08-22-2003
Bene/Catalina v. Sabre/tartan--new or used
Like buying a car, it all depends on where and how you intend to use the boat, and on your ego. (If you think ego isn''t an issue, how many people really need limos or big suvs or high end sports cars?)
Are you using it on inland lakes, or for coastal cruising, or for making long passages? Is speed and lively performance important to you, or are you only concerned with getting there safely, no matter how long it takes? If you are only going to use the boat in a less demanding environment, does your ego require that you have an upscale boat that will "wow" the dockwalkers, but that is overbuilt for your intended use? Could you be equally satisfied with a used boat in excellent condition that has depreciated significantly, rather than a sparkling, new boat with all the latest bells and whistles? Many of us would have widely differing answers for those questions, but only your answers would be right for you.
In short, you should look at the boat to see if it is designed and built to meet your needs, and then look inside yourself to see if it meets your expectations. If it fails in either respect, you probably won''t be happy with it.
Personally, I bought a new boat over 20 years ago with all the options, and, when you amortize it, it has been a great value. However, if I was buying a boat that I only planned to keep for 2-4 years, I would definitely buy a used boat.
Many people who are 3-4 years away from retirement, and can''t take the time to make long passages might want to buy a used Catalina or Beneteau now, and then buy a new, bigger, tougher, more luxurious boat when they retire.
The good thing is that, thinking about all these things, and hunting for just the right boat is almost as much fun as having it.
