Does size even matter at all? - Page 2 - SailNet Community
post #11 of 14 Old 08-25-2003 Thread Starter
So, you would suggest for 4-5 people, for sailing across the atlantic, something big like a 40-50ft? so what type, a J-boat, Tartan, or any others?
Jeffamc is offline
post #12 of 14 Old 08-26-2003
Moderator
Jeff_H's Avatar
I would not necessarily suggest a J-boat or Tartan, because the marjority of the models by both companies are oriented toward coastal cruising or in the case of J-boats towards racing and coastal cruising. That said both are also well made boats.
But if you are looking for a comparatively fast boat (which I belive that you said that you were) and you are carrying 4 or 5 adults then I am suggesting a 40 to 50 footer. To some extent the company and model will be dictated by how much you can afford to pay and what your ultimate itinerary will be.
Both J-boats and Tartan have made models that might work for your needs but they will be a comparatively expensive way to go.
Jeff_H is offline
post #13 of 14 Old 08-26-2003 Thread Starter
Well Jeff_H, what are some less expensive 40-50 footers that are good for bluewater? i can afford up to $90,000 for the sailboat. Just something that is fast, and something that can handle rough waters.
Respectfully,
Josh
Jeffamc is offline
post #14 of 14 Old 08-27-2003
We purchased a Formosa 46 for 75k and have put about 15k into her. The Peterson 44 is a similar boat. They are very capable of long range cruising.
sailcarter is offline
Thoughts on a mid size cruising boat FRRizzo111 Boat Review and Purchase Forum 6 11-13-2004 04:10 AM
what size prop?? stevfran Gear & Maintenance 1 01-30-2003 07:16 PM
winch size maestro Gear & Maintenance 6 12-19-2002 08:09 PM
sail size to boat size ronbrockman General Discussion (sailing related) 0 09-25-2001 04:10 PM
Minimum sailboat size to get two seperate sleeping quarters? duffer1960 General Discussion (sailing related) 9 08-02-2001 12:14 PM
