard to find on the used market).
If you intend to do some distance cruising on the Lakes and have time constraints, upwind sailing performance is important, as undoubtedly you'll have to do some of this. In our experience, a Catalina 30 with a wing keel or the much newer Jeanneau SO34.2 or SO35 with a shoal-draft keel will have more leeway and not make as much progress upwind as a boat with a full keel or a shoal keel with a deeper centerboard, absent assistance from the Iron Genny. The shoal draft is useful in the few shallow harbors and when anchoring in some places, but not nearly as necessary in the Lakes as it is reputed to be in Chesapeake Bay. Unless you wish to frequent a harbor or anchorage where deep draft just doesn't fit.
Some Pearson models/years have deck core issues which we understand arise from faulty bedding of the lifeline stanchions. Sabres are hard to find on the Lakes and priced higher than the other boats. While Catalinas are OK boats, have great mutual support among their owners, and the Catalina owners we know all like their boats, the makes you mentioned in your first post are better if well-maintained.
And keep in mind that a freshwater-only boat will usually have fewer problems than one that has been in salt water, all else equal.
--Karl
so34chi is offline
post #72 of 116 Old 08-31-2011
chef2sail's Avatar
I would also be looking into the C&C 35 of thiis era as they are sturdy, well built and perform better on many points of saIL than most of the boats already mentioned.Additionally these is quite a fleet of them on the Great lakes as they were built in this era. This is in no way a put down of the Tartans, Ericksons, Personas or Sabres. They are all fine boats. In fact when I purchased Haleakula it was between her and a Tartan 37 and a Sabre 36. The C&C 35MKIII was in better condition. Thats what drove me to buy her. All are good quality boats.
Dave
___________________________
C&C 35 MKIII Hull # 76
Parkville, Maryland
(photos by Joe McCary)
Our blog-
chef2sail is offline
post #73 of 116 Old 08-31-2011
JimsCAL's Avatar
I believe the Pearson 31 and 33-2 built in the mid 80s had that issue. Pearson used gaskets under the stanchion bases rather than traditional bedding. Didn't work.
JimsCAL is offline
post #74 of 116 Old 08-31-2011 Thread Starter
Pearson 31-2/33-2 Design Flaw
That is too bad. I was considering going to look at both of these models. Is this a major project to fix? Would this design flaw rule out this class of boats or would a good example be worth looking at and repairing if needed?
Grand River Raider is offline
post #75 of 116 Old 08-31-2011
Chastened
Ajax_MD's Avatar
No, it wouldn't rule it out. Every boat has some kind of flaw. Don't let "Perfect" be the enemy of "Good Enough".
You're asking all the right questions and doing your research but I think you're starting to suffer from information overload a bit.
In the case of the P-31 and 33-2, early owners may have caught this problem early and fixed it. Later owners may have repaired soggy core and sealed the stanchions. Go look at the boats, and just have the surveyor (or you) check for stains, soft spots, and use a moisture meter. Tap around and listen for a dull thud that indicates a soggy core.
Alacrity, 1981 Tartan 33 #168
Ajax_MD is offline
post #76 of 116 Old 08-31-2011
GRR,
--Karl
Ah! That's what I meant... the 11, not the 10.3. A friend has one and loves it. He and his wife have been chipping away at upgrades, replacements, repairs, etc... it has to be one of the nicest S2 11's around!
puddinlegs is offline
post #77 of 116 Old 08-31-2011
Irrationally Exuberant
GRR, Pearson used the brilliant gasket method under the stanchions of our 87 P28-2, which we bought 4 years ago. It's not necessarily that big a deal. No doubt it depends on the boat, but here's how ours went. The surveyor found our decks to be solid everywhere, and dry for the most part. He found elevated moisture and some dead soundings around the bow pulpit and near the stbd jib track. Otherwise all good. I have since potted and rebed all stanchions and really only had wet core and around 3, with some localized rot out maybe 2 inches around the 2 pulpit supports. I was able to scrape out the bad stuff with pieces of coat hangers to get to good core and then refill these areas with thickened epoxy during the potting.
So, yeah, repotting-rebedding is a pain, but I'd plan to do that on any boat that old that hadn't had it done. It certainly shouldn't disqualify any Pearson you're interested in without inspection--and really, once you know how to inspect, you can do a good preliminary check on this yourself.
Tom K
2000 Beneteau 331
Northern Chesapeake Bay
arf145 is offline
post #78 of 116 Old 08-31-2011
Sailing Junkie
Send a message via Skype™ to boatted9
Overload of Information
Here's an additional thought that might help. We have literally searched for and looked at (online and in person) hundreds, maybe thousands of boats. We finally started an eliminatiion process in size, prices, style and quality. By elimination (price first) and setting realistic ranges we narrowed our search down a lot, but we also found a number of less well know names that fit our requirements. If you can be really specific (in your own mind) about what you must have you'll find fewer boats to consider, but that special beauty may come out of the pack, and you may never have heard of the builder before. We recently have had that experience and found a wonderful boat (for us) at a price we could afford that many do not recognize.
Good luck, and remember, the journey is usually as rewarding as the destination.
boatted9
boatted9 is offline
post #79 of 116 Old 09-02-2011
GRR: go to ericsonyachts.org and check the thread "E-35 kicks butt"
mikel1 is online now
post #80 of 116 Old 09-02-2011 Thread Starter
Pearson 31-2 Deck Surgery
arf145,
Thank you for this information. Shortly after previous posts about the stanchion-deck issues on Pearson 31-2 and 33-2, I contacted a broker about a late 1980's model 31-2. He said it is a very fine boat, but a recent survey found wet decks, mostly around the bow area on both starboard and port. They finally decided the problem was at the toerails and upon removing these discovered that all of the "caulking" was gone. The balsa core was tested and found to be wet, but to have no rot. So, they hired a company called Dry Boat (ever heard of this?) to fix the problem. As it was explained by the broker, all of the toerail was removed, holes were drilled in around the deck horizontally rather than vertically, and then a bunch of small tubes were inserted and air was injected through the tubes over a period of time to dry the core. Then the toerails were bedded. He said a surveyor was involved throughout the process to check the work.
As part of this process, he said they also rebedded the stanchions. If someone were to rebed the stanchions on these boats properly, would the gaskets remain or would this be replaced by something else?
I am going to go see this boat in a couple of weeks. I am a bit leery about a boat that has had such major surgery, but maybe that fixed the problem (or maybe it didn't ). At the very least, it will give me an opportunity to see whether I like this model and whether it is worth pursuing other examples.
GRR
SHE Yachts Build Quality? SteveT44 Boat Review and Purchase Forum 0 01-06-2009 07:15 PM
Feedback on Ericson 30+, Tartan 3000, Cal 31, Pearson 32 SESailor Boat Review and Purchase Forum 2 12-07-2007 12:39 PM
Hunter Build Quality? SEMIJim Boat Review and Purchase Forum 64 06-24-2007 01:04 AM
Pearson 39-2/Ericson 38-200/Tartan 37 D&D Boat Review and Purchase Forum 4 11-18-2005 11:26 AM
build quality maiden Boat Review and Purchase Forum 5 03-29-2004 06:47 PM
